Cruise Control din_forward  [SOLVED]
mane2
Has thanked: 40 times
Been thanked: 41 times
Post by mane2 »
So, I have Tesla LDU and when going forward I need to put the motor to "reverse" in firmware point of view to go forward. When trying to use cruise control, it won't engage as in code there is this
   if (Param::GetBool(Param::din_brake) || !Param::GetBool(Param::din_forward))
      Throttle::cruiseSpeed = -1;
So it always sets cruiseSpeed to -1 when going forward with Tesla motor (as it's on din_reverse when going forward).
I'm on firmware v5.32.R
How to fix this? How to enable cruise on Tesla motors?
Has thanked: 380 times
Been thanked: 1562 times
Re: Cruise Control din_forward  [SOLVED]
This was added as a safety measure.
Set dirmode to SwitchReversed and rewire your direction selection
mane2
Post by mane2 »
Cool, thanks. I guess "hill hold" -mode will start to work then too.
mane2
Post by mane2 »
Got the cruise control working by rewiring and switching to SwitchReversed. Thanks!
But Hill hold did not start to work :( Was it so, that it works only on FOC version?
That needs proper testing. Supposed to for sine, too but apparently doesn't
