48v 15kw inverter for tesla modules Topic is solved
im currently using a sungold power 48v 10k inverter to power my house via solar and I have 12 24v tesla modules in a 2s 6p configuration for 48v, my issue is i cannot use about 35% of the battery bank as the inverter cutoff voltage is 40v is there a way to change this or maybe assemble a diy inverter built specifically for this? I have a vero bms hooked up currently to monitor the battery bank
Re: 48v 15kw inverter for tesla modules
I should mention im looking for a low voltage cut off of 37 volts
