Wanting to contribute and try to implement Qt Software front end.
Hello all. I have about 6 months till my shop is built and I can start working on conversions and I'd like to learn more about the software for the open inverter and eventually build a UI for conversions based on the open source software Qt. I'm learning the QML C++ language for the UI, what language should I learn for understanding and working on the open inverter software?
Re: Wanting to contribute and try to implement Qt Software front end.
The STM32CubeIDE is the way to go.
But there are probably other IDE's
- Been thanked: 1914 times
Do you actually want to play with the software or do you "just" want to design a frontend and need to know the interface? In case of the latter look at the output of the "json" command. And look at inverter.js in the esp8266 project.
I use Code::Blocks IDE because it's less convoluted and just takes 1s to start. Lacks some features though, code completion ain't the best
Start with "just" building a front end, and then go from there. I'll look at what you suggested thanks!
