Control of the two inverters at the same time
yaroslav
Has thanked: 14 times
Post by yaroslav »
Hi! Сan connect two control units via the can bus to control both units synchronously, connect the accelerator pedal to one control unit, and transmit the position of the gas pedal to the second control unit via the can bus ?
Has thanked: 380 times
Been thanked: 1571 times
Re: Control of the two inverters at the same time
Absolutely.
Map "pot" to can bus on inverter 1, e.g.
can tx pot 1 0 16 1
And on inverter 2 (set potmode to CAN)
can rx pot 1 0 16 32
Configure the same throttle ranges etc. Done :)
yaroslav
Post by yaroslav »
Thank you, everything worked
Has thanked: 405 times
Been thanked: 260 times
Post by MattsAwesomeStuff »
yaroslav wrote: Thu Apr 30, 2020 7:18 am Thank you, everything worked
You sure?
Because I don't see any pictures of video...
"I slept with Scarlett Johansson"
... not very convincing, is it? :D
Bowser330
Post by Bowser330 »
Any update on controlling two motors, would love to hear about the build!
yaroslav
Post by yaroslav »
The Assembly will be a little later, the engines will be connected through a coupling.
