Tesla main juction box model S
Johaljaswant
How to wiring 12 pin connector of Tesla Main Junction box to make it work for swap.
- Kevin Sharpe
- Been thanked: 10 times
Re: Tesla main juction box model S
Do you want to swap this into a Tesla car or into a conversion?Johaljaswant wrote: ↑Wed Jul 03, 2019 2:07 pm How to wiring 12 pin connector of Tesla Main Junction box to make it work for swap.
Johaljaswant
- Kevin Sharpe
Johaljaswant
- Kevin Sharpe
Link works fine for me and I can access documents (see screenshot)... maybe it's an issue with your browser (I'm using Chrome)... why not try looking up that error message?Johaljaswant wrote: ↑Wed Jul 03, 2019 4:57 pm Could not down load any thing my Drive said no recoded activity.
Johaljaswant
I can access these file through chrome. Thanks,But I could not find any references regarding junction box connection.
On page 20 of 2014.2_ModelS_RHD_Release.pdf only give you High voltage interlock connections reference.
- Been thanked: 1139 times
You don't actually need to control anything in the HVJB in order to use it with the Gen 2 charger for AC charging.
Johaljaswant
That’s good,Thank you jack,I was assuming that high voltage contactor may work by supply from that 12 port pin.
- Kevin Sharpe
Here's a thread with lots information on the HVJB from the Model S (pre 'face lift' models);Johaljaswant wrote: ↑Thu Jul 04, 2019 3:12 pm That’s good,Thank you jack,I was assuming that high voltage contactor may work by supply from that 12 port pin.
https://www.diyelectriccar.com/forums/s ... p?t=181417
Here's a link to the schematic for the main PCB;
https://www.diyelectriccar.com/forums/s ... ostcount=6
AFAIK no one has published any detailed information on the control board in the HVJB.
As 'Jack' says, you don't need to do anything to use the HVJB with the Gen 2 Tesla chargers. Controlling the contactors in the HVJB will only be required when we start DC charging via a Tesla CHAdeMO/CCS adaptor (which is awaiting the next version of the charger control board).
What about controlling the contactors in the Model S gen 3 charger with a V3 Open Inverter control board?Kevin Sharpe wrote: ↑Thu Jul 04, 2019 6:20 pm Here's a thread with lots information on the HVJB from the Model S (pre 'face lift' models);
I'm struggling to find current information on the charger controls. There's a decent amount of information here concerning specific issues with earlier revisions of the control board, but I'm at a loss for current information. I'm trying my best to teach myself and not rely so heavily on everyone here, but I could use a little pointer. The Tesla subforum doesn't get much traffic currently, and only goes back to 2019, but I think the charger boards were in development prior to that? Is there an archive and can I access it?
I've also found some minor discrepancies within the documentation on Damien's github. Is that the latest and greatest publication, or is someone else keeping the newest revision? How do I submit corrections? Does anyone care at this point?
