congratulations on your success. may we ask what the reason was?Jack Bauer wrote: ↑Mon Aug 09, 2021 9:13 am The mystery of the Circontrol station stopping at 80% has been solved. Of course It wasn't anything that I thought it was.
i still have three prototypes that i would sell for € 50 apiece. I would also be happy to receive a feedback to hear if it works properly. The circuit diagram can be found on my tread.bitterandreal wrote: ↑Fri Aug 20, 2021 10:49 am @muehlpower & Jack Bauer
How far is the voltage sense board?
Are you willing to sell one for testing? Or could we get the design files?
I would like to purchase one of your prototype board for testing. I'll try to learn how to send you a private message.muehlpower wrote: ↑Fri Aug 20, 2021 5:51 pm i still have three prototypes that i would sell for € 50 apiece. I would also be happy to receive a feedback to hear if it works properly. The circuit diagram can be found on my tread.
Would love to get some SPI/PCAP captures here, just to see what the efacec is unhappy about. Is state 0 normally SLAC? There are a few stations that are borderline out of spec in terms of SLAC setup speed. I'd like to see the captures to make sure your fix doesn't break compatibility with another station or something.Jack Bauer wrote: ↑Sat Aug 21, 2021 2:33 pm 2)Efacec. No charge constantly failing around state 1/2. Modded the state machine so state 0 is "standby" for 2 seconds. Problem solved.
That’s nice I sent you a PM to arrange payment and shipping.muehlpower wrote: ↑Fri Aug 20, 2021 5:51 pmi still have three prototypes that i would sell for € 50 apiece. I would also be happy to receive a feedback to hear if it works properly. The circuit diagram can be found on my tread.bitterandreal wrote: ↑Fri Aug 20, 2021 10:49 am @muehlpower & Jack Bauer
This is the link to the circuit diagram viewtopic.php?p=28143#p28143.bitterandreal wrote: ↑Mon Aug 23, 2021 8:18 pmThat’s nice I sent you a PM to arrange payment and shipping.muehlpower wrote: ↑Fri Aug 20, 2021 5:51 pmi still have three prototypes that i would sell for € 50 apiece.bitterandreal wrote: ↑Fri Aug 20, 2021 10:49 am @muehlpower & Jack Bauer
Could you share the link to you’re tread?
Is the board tested with a working setup?
I wrote a big part of the wiki and followed the thread from the beginning but can't remember anyone mentioning contactor holding current or voltage.Jack Bauer wrote: ↑Mon Sep 13, 2021 10:46 am Please use the search function in thread or wiki article : https://openinverter.org/wiki/BMW_I3_Fa ... LIM_Module
that's exactly how i did it. I have small relays in parallel with 15 ohms and use them to switch Gigavac 240 with economizerbitterandreal wrote: ↑Mon Sep 13, 2021 10:17 am
The easiest way is probably using a wire wound resistors to simulate the 15 ohm coils and a small relay in parallel to switch the HV contactors with internal economizer.
Original contactor coil ~15 ohms
Thanks! Just got the resistors.muehlpower wrote: ↑Mon Sep 13, 2021 11:44 amthat's exactly how i did it. I have small relays in parallel with 15 ohms and use them to switch Gigavac 240 with economizerbitterandreal wrote: ↑Mon Sep 13, 2021 10:17 am
Can you say what make and model station that is? Normally the EVSE Max Current Limit in the current demand response message will tell you the maximum of what you can request, and it should not cause a fault if you are following it. Assuming what you said to be true would mean that many cars would fault at that station.Jack Bauer wrote: ↑Mon Sep 13, 2021 8:38 am Edit : and oh yeah trying to pull 50kw from a different vendor's 50kw station resulted in a shutdown with "vehicle problem" reported on the screen. Setting a maximum of 40kw cured my "vehicle problem" and the car charged fine. This despite respecting the limits and flags transmitted by the station.
Hah! Sometimes it's the simplest issues.Jack Bauer wrote: ↑Thu Jun 24, 2021 3:06 pm Uh guys? So ehhh...found out why I only got 8 amps from the Tritium....... My silly prepaid access app thingy needs at least a 20 Euro balance! So as they say in America : I was outta quarters:)
jon volk wrote: ↑Thu Sep 23, 2021 12:55 am Does anyone happen to have a part number for the mating connector of the i3 CCS locking actuator? Im coming up empty other than finding the complete mating harness from an i3.
On a related note, these IP67 RGB LEDs looks like a nice choice with a common cathode and easy mounting.
https://www.mouser.com/ProductDetail/Di ... A2ew%3D%3D
Is that a connector on the LIM itself?jon volk wrote: ↑Thu Sep 23, 2021 12:55 am Does anyone happen to have a part number for the mating connector of the i3 CCS locking actuator? Im coming up empty other than finding the complete mating harness from an i3.
