Tesla LDU iacmax
RiPower
Tesla LDU iacmax
Post by RiPower »
Hello,
who can tell me how to set the iacmax correctly on the Sport LDU? I want to play it safe and not destroy the controller. In the online parameter overview the value is 5000A but with this value all security is probably deactivated. I have now tested and driven the motor with 1000A, but the derating occurs relatively quickly and the motor has little power in the lower speed range.
I drive a 1998 Chevi K1500 Silverado with 2 x Tesla Power (SDU + LDU)
Matra Murena 1983 with Tesla SDU
various electrical conversions for customers: https://ripower-elektrofahrzeuge.de/
P.S.Mangelsdorf
Has thanked: 238 times
Been thanked: 280 times
Re: Tesla LDU iacmax
Post by P.S.Mangelsdorf »
Take a look at the parameter sets shared here:
https://openinverter.org/forum/viewtopic.php?f=10&t=195
Jon's parameters are probably the most extreme setup that has significant street time.
jon volk
Post by jon volk »
I didn’t play too much with current limiting settings. I found pushing too had against them would cause oscillation into a desat fault. A sport unit should be able to take more, but I don’t have any experience to say that more comes in additionally aggressive settings or it just makes more power at equivalent parameters.
RiPower
Post by RiPower »
Thank you very much for the hints, as I can see the max values are always 5000. According to my conversation with Mr. Johannes Huebner, the LDU can only tolerate 1200A but he is not sure. If I now go to 2000A or more, the output stage won't burn out either?
Isaac96
Post by Isaac96 »
iacmax sets the point at which the OpenInverter board will start reducing current. It is basically a safety measure -- if current gets that high it will be reduced.
With a parameter set like Mr. Volk's, the other parameters (fslipmax, boost, fweak etc) drive the motor within its safe limits so that current stays lower.
RiPower
Post by RiPower »
Oh, thank you very much for this explanation, so should I use the suggested parameters and avoid derating?
Does anyone know at what maximum motor current does the whole thing settle? So what is the maximum motor current for the LDU? The point is that I cannot go to the maximum because my cardan shaft cannot handle the maximum torque. But if I don't know at which motor current the maximum torque is applied, I can't throttle sensibly. I hope you understand my question, my english is not good I work with a translator.
Thank you in advance for your answers.
Has thanked: 384 times
Been thanked: 1589 times
Lowering fslipmax reduces maximum torque most effectively.
