Tesla LDU WLAN module failed
For your information, 2 weeks ago I had the problem that I no longer received a WiFi signal from the inverter. I then removed the engine and removed the cover. The WiFi module had slipped out and was lying loose in the housing. So that this doesn't happen again, I've now secured it with a cable tie. See photos:
I drive a 1998 Chevi K1500 Silverado with 2 x Tesla Power (SDU + LDU)
Matra Murena 1983 with Tesla SDU
various electrical conversions for customers: https://ripower-elektrofahrzeuge.de/
Re: Tesla LDU WLAN module failed
I used a dab of hot glue for mine. Also added some glue to the electrolytic capacitor as I had a cracked solder joint at one point.
I also thought of hot glue, but I was worried that it would get a little warmer under the hood.
