Hi guys!
I'm currently in the progress of installing a leaf setup, using the motor, inverter and pdm, we are using the ZombieVerter to control.
I'm hoping to use the chademo setup within the pdm, Has anyone made progress with implementing this with the ZombieVerter?
Thanks in advance!
Chademo charging!
- Bratitude
- Has thanked: 246 times
- Been thanked: 469 times
Re: Chademo charging!
i dont think anyone has, but should be very straightforward to use the current hardware layout and just control the contactors directly with your own logic.
though I bet the necessary CANBUS ids are floating around in some of the available leaf logs. pretty much everything else has been decoded.
paaa
- Has thanked: 2 times
- Been thanked: 13 times
I have chademo logs somewhere along with a.c. charging logs , I'll dig them out.
- Been thanked: 1134 times
