ZombieVerter VCU Support
- EV_Builder
- Been thanked: 37 times
Re: ZombieVerter VCU Support
You need recursive enabled to download sub repo's.
- Been thanked: 1130 times
Yep will be in all forthcoming kits also.electromatic wrote: ↑Sun Oct 30, 2022 4:43 pm Hi, just wanted to say that NCV8461DR2G is available at RS again if you are missing this one. https://uk.rs-online.com/web/p/peripher ... ps/1869867.
- AdrianB
- Has thanked: 24 times
- Been thanked: 23 times
I’ve built up my Wemos WiFi adapter board. As Damien says it’s quite straightforward. The only thing to watch is that the back of the mini USB port doesn’t short the connector pins. For the 10 pin connector I used item 613010243121 from Mouser.
Can anyone confirm if the instructions for installing the software at https://openinverter.org/wiki/Olimex_MOD-WIFI-ESP8266 work for the Wemos module and the Zombieverter? Also should we be using Johannes web interface code https://github.com/jsphuebner/esp8266-web-interface or the GS450H VCU code https://github.com/damienmaguire/Lexus- ... aster/WiFi ? I can’t see any code specifically for the Zombieverter VCU.
Carlton Commando
Zombieverter
BMW hybrid battery
Outlander charger DC/DC
Zombieverter
BMW hybrid battery
Kelju
- Has thanked: 13 times
- Been thanked: 19 times
This did not help for me, but thanks.dadiowe wrote: ↑Thu Oct 27, 2022 8:42 pm Hi,
This .bin file is a blank file. I recall Damien giving me the link for it.
If you flash this file then power down and repower the Zombieverter then use the latest recommended .bin file on the github page it might cure your problem. I have tried thid method myself and it has worked for me.
Also, I checked the tutorial video again from the part that covers the wifi issues, but it does not seem to provide a cure for this.
According to this thread viewtopic.php?t=1756, the problem might be a filled up flash.
All the symptoms seem to point to this direction.
Here is what I get with "http://192.168.1.26/list":
[{"type":"file","name":"chart.min.js.gz"},{"type":"file","name":"refresh.png"},{"type":"file","name":"remote.html"},{"type":"file","name":"gauges.js"},{"type":"file","name":"inverter.js"},{"type":"file","name":"gauges.html"},{"type":"file","name":"jquery.knob.min.js.gz"},{"type":"file","name":"gauge.min.js.gz"},{"type":"file","name":"log.html"},{"type":"file","name":"ajax-loader.gif"},{"type":"file","name":"README.md"},{"type":"file","name":"log.js"},{"type":"file","name":"style.css"},{"type":"file","name":"jquery.core.min.js.gz"},{"type":"file","name":"syncofs.html"},{"type":"file","name":"wifi-updated.html"},{"type":"file","name":"wifi.html"},{"type":"file","name":"stm32_vcu"},{"type":"file","name":"stm32_vcu.bin"},{"type":"file","name":"chartjs-annotation.min.js.gz"},{"type":"file","name":"index.html"},{"type":"file","name":"index.js"}]I do not have any clue as to which of these files can be deleted and which ones are needed.
Can somebody check the list above and tell me which ones I can toss.
Just use the standard web interface from Johannes.AdrianB wrote: ↑Mon Oct 31, 2022 10:08 am I’ve built up my Wemos WiFi adapter board. As Damien says it’s quite straightforward. The only thing to watch is that the back of the mini USB port doesn’t short the connector pins. For the 10 pin connector I used item 613010243121 from Mouser.
I use this code from the wiki:
I get the error about the key, and the command fails... the.zip file downloaded from the repo has the empty folders when unzipped
But further, I haven’t had success uploading the .bin or .hex file for the GD chip with stlink or over the web interface.
I uploaded the bootloader and got the accty led blinking, but it goes dead after “uploading” the firmware and I have no serial communication. I really don’t want to have to unsolder the chip and replace it, because I don’t have a hot air station
- mjc506
- Has thanked: 30 times
- Been thanked: 29 times
Why have you got the 'git@github' thing in there? You're trying to authenticate as the user 'git' on the github servers, which is unlikely to work...
That’s the command directly copy/pasted from the zombieverter wiki page... it doesn’t say anything about authenticating
Here’s what that section of the wiki says:
“ If you properly clone the repository with git on the command line that looks like this;
./Stm32-vcu/libopeninv/src/
Make the above changes to these files for the GigaDevices GD32F107.”
- mjc506
Try . The one on the wiki assumes you've got your own github account set up with ssh public key auth
https://github.com/damienmaguire/Stm32-vcu.gitRe: ZombieVerter VCU Support
Looks like I need a break.... The GD chip doesn't want to cooperate, and now I'm suddenly getting USB communication error in stlink utility
A quick rundown of my problem trying to program this thing:
First started by uploading precompiled GD chip with Stm32-vcu.hex with stlink... Utility showed successful, but no blinking ACCTY LED
Eventually programmed bootloader with stlink and successful blinkenlight ACCTY LED
Eventually got esp wifi interface programmed and able to view web interface on my laptop browser
Attempting to upload precompiled GD chip Stm32-vcu.bin with wifi interface showed "Upload Successful" instantly, with no progress bar
Uploading Stm32-vcu.bin with stlink gave similar results as wifi interface method... both show as successful, but no firmware seems to have actually loaded.
I've cloned the git and installed ARM toolchain (but get the error of arm-none-eabi-gcc command not found) when building so I messed that up probably due to my shitty terminal skills
If anyone has successfully programmed a GD chip... I'm all ears
- AdrianB
I don’t think your .bin file has uploaded. When I upload it I also see the “upload successful” message instantly, then after a few seconds the progress bar appears and progresses very slowly. Often it freezes before it gets to 100%. I have to repeat the process several times before it it gets to 100%.
Carlton Commando
Zombieverter
BMW hybrid battery
Zombieverter
BMW hybrid battery
- AdrianB
Using TPS as throttle.
I want to keep my original accelerator pedal so I’m using the car’s throttle position sensor (TPS) to provide a single channel throttle signal for the Zombieverter. Calibration went fine, except for the usual Olimex WiFi problems, but the motor doesn’t start spinning until the throttle is about 30% open. Any suggestions about how I troubleshoot this?
Carlton Commando
Zombieverter
BMW hybrid battery
Zombieverter
BMW hybrid battery
- EV_Builder
Throttle response depends on more factors then only on the signal. First step is make sure the signal is setup correctly.AdrianB wrote: ↑Wed Nov 02, 2022 9:44 am Using TPS as throttle.
So movement of the throttle is a movement of the signal.
After that its about parameters how quickly does the inverter raise signals in relation to throttle?
The first 30% is the regen zone. Set your regen params to 0 to disable.AdrianB wrote: ↑Wed Nov 02, 2022 9:44 am Using TPS as throttle.
The .bin file definitely didn't load, I'm well aware... Pretty sure I caused it to get stuck, because the bootloader was uploaded successfully and I had a blinking ACCTY led, but no longer. I honestly don't remember if I tried uploading the GD Stm32-vcu.hex with stlink, or the .bin with wifi interface first. In any case, the uploads were not successful, and I don't have the blinking LED indicating the bootloader is running so I'm pretty sure that means uploading via wifi is out.AdrianB wrote: ↑Wed Nov 02, 2022 8:54 am I don’t think your .bin file has uploaded. When I upload it I also see the “upload successful” message instantly, then after a few seconds the progress bar appears and progresses very slowly. Often it freezes before it gets to 100%. I have to repeat the process several times before it it gets to 100%.
Unfortunately, I can no longer connect to the target in stlink utility because it fails target detection. I've tried powering on the chip with reset tied to ground, 3.3V, boot0 tied to ground, 3.3v and none allow the stlink to recognize or connect to the chip.
Stlink utility will go in circles saying change settings to "connect under reset", then when you do to set to "normal or hotplug". Changing SWD frequency has no effect
Messages from stlink utility console:
"Can not connect to target!
If you're trying to connect to an STM32W1xx device, please select Normal or HotPlug mode from Target->Settings menu.
If you're trying to connect to a low frequency application , please select a lower SWD Frequency mode from Target->Settings menu.
13:12:15 : No target connected
13:12:32 : Can not connect to target!
Please select "Connect Under Reset" mode from Target->Settings menu and try again.
13:12:34 : No target connected"
- AdrianB
Thanks. That worked a treat. I had to leave 5% regen to stop the motor creeping at zero throttle - probably a problem with some other parameters but I ran out of time today.Jack Bauer wrote: ↑Wed Nov 02, 2022 10:19 am The first 30% is the regen zone. Set your regen params to 0 to disable.
Carlton Commando
Zombieverter
BMW hybrid battery
Zombieverter
BMW hybrid battery
Re Patreon Video "Improved Zombie". Unfortunately I can't see the named video for some reason. Can I ask if the work on the GS450H reconversion is completed and if everything is working OK.
My question is in relation to regen not working and jerkiness in throttle operation. I ask this as I have these two issues and I don't want to waste time trying to diagnose the issues if they are software related.
Question on the Zombieverter for the Nissan Leaf. Can I use any of the unused pinouts, such as oil pump or the pots and trans outputs to control the water pump and brake vacuum pump?
Sure. You'll just need to reprogram the firmware for your specific needs.
No its not finished yet. When it is there will be videos and forum post and any problems with the vcu will be reported and solved. Most likely by me. I'm a team of one on this and many other projects.dadiowe wrote: ↑Fri Nov 04, 2022 10:45 am Re Patreon Video "Improved Zombie". Unfortunately I can't see the named video for some reason. Can I ask if the work on the GS450H reconversion is completed and if everything is working OK.
Kelju
I finally got around to revive the Zombie with the ST-Link flashing and it did come back to life. Afterwards I tried the wifi update, but the Zombie was once again bricked.Kelju wrote: ↑Mon Oct 31, 2022 5:37 pm According to this thread viewtopic.php?t=1756, the problem might be a filled up flash.
Here is what I get with "http://192.168.1.26/list":Can somebody check the list above and tell me which ones I can toss.Code: Select all
Would really appreciate if someone can check the file list above and tell me what can be removed from the wifi module flash.
I can manage with the ST-Link, but it is somewhat of a pain.
- asavage
- Has thanked: 369 times
- Been thanked: 119 times
You have a file named stm32-vcu with no filetype, and the .bin file stm32-vcu.binKelju wrote: ↑Sat Nov 05, 2022 11:27 pm I finally got around to revive the Zombie with the ST-Link flashing and it did come back to life. Afterwards I tried the wifi update, but the Zombie was once again bricked.
I would delete those and start over.
I found the wifi update is MUCH more successful if you connect the esp module to your home wifi instead of connecting to it's AP/192.168 wifi address. You can do this by connecting to the esp's 192.168.... address and changing the wifi settings. On the bottom you can enter your home wifi ssid and password and your wifi router's dhcp will assign it an IP address
Hi guys, new to the forum. Have recently purchased the zombieverter vcu from Damien and had it assembled as per video but still have to fit IC 10 as not supplied in the kit. After connecting the resolver cables and doing a basic power check using 12v volt battery the micro controller IC 8 started giving off smoke signals so I quickly disconnected. Where have I gone wrong.
I am using the lexus 300h and inverter.
