Code not compiling after setting up a "new" computer
Kelju
Has thanked: 13 times
Been thanked: 19 times
Post by Kelju »
Hello,
I am trying to get the development environment running on another computer.
Followed the instruction and executed the following commands on the terminal:
sudo apt-get install git gcc-arm-none-eabi
Installation goes through with no errors.
When trying to make I get the following error:
arm-none-eabi-g++: error: unrecognized command line option '-std=c++17'
I checked the compiler version on the old computer and the new one and both are the same:
gcc (Ubuntu 5.4.0-6ubuntu1~16.04.4) 5.4.0 20160609
Any idea why I am getting this error and how to fix it?
crasbe
Has thanked: 58 times
Been thanked: 180 times
Re: Code not compiling after setting up a "new" computer
Post by crasbe »
Your gcc version is too old as you are using quite an old version of Ubuntu (16.04, 7 years old by now :D ).
You can find a guide to update the gcc compiler here: https://askubuntu.com/questions/1243252 ... ocal-fossa
Unfortunately it is a bit (a lot) annoying.
Been thanked: 1914 times
You could also edit CPPFLAGS in makefile to std=c++11 (I think, or was it 12?) try it. Don't think we're using any of the newer features
Kelju
Post by Kelju »
Thank you both crasbe and johu. Both resolutions work.
The reason why I ran into this problem was because I am lazy...
I am running the Linux on a Windows environment inside a Virtual Box.
When changing the PC, I did not want to go through all the trouble of installing a whole new Ubuntu on the Vmachine, so I opted to just make export/import. As crasbe pointed out, the installation was badly outdated. On this note, I now made a fresh installation with the most recent Ubuntu. Works perfecty fine after setting up everything.
Also tried the instruction from Johu with the old Ubuntu installation and the problem was fixed.
