The SuperYacht BMW E65 7 Series
- Kevin Sharpe
- Been thanked: 10 times
Re: The SuperYacht BMW E65 7 Series
The HV Junction box being prepared for installation (note the ISA shunt which will play an important role in conversions going forward)
xp677
- Been thanked: 15 times
What are the red isolators that are mounting the fuses? I'm looking for a solution to this at the moment .
- Been thanked: 1124 times
I found a variety of choices using the search terms "Buss Bar insulators". Here's a link to amazon.com https://www.amazon.com/LBY-Busbar-Insul ... B078TDD4X6
I like the High voltage junction box, do you have a part number for that?
- Kevin Sharpe
It's a generic plastic box that was purchased from a local electronics store...
- Kevin Sharpe
Why not try printing some and tell us how you get on
zippy500
- Has thanked: 100 times
- Been thanked: 7 times
Google search : IP65 plastic enclosure
I like the ones with the clear lids
I will, but when I come to this part
Lots of wiring and component mounting done in the Bexus.
mattndex@gmail.com
Is there a chance of you posting a schematic of how the high voltage junction box is wired.
xp677
That's awesome, many thanks. Some more digging and the best Google term seems to be "stand off insulator".Jack Bauer wrote: ↑Fri Feb 21, 2020 7:44 am Had a hell of a time finding these.
https://www.amazon.co.uk/gp/product/B07 ... UTF8&psc=1
I've currently resorted to cutting out big chunks out of whatever my fuses were originally mounted to - these insulators are a much better solution!
It's funny how similar our projects have turned out - I'm also using a Tesla Gen3 charger in the same location, but I've gutted the end of it that has the supercharger PCB/contactors and am using that as the junction box for my 320V bus. I'm also using the TRW PAS pump, and it looks like the same vacuum pump.
Do you have more info on that (or pics)? That is a very good solution to make everthing appear OEM to evade the EMC testing when converting the car from ICE to EV with the authorities.xp677 wrote: ↑Sun Feb 23, 2020 4:12 pmThat's awesome, many thanks. Some more digging and the best Google term seems to be "stand off insulator".Jack Bauer wrote: ↑Fri Feb 21, 2020 7:44 am Had a hell of a time finding these.
xp677
I have not published information on that yet. And now I feel that doing so may be a bad idea. I do not wish to publish Information which would be used explicitly to circumvent such testing.
However the procedure is as described. Remove the parts which you do not need and replace with those that you do.
It looks like Damien has kept his charger intact, so this discussion is not relevant in this thread.
Hm, that is indeed a good point. Thanks for the reply anywayxp677 wrote: ↑Tue Feb 25, 2020 11:55 pm I have not published information on that yet. And now I feel that doing so may be a bad idea. I do not wish to publish Information which would be used explicitly to circumvent such testing.
- Kevin Sharpe
Top balancing the test battery today... here's the rear pack
- Kevin Sharpe
The participants on next weeks course are building a HVJB for the Grey Goose project. It will be very similar to that used on BEXUS. I'll ask them to document the build and post details in that threadmattndex@gmail.com wrote: ↑Sun Feb 23, 2020 2:49 pm Is there a chance of you posting a schematic of how the high voltage junction box is wired.
Front of the car all back together. Next up wiring in the V2 VCU with Wifi and ISA Shunt interface.
V2 VCU and isa can shunt up and running in the bexus. VCU now controlling precharge, startup and shutdown as well as hv control during charging. WiFi interface works perfectly.
It may be possible to wire it up this way. Ive done it for other electronics transmissions in the past.
Weigh in for the GS450H transmission.
Oops, I'm waiting for the gearbox to be delivered, I need a crane to move it ...
- mdrobnak
- Been thanked: 5 times
Nice! Definitely great progress.
I heard you say "that's interesting" but couldn't make out what you were referring to.
-Matt
