My first post here so a quick intro....
I am using the Enova 3ph 90Kw motor coupled to the Enova power stage with the Damien/Johannes Combi V8 board and Johannes Olimex board running v4.87 software.
My questions to the forum please ...
The motor rating plate gives two values for RPM, Continuous 3600rpm and Max 9000rpm. Also two values for Frequency, Base 121Hz and Max 305Hz, however I am trying to work out what settings to use for the following...
Fweak
Fslipmin
Fslipmax
Not sure what to set the parameters to ?
I wish to use the full rpm range, max 9000rpm, motor rated voltage 208v.
DC bus voltage at present is 230v most probably will be increased to 280v later once I am rolling.
If anyone is based in the North West UK please say 'hello' too
All the best. Peter
