electric karting udc 52v
yaroslav
Has thanked: 14 times
Post by yaroslav »
I decided to share my project too (electric karting ) I use an inverter powered by 52V maybe someone will be interested, to start I will post a photo of my controller
yaroslav
Re: electric karting udc 52v
Post by yaroslav »
Now I will lay out the controller in assembled form, this is how it looks now
yaroslav
Post by yaroslav »
Схема отлично работает
Alexstarex
Post by Alexstarex »
Привет. Круто получилось. Распиши характеристики.
В чем рисуешь? cad?
Hey. It was awesome. Describe the characteristics.
What do you draw? cad?
yaroslav
Post by yaroslav »
the inverter was designed for 72 volts, on the MOSFET irfp4110 I had at hand irfp3077 I used them, on the battery a maximum of 54 volts, the phase current of about 200 amps
yaroslav
Post by yaroslav »
power on the wattmeter when overclocking karting about 5 kW
Been thanked: 1139 times
Nice work:)
yaroslav
Post by yaroslav »
The boards were developed for me according to my schemes, I didn't ask what program they were developed in, I can find out
Very impressive. Cool to see the Blue Pill getting used :)
kiwifiat
Been thanked: 12 times
Post by kiwifiat »
Nice job. I had a quick look at the schematic. My only comment would be that the output voltage from your current sensors will not be centered on 1.65v You may want to adjust the values of the voltage divider to get closer to the target 1.65v . I believe this is required by the STM32, maybe Johu could clarify if that is important? Without doubt accurate current readings are a prerequisite to good FOC or I guess if this is an induction motor it may not be relevant.
What motor are you driving with this inverter? I will be using a bluepill on an upcoming project so Johu please keep it as an option in the code base.
Pictures of you kart, motor, and controller would be nice.
kiwifiat wrote: Sat Feb 15, 2020 7:47 am Nice job. I had a quick look at the schematic. My only comment would be that the output voltage from your current sensors will not be centered on 1.65v You may want to adjust the values of the voltage divider to get closer to the target 1.65v . I believe this is required by the STM32, maybe Johu could clarify if that is important? Without doubt accurate current readings are a prerequisite to good FOC or I guess if this is an induction motor it may not be relevant.
Haven't seen the schematic, most importantly the reading must never go above 3V3. Offset calibration is automatic, so if offset is e.g. 2V and you still never exceed 3V3 you'll be fine.
yaroslav
Post by yaroslav »
The engine first used 90 dimensions, now put the engine with a combined winding type Slavyanka DA-90S, photos will soon do
kiwifiat
Post by kiwifiat »
Your current sensors look interesting. What mV/A do they output and what ferrite cores have you used?
yaroslav
Post by yaroslav »
Depends on the gap in the ferrite ring, I cut 7mm, designed for a phase current of 400a
https://www.chipdip.ru/product/ss49e?fr ... st_product
https://www.chipdip.ru/product/b64290-l618
kiwifiat
Post by kiwifiat »
yaroslav wrote: Fri Feb 28, 2020 4:41 pm Depends on the gap in the ferrite ring, I cut 7mm, designed for a phase current of 400a
Thanks for the response. What a great idea to build your own current sensors and at such a low cost :) The cheapest 400A current sensors I can get from Digikey here in Canada are $31.75 for one off and $20 for 200.
yaroslav
Post by yaroslav »
Only there is one inconvenience, you need to saw ferrite rings, very bad sawing, ferrite dust is very easy to get into the respiratory tract, you need to saw only with good ventilation, and preferably in a mask.
yaroslav
Post by yaroslav »
HI,
The photo my electric karting
joromy
Post by joromy »
Nice, like the recycled wood boxes.
Are you going to make wooden box for motor/inverter to.
Video pleeeease!! :D
yaroslav
Post by yaroslav »
Sounds angry :) How does it drive?
yaroslav
Post by yaroslav »
Good traction in this engine, I can not achieve a dynamometer key, but if it is already turned , the torque is high, breaks the cameras in the wheels :)
yaroslav
Post by yaroslav »
Hi everyone , I made some more videos
