Some may say, "it's not a real solution - it's just a crutch".
1971 GMCe Lexus GS450H BMW 530e Tesla Model S Electruck [Upgrade]
- lsh3rd
- Has thanked: 117 times
- Been thanked: 40 times
Re: 1971 GMCe Lexus GS450H BMW 530e Tesla Model S Electruck
- Gregski
- Has thanked: 500 times
- Been thanked: 946 times
- Gregski
on this episode we finally removetize the old BMW high bred 9 kWh battery pack
... and create a tripping hazard in our threeeee car garage
- Gregski
sometimes you have to take the little wins, like hanging up a shelf, am I right fellas ?
"Squint" from Tilt Construction LLC knocked it out in only a couple hours
- Has thanked: 370 times
- Been thanked: 222 times
Just so long as it doesn't fall of the wall first time you set a screwdriver on it.
- Gregski
in this video The Greg removes more stuff off of his electrically converted Chevrolet (pronounced: "GMC") pick up truck in order to be able to access the Lexus GS450h transmotor input shaft
well hopefully this is all that had to be removed...
- Uppertown
- Has thanked: 133 times
- Been thanked: 34 times
The shelf will be fine; the screwdriver will simply roll off and impale itself in one of Greg's batteries
- Gregski
- Gregski
new trans plate time - NTPT
- Has thanked: 403 times
- Been thanked: 260 times
Picking up the hand crank drill off of the drill press platter got me.
Seeing you trace out a pattern in the middle of the sheet had my hoarder's anxiety blaring a klaxon.
- Gregski
Ha ha, I appreciate that, as I went to 7 different Thrift stores looking for a "vintage" hand drill, only to find out my buddy Pontiac Mike had one but he lived all the way across town, so a joyful cross town trip later during rush hour, that beauty was mine.MattsAwesomeStuff wrote: ↑Wed Dec 04, 2024 9:39 pm Picking up the hand crank drill off of the drill press platter got me.
Best damned French film I’ve watched in years. Le Magnifique Le Greg
- Gregski
ha ha, thank you, and Rotten Tomatoes agrees
- Gregski
GMC Electric Truck Lexus Transmission Plate Improvements watch me improvetize my crappy aluminum plate using a $300 dollar steel template
please forgive a slight overlap with this other post you may find useful: GS450H Adapter Plate
- Gregski
Happy Holidays You All
- Gregski
so first attempt at locking out the input shaft was a small failure
below you can see the circumference of the circle I etched
below I raised the Ninja star about 1/2 an inch off the plate to make it sit further inside the bell housing and on the input shaft, this was still just for testing purposes
Will there be much torque on the plate or is the concern more about stressing the bearings if it's not perfectly aligned?
- Gregski
both, equally important I recon
- Gregski
after one too many sleepless nights The Greg made some significant progress on Rev. 2.0 of our input shaft mechanism, using this handy LDR 311 F-112 Galvanized Floor Flange, 1-1/2-Inch, complements of our friends in Vietnam, or as I like to call it the Lexus GS450h transmission plate too big of a hole reducer thingie
here it is as found in our local Ace Hardware store plumbing section
- Gregski
alright, I aint gonna lie to you, it's not a snug fit... yet ! but we got a solution for that
this gets us in the ballpark but it's not a snug fit, we can do better...
- Gregski
turns out a simple rubber band set was the secret weapon for perfect alignment
naturally the second one snapped off the shaft into oblivion during the photo shoot, so just picture two of them on here
- Has thanked: 379 times
- Been thanked: 1560 times
as my highly decorated professor once said: every fool can come up with a complicated solution, only true masters find a simple one
- Gregski
thank you... I think
- Gregski
did I mention I was tickled pink when I discovered OUR custom transmission crossmember was going to clear all North, South, East, and West boltuators
- Has thanked: 219 times
- Been thanked: 178 times
Thats a first for a rubber band aided fix that i've seen! Nice!
