Subaru Legacy AWD 2008, Leaf motor
Ruudi S
Has thanked: 29 times
Been thanked: 29 times
Post by Ruudi S »
This is my first all wheel drive car. Bought it because we have winters with snow and ice here. I am driving daily i-MiEV (RWD) or Leaf (FWD) and frequently feel that with one driving axle electric motor potential is not fully used. I have had a chance to try Jaguar i-pace, so I wanted and electric 4WD car for myself too.
The car was already without diesel boxer engine. Seller told me that this car was the first new diesel Subaru sold in Estonia. I want to give this car second life with electric power. Body is not bad, much better then my first car conversion. But I'll lift it up and then we'll see what I got. There are plastic covers on sides and under covers also, these need to be removed to see the real situation.
Buying decision was made when I saw here in openinverter forum two Legacy models that's conversion has been started. And I saw that these cars have electric power steering! This is very important since steering system changing is not allowed here. I will keep the original manual transmission to get it running like 4WD car should and attach first gen Leaf motor to it.
I haven't decided the way to build up the electrical system but I have full Leaf electric system in my garage with wiring and all the parts except battery. I have tried many months but not managed to get the Leaf harness and system to work yet. I am thinking of buying some 96S plug in hybrid pack for this project. I need to fit everything in engine compartment maybe onboard charger can be at the rear. Heating will be electric and webasto. Car was equipped with AC, someday may add leaf AC compressor also.
Here Chademo chargers are being replaced so the car needs a CCS fast charging system also.
Zombiverter would control most of the parts but does it handle the 2012 Leaf high voltage junction block
(actually it's called PDM power delivery module) and I got the answer from forum here:
viewtopic.php?f=17&t=5846
Re: Does the Nissan Leaf Gen 1 PDM work with Zombieverter?
Post by tom91 » Thu Dec 12, 2024 7:12 pm
It works with:
Inverter + Motor - Gen1, Gen2 and Gen3
PDM - Gen1, Gen2
Thank you tom91 for clarifying that!
Ruudi S
Re: Subaru Legacy AWD 2008, Leaf motor
Post by Ruudi S »
Today washed the car and lifted up for the first time. Under body plastic covers were broken and they carried a lot of sand. Some bolts didn't come loose and snapped. Removed the exhaust pipe I'll try to sell it, seems like its stainless steel so I don't know if anybody needs it.
In the summer I should sandblast the underfloor and stop the rust.
I'll find new used plastic covers.
Cut the clutch disk and got the center piece with spline for making the Leaf motor to subaru gearbox adapter.
Next I will try to fit the Leaf motor under the bonnet to see how to attach it to old engine attachment place.
Ruudi S
Post by Ruudi S »
Trying for the first time how the Leaf motor fits
Motor and gearbox shafts are touching but there's still a gap. I'll make a adapter plate from steel about 14mm thickness. Motor position in this car is strange it's not horisontal and a lot of room is wasted under the motor but what to do, under there is very bad place for anything. Our roads in winter time are salty muddy and sandy. I'm thinking maybe adding somekind of frame and adding a few Leaf original motor mounts in addition to subaru original mounts. Then it would be easier to attach all the other parts like AC compressor, Leaf HV junction block, inverter, on board charger and so on.
maland2
Post by maland2 »
Sweet build! I'll be following along since I'm also considering converting my '06 Outback. It sounds like you're planning on packaging the battery under the hood which makes sense, I've been struggling with figuring out how to package the modules in my build. Do you have any plans for active battery heating to allow charging below ambient? I saw you mentioned webasto, are you planning on using one of their coolant heaters like this? https://www.heatso.com/webasto-thermo-t ... truck-kit/
Good luck with your build!
Ruudi S
Post by Ruudi S »
maland2 wrote: Tue Mar 18, 2025 5:08 pm Sweet build! I'll be following along since I'm also considering converting my '06 Outback. It sounds like you're planning on packaging the battery under the hood which makes sense, I've been struggling with figuring out how to package the modules in my build. Do you have any plans for active battery heating to allow charging below ambient? I saw you mentioned webasto, are you planning on using one of their coolant heaters like this? https://www.heatso.com/webasto-thermo-t ... truck-kit/
Thanks, I don't think I can fit the battery under the hood. At first I plan to use small cheap hybrid battery like bmw hybrid 10kWh and fit it in the boot. This is for getting the car just to drive and get it registered. Then I'll see what's available at the time and see what can be done.
Under the bonnet will be: motor, inverter, electic and fuel heater, onboard charger, AC compressor, high voltage junction block, vacuum pump.
I hope I don't need to heat the battery it heats when charging at night and also when driving. When that's not enough then I'll deal with it, maybe some electric floor heater cable or leaf battery heater elements?
Yes webasto or eberspaecher, I am using them in my daily electric cars (i-MiEV and Leaf) fuel heater at cold wintertime. One has diesel heater other has gas heater and I like gas heater, I don't like diesel heater smell and oily hands when adding fuel.
I'll add nissan leaf original electric coolant heater also for preheating when car is plugged in or the wheather is not so cold or at shorter trips. Would like to control it with OVMS app.
This winter I drove a few times 2006 Outback it was automatic and 2.0 petrol engine, it was amazing in the snow. But I didn't like the visits to gas station. Very expensive to drive 10 litres per 100 km. But difference with my car is that it didn't have electric power steering rack.
Does your car have electric power steering? My diesel had.
Has thanked: 176 times
Been thanked: 368 times
I have adapter plates for this, but if you want do them your self have the files posted
Ruudi S
Post by Ruudi S »
Bratitude wrote: Fri Apr 18, 2025 12:35 am I have adapter plates for this, but if you want do them your self have the files posted
Thanks I'll memorize your offer If I cannot make those plates myself. I have CNC plasma table at work. I am not sure if plasma is good enough accuracy for this kind of work but I'd give it a try. I use half of the leaf reducer case and also the reducer small input shaft with its splines.
Scubascooby
Post by Scubascooby »
Leaf stack was in my original plans (still haven't done anything) but now I am looking at using the Crosstrek plug in hybrid transmission.
I am still thinking of using Leaf batteries due to the variety of module sizes. Some under the bonnet, some in the fuel tank space and some in the spare wheel well.
Project: EV Subaru Legacy estate diesel
Ruudi S
Post by Ruudi S »
Now that the schoolyear is ending I have done a few things on my Subaru.
My colleague changed rear boot lid, with students, old one was veru rusty, fortunately I got other one just the same color and rust free!
Cut off the differential part from the leaf reducer case half.
When testfitting it I found out that I have to rotate the motor 90 degrees.
Seems to be fine, cooling pipes seems to be ok and even the AC compressor should go onto the original mounts on the motor.
at the moment I am testfitting the motor these thin plates are only for testing that I cut with CNC plasmacutter. CAD drawings were made with my students with whose help we prepared the g-code files for plasmacutting with Swift Cut plasmatable.
view from bottom
I think I need to make rear support also for the motor but there's not a strong place to attach it.
Ruudi S
Post by Ruudi S »
Now need to work on the spline shaft coupler things
Ruudi S
Post by Ruudi S »
I made the coupler from Leaf reducer part where I had to cut input shaft shorter and turn a space for subaru clutch disk center piece
welded them together
thats how it looks on the subaru gearbox
Ruudi S
Post by Ruudi S »
I made a lasercut cardboard template to see if measurements are ok.
plasmacut the spacer out of 10mm steel
and that's how it looks
