Rev 3
zippy500
Has thanked: 100 times
Been thanked: 7 times
Rev 3
Post by zippy500 »
Is there a BOM for the rev 3 board ?
dima
Re: Rev 3
Post by dima »
*** Unofficial *** 8-)
https://github.com/dimecho/Huebner-Inve ... board7.csv
Please give feedback is something is off.
zippy500
Re: Rev 3
Post by zippy500 »
many thanks will take a look,
is it feasible to build this board ( I wish I had the money to buy a pre build one to support the work) I have limited EE skills :(
damian.lo
Re: Rev 3
Post by damian.lo »
According to BOM from link above I have question. I want to connect this board to Leaf inverter+motor via Johannes interface board, so which resistors should I populate in group R40-R43, where is speed selection?
Another headache are R50-R51 - I think depends of which current measurement I have. In case of Leaf inverter I think I should populate them, correct?
dima
Re: Rev 3
Post by dima »
A more official link if here https://github.com/jsphuebner/inverter- ... rdv1.1.pdf
If you need 17.6kHz PWM then R40-R43 follow the drawing
damian.lo
Re: Rev 3
Post by damian.lo »
Thanks for updated link to schematic.
:) Do I need 17.6kHz PWM now is question. Really sorry for my ignorance, but really I don't know if for stock Leaf resolver in motor from Leaf, should I take higher or lower PWM and which is better in my situation. Maybe someone with already soldered board can look at board and write what have on board?
Instead of this maybe can someone explain differences in user condition?
Thanks and regards.
Re: Rev 3
The Leaf inverter should be operated at 8.8kHz. At an earlier stage I thought it had to be 17.6.
With the latest software the excitation frequency is decoupled from the inverter frequency. It is now always 4.4kHz. So the values denoted in the schematic (0.51, 10k, 3k3) are what you want.
damian.lo
Re: Rev 3
Post by damian.lo »
Thank You Johannes for support with my doubts. I hope I will finish this board at next days, so I will do some trials.
damian.lo
Re: Rev 3
Post by damian.lo »
Hello again,
Today I finished soldering v3 board and after power on ofcourse board doesn't work :) PWR led isn't working, so I checked voltages and both VCC-5V and VCCIO-3,3V are about 1,2V.
On beginning I had D1 and D2 B540C, then I replaced them to 1N5819, because now I can't obtain CDBA540-HF. For now also C20-470uf/16V I left normal thrue hole version. It can be some problem with this power supply or somewhere else? Any other part isn't hot/smoked/etc so can be, that LM2596 is broken?
Re: Rev 3
I think there is a short somewhere, can you check 3V3 and 5V against GND with ohms range?
damian.lo
Re: Rev 3
Post by damian.lo »
Here are measurements:
GND-VCC=640R
VCC-GND=470R
GND-VCCIO=594R
VCCIO-GND=420R
Re: Rev 3
Similar values on mine. You can remove the 3V3 reg and see if 5V are stable.
damian.lo
Re: Rev 3
Post by damian.lo »
The same, VCC output 1,2V without IC8 3,3V reg.
Can You check on Your board R11 (in resolver mode) resistance in both directions?
On mine is:
VCC - JP2-2= 550R
JP2-2 - VCC= 312R
On C20 cap are: 650R/160R
Edit 11.01.2019:
What a shame with voltage regulator LM2596 :)
Today after big investigation what is wrong I discovered what I exactly ordered from Farnell - it was LM2596-ADJ instead of LM2596-5
Good, that the output voltage was 1,2V and not 12V, otherwise will be a little mess.
So, now I'm waiting for next parts delivery and then I will try with this - thanks Johannes for Your time in search of my error.
One more day with this mystery and probably I will also take already soldered version from JLC.
Regards
