To start this I want to check the rest of the system. So I selected the outlander charger for now. Planning to use the outlander code as base for the MG ZS charger.
I checked out the zombie code and as far as I can tell it should enable the EVSE and send AC to the charger and enable the HV. Without the charger communicating with Zombie?
Used the ConfigFocci function on Zombie to set up the Foccci. Foccci is on firmware : 0.42.76.B as it came from the OI shop.
Zombie is on firmware : 2.22.A
In the spot values the EVSE current limit is correct and updating when I change the setting on the EVSE.
Also have the CPspoof set on the Zombie and it works fine, duty cycle changes with the EVSE setting.
Found some things that are off but don't know if this is a problem:
- Cablelim and PilotLim are the pilot limit(Cablelim is not used currently I think)
- MaxTemp is mapped in the Foccci but the Zombie code labels this as ChargePort_Plug
- the AcOcbState and AllowUnlock CAN maps overlap
