Which board is better to use?
Taichi
Post by Taichi »
Hello. I have a task to create an electric buggy. I want to use the native battery and inverter from the nissan leaf 1 gen. I need a slow charging function from the native connector and about 50 kW of power on the engine. Which of the boards can use these functions? Please do not be angry, I am new to this forum and I use a translator to communicate with you. Thank you
LRBen
Has thanked: 77 times
Been thanked: 220 times
Re: Which board is better to use?
Post by LRBen »
Zombieverter board will work for that just fine. Plenty of documentation on here and the wiki as well for running a leaf setup.
maiks
Has thanked: 7 times
Post by maiks »
LRBen wrote: Thu Jun 12, 2025 6:49 pm Zombieverter board will work for that just fine. Plenty of documentation on here and the wiki as well for running a leaf setup.
get more details about Zombieverter here viewtopic.php?t=4934
Has thanked: 176 times
Been thanked: 369 times
There is no controller available that will run the gen 1 Lea on board charger.
The zombiverter will run the gen1 leaf motor+inverter
And dose CHAdeMO
but dose not run the gen1 leaf charger
Has thanked: 209 times
Been thanked: 572 times
Bratitude wrote: Tue Jun 17, 2025 4:25 am The zombiverter will run the gen1 leaf motor+inverter
Where you getting this info from? I do not believe this to be the case.
Has thanked: 413 times
Been thanked: 118 times
Post by Jacobsmess »
tom91 wrote: Tue Jun 17, 2025 6:41 am Where you getting this info from? I do not believe this to be the case.
I vaguely remember one of Damiens videos on the stack mentioning something along the lines of this. May well be legacy information.
