Marat wrote: ↑Fri May 31, 2024 7:20 pm
I modified the firmware of the BMS unit of all generations of Liaf, chip 70F3236 70F3382, in order to expand the range of their operation to the required battery parameters, the most popular CATL 115Ah 120Ah 180Ah..., there is an example of standard BMS30 firmware adapted for BMS24 (3NR4C_BLINK-OFF.kwp).
hello ,
Thanks for sharing . Am kindly requesting for 63kw firmware or a link where l can download it
You can only purchase a pre-programmed LBC module of all Leaf(Gen1-Gen3), with a pre-agreed battery power, the price is the average price of LBC + $150.
Marat wrote: ↑Mon Feb 17, 2025 7:45 am
I have a 30kW BMS. Would it be possible for me to send it to you for an upgrade to 64kW?
FYI current sensor pinout for 62kWh nissan leaf BMS is different from that used for 40kWh.
I measured the continuity directly from current sensor harness to the bms harness. Note. in the middle there is another harness entering in the junction box where the current sensor is located.
the result pinout is:
1->10
2->9
3->15
4->11
