Used ZK-PP1K from E-bay to generate the PWM I fed into the TI Signal of the cluster. Must have RPM showing a value, and also the speedo must have some value on it. I have not quite worked those 2 bits out, but all they do is disable or enable the economy meter from working.
Please see the excel spreadsheet to show the PWM % variation at 500Hz vs Litres/100km displayed. It is quite linear. Tried at 200 Hz but the meter became very sensitive. So prefer 500Hz value. This meter will be able to display energy consumed / 100km, or power consumed / 100km. (I think energy is better). It appears that if RPM meter reaches 1500 RPM, the economy meter is enabled. If the RPM meter falls below 1200RPM, the economy meter is disabled. Meter has to go back to 1500RPM before the economy meter will be enabled again. Only thing, I don't know what the threshold is for the speedometer, so I am going to install 3 of these ZK-PP1Ks, so I can work that out too.
I would like to use this with the zombieverter ECU
