I'm going to install an Nissan EM57 AZEO motor om my boat.
I cant get valid connection of resolver to Open Inverter board.
8 pins of resolver -R1,R2,S1,S2,S3,S4 temp1, Temp2.
on the board I have 4pins + 2 temp pins
temp+, temp-, to temp1, temp 2 on board, here is clear
R1 resolver pin to ENC_IN_Z/RES_R1
S2 resolver pin to ENC_IN_A/RES_S2
S3 resolver pin to ENC_IN_B/RES_S3
R2 resolver pin to? nowhere? to GND?
S1 and S4 conected together and to ENC_5V/RES_S4S1, Should I also add 5dc volts here?
