So long time readers will know I've been working on a new robotics platform, and finally have the software all packaged up, and one of the extensions I created it for first was OpenInverter
If you have an esp32s3 (or P4) lying around with a CAN interface, you can now install it with one click
If you are interested in other CAN bussy apps like Dalas Battery Emulator etc check out the Extensions hub where you can load others
Give it a go and let me know in the comments how you get on!
OpenInverter UI, One click install
- Has thanked: 330 times
- Been thanked: 848 times
Re: OpenInverter UI, One click install
Would it be possible to set one up for the ESP32 (Wemos) serial interface used directly on OI boards?
- Has thanked: 91 times
- Been thanked: 517 times
I also would like to know how to add projects to this
- jetpax
- Has thanked: 20 times
- Been thanked: 37 times
hopefully most of what you need to create any apps for the platform should be in
https://scriptostudio.com/docs/
“Take the best that exists and make it better”
- jetpax
@tom91 IIRC I had some library install error compiling for esp32 and couldnt be bothered to fix it, as i consider them basically obsolete haha
S3 (and P4) are so much better, esp security wise
bear in mind the platform supports a lot more than just OI eg
https://pycoclaw.com
but will take a look
