Nissan Leaf and Zombieverter minimum components need?
Topics relating to the ZombieVerter VCU
Taichi
Has thanked: 9 times
Re: Nissan Leaf and Zombieverter minimum components need?
Post by Taichi »
Hello. Need some information about maximum RPM EM57 Engine. I added 2 reductors from rear audi axis, wonna make AWD. But it multiply reduction ratio. Need RPM near 16000 RMP. Anyone run EM57 with 16K RPM? Thx for answer.
Has thanked: 246 times
Been thanked: 469 times
common info thats easily found.
10500rpm, e+ leaf goes to 11330rpm.
Any faster are bearing speeds start to exceed and rotor may start to expand.
blasaab
Post by blasaab »
Hi i have a board with this missing components. can someone tell me what component to skip on leaf setup.
Has thanked: 330 times
Been thanked: 848 times
What else are you going to control? what pins will you use?
Just fit all and not restrict yourself.
blasaab
Post by blasaab »
I dont have those component and dont know what they are for. i can order later and fit but now i want to test my leaf motor/inverter without some off this components.
J0hannes
Has thanked: 21 times
Been thanked: 182 times
Post by J0hannes »
You have on your list parts from modules: power supply, Can3, RS232, LIN bus, Digital outputs and some others.
At least if you don't have any of those power supply related components you listed, you can't use the board at all.
https://github.com/damienmaguire/Stm32- ... ematic.pdf
If it helps, you can look from the scematic yourself, what goes where.
blasaab
Post by blasaab »
J0hannes wrote: Wed Mar 11, 2026 7:21 am You have on your list parts from modules: power supply, Can3, RS232, LIN bus, Digital outputs and some others.
Thanks Johannes that helped
