Parameter settings for ADA4571 amr encoder
Adrianbb
Been thanked: 6 times
Post by Adrianbb »
Hello, I searched a lot, but I didn't find any clear answer to my question. I´m running sine OI firmware and have ada4571 amr encoder. I'm not sure how to set correct parameters.
https://www.analog.com/media/en/technic ... DA4571.pdf
It have two sine waves per 360° revolution. Output amplitude is 0,875V - 2,545V, so mid point is 1,71V and sincos offset is set to 2122. I think that is ok.
Encoder set to sincos, but what about resolver pole pairs? If here are two sinewaves per revolution, then correct setting is 2?
Thank you.
Been thanked: 1913 times
Re: Parameter settings for ADA4571 amr encoder
Adrianbb wrote: Mon Mar 16, 2026 9:08 am If here are two sinewaves per revolution, then correct setting is 2?
yes
