Page 5 of 13
Posted: Tue Feb 02, 2021 12:01 pm
Thought about this. if you read the can back from one of the charger modules it tells you the max mains current. gen2 = 16A and gen3 = 32a if I'm remembering.
Posted: Tue Feb 02, 2021 12:18 pm
That would be great. Do you know where in the CAN stream?
Posted: Tue Feb 02, 2021 6:25 pm
0x207 is the module 1 line status message. Available line current is in bits 32 to 40 as a 9 bit unsigned int with a scale of 0.06666. On the gen3 this will report as a little under 24A at power up and around 13 A on the gen 2 at power up.
Posted: Tue Feb 02, 2021 9:01 pm
Great!
I continuously sample that message now, can you check for a valid value in "hwaclim"? It will read a little (like 7%) low due to the limitations if the scaling capabilities of stm32_can. I also realized that the scaling of cXiac was off, fixed now.
What is the max DC current of the gen3 charger? I found 18000/400 still yields 45A.
EDIT: just tested on my GEN2 charger, it displays 15A and with the 7% scaling error that is 16A
Posted: Tue Feb 02, 2021 9:05 pm
by Bryson
johu wrote: ↑Tue Feb 02, 2021 9:01 pm
That explains what I was seeing, thanks! Good catch.
Posted: Wed Feb 03, 2021 3:22 pm
Also thought about the low voltage problem, i.e. using the charger with <200V batteries. The problem is that it will send 3.7 kW to the secondary side which results in 18A i.e. more than 15A of DC current. Now I could enforce a per-module DC current limit to make sure the DC current never exceeds 15A per module.
Posted: Sun Feb 21, 2021 1:35 am
by Bryson
So I uploaded the latest firmware and gave it another shot. The AC current per phase (cXiac) is now scaled correctly, but it looks like hwaclim and/or aclim changes are preventing me from getting full juice. I'm only getting 5A per phase max.
I started a session with the old firmware, updated firmware, and now I'm stuck at a max charge of 15A AC.
Posted: Mon Feb 22, 2021 2:17 am
by Bryson
One more thing for Johannes - based on what I'm reading in the description of Type 1 and Type 2 settings, the charger will always enforce a maximum AC current of 32A, even if the EVSE is telling it that it can do more. Is that correct? My EVSE regularly puts out a full 40A with other EVs, Tesla and otherwise, so I'm not sure this interpretation of J1772 single phase is 100% correct. Am I reading it wrong? Should cablelim just be set to whatever the evselim is?
You'll notice that with the 'old firmware' in my image above, the EVSE is putting out just under 8kW. At 240V, that's about 32A total, curiously equal to cablelim.
Here is the same charger, cable, EVSE on the 'pre-Johannes' firmware running at 40A (@240V = 9.6kW):
edit, last thing: I made a window in the charger case and covered it with a layer of kapton, this definitely improved my WiFi:
Posted: Mon Feb 22, 2021 7:18 am
Understood, will make some changes and let you test
Posted: Mon Feb 22, 2021 1:13 pm
by jon volk
Bryson wrote: ↑Mon Feb 22, 2021 2:17 am
There are similar range issues with the wifi module buried under the LDU case. I use this in an enclosure with automesh. It functions transparently and I can connect 10' away from the car.
https://github.com/martin-ger/esp_wifi_repeater
Posted: Mon Feb 22, 2021 1:27 pm
Here is a new firmware that should fix the low current limit.
Posted: Mon Feb 22, 2021 3:15 pm
by jon volk
Did you happen to change the SDO message ID to prevent collisions with inverter boards on the same bus?
Posted: Mon Feb 22, 2021 3:31 pm
by Bryson
johu wrote: ↑Mon Feb 22, 2021 1:27 pm
Thank you again, I’ll give this a go as soon as I have another window of time, hopefully an evening this week.
Posted: Mon Feb 22, 2021 3:49 pm
jon volk wrote: ↑Mon Feb 22, 2021 3:15 pm
Ah forgot, will hard-code it to 5 (i.e. 0x505) next time.
Posted: Sat Feb 27, 2021 5:48 pm
by Bryson
Well gents, I learned something this morning!
1. New firmware works great, thank you Johannes! I charged up to 37A, limited by constant voltage charge (EVSE does 39.4)
2. The Tesla charger doesn't like more than 420V set point. It looks like this may have been my issue. I played with different values and was able to quickly reproduce the cycling issue. I'd suggest limiting the max values at 420V instead of 430V based on this learning.
Note that this testing was done purposely in the constant voltage range of charging to attempt to trigger some of the high voltage cycling issues I've been seeing, nothing here is in the lower SOC constant current range.
Off to the office now...
* these should all be VOLTS not AMPS. Oops
Posted: Fri Mar 05, 2021 6:50 pm
Thanks! I guess I will make this the new version then. While also dropping max voltage to 420V.
Posted: Sun Mar 21, 2021 8:16 pm
by Boxster EV
Thought it was about time I moved over to this gig.
I've had my free five mins of juice and just purchased a pin.
Posted: Sun Apr 04, 2021 3:31 pm
by jon volk
Question on the CAN control. Does the charger need to receive a full array of data for a 0x102 rx message or is it fine just receiving a 1 or 0 on byte 4 for enable? Does this message also override or act as a replacement for the hardware enable wire? Working on reducing hardware i/o for anything that can be done over CAN.
Posted: Sun Apr 04, 2021 4:28 pm
You'll need to send all items except SoC as they'd be set to zero otherwise. Could certainly remove the enable wire in that case but currently it is required.
Posted: Fri Apr 09, 2021 5:57 pm
I did some testing today to control the charger via CHAdeMO protocol and realized and reports "Connector locked" and "enabled" bits in the wrong byte (Byte 4 instead of 5). Concerns message 0x109. Have updated the
wiki
I will change it in the next release, be aware you need to change your custom VCUs should you upgrade your charger from version 1.06.R or earlier
Posted: Fri Apr 09, 2021 6:19 pm
by jon volk
On a side note, I've had no issues in 2.5 months of usage on my own charger as well as various public J1772 charge stations.
Posted: Fri Apr 09, 2021 6:28 pm
Very good to know!
Posted: Wed May 05, 2021 6:19 pm
As you might have seen
here I'm using a Gen2 Tesla charger as CHAdeMO EVSE. I had to make some small changes to the software to make it work:
- Fix the 0x102 message (enable bits now start at bit 40, not 32)
- Added an "enablepol" parameter to start charging when the enable pin is LOW
Internally I added a pull-up resistor to the enable pin. You can also use this parameter to skip the enable pin all together. Try it, pin stays valid over all future upgrades.
EDIT: when I say "make it work" I only made changes that I anticipated. Actual test is tomorrow.
Posted: Thu May 06, 2021 10:53 pm
by EV_Builder
Which board version does it support and if you don't have the wifi module, will it spit out over COM native or COM USB?
I have a fast flashing LED but nothing more/less..
Posted: Fri May 07, 2021 6:47 am
Both interfaces work, just no update over USB possible. Works on all STM32 based hardware, gen2 and gen3
https://openinverter.org/wiki/GEN2
Oh, my CHAdeMO test didn't go well, it turns out I have a super charger charger
