That's awesome, many thanks. Some more digging and the best Google term seems to be "stand off insulator".
I've currently resorted to cutting out big chunks out of whatever my fuses were originally mounted to - these insulators are a much better solution!
It's funny how similar our projects have turned out - I'm also using a Tesla Gen3 charger in the same location, but I've gutted the end of it that has the supercharger PCB/contactors and am using that as the junction box for my 320V bus. I'm also using the TRW PAS pump, and it looks like the same vacuum pump.
Do you have more info on that (or pics)? That is a very good solution to make everthing appear OEM to evade the EMC testing when converting the car from ICE to EV with the authorities.
Re: The SuperYacht BMW E65 7 Series
Posted: Tue Feb 25, 2020 11:55 pm
by xp677
I have not published information on that yet. And now I feel that doing so may be a bad idea. I do not wish to publish Information which would be used explicitly to circumvent such testing.
However the procedure is as described. Remove the parts which you do not need and replace with those that you do.
It looks like Damien has kept his charger intact, so this discussion is not relevant in this thread.
Posted: Wed Feb 26, 2020 7:39 am
by Bentto
xp677 wrote: ↑Tue Feb 25, 2020 11:55 pm
Hm, that is indeed a good point. Thanks for the reply anyway
Posted: Thu Feb 27, 2020 10:00 am
by Kevin Sharpe
Top balancing the test battery today... here's the rear pack
Posted: Thu Feb 27, 2020 8:04 pm
by Kevin Sharpe
mattndex@gmail.com wrote: ↑Sun Feb 23, 2020 2:49 pm
Is there a chance of you posting a schematic of how the high voltage junction box is wired.
The participants on next weeks course are building a HVJB for the Grey Goose project. It will be very similar to that used on BEXUS. I'll ask them to document the build and post details in that thread
Posted: Sat Feb 29, 2020 3:39 pm
by Jack Bauer
Front of the car all back together. Next up wiring in the V2 VCU with Wifi and ISA Shunt interface.
Posted: Tue Mar 03, 2020 5:32 pm
by Jack Bauer
V2 VCU and isa can shunt up and running in the bexus. VCU now controlling precharge, startup and shutdown as well as hv control during charging. WiFi interface works perfectly.
Posted: Wed Mar 04, 2020 10:07 pm
by slow67
RE3Rotor wrote: ↑Wed Feb 12, 2020 11:05 pm
I did notice mine has 2 drive positions on my gearbox. I would love to know if it is as easy as just connecting the shift lever so I can manually switch to the second location.
It may be possible to wire it up this way. Ive done it for other electronics transmissions in the past.
Posted: Thu Mar 05, 2020 6:35 pm
by Jack Bauer
Posted: Thu Mar 05, 2020 7:19 pm
by Jack Bauer
Weigh in for the GS450H transmission.
Posted: Thu Mar 05, 2020 8:14 pm
by Sloth
Oops, I'm waiting for the gearbox to be delivered, I need a crane to move it ...
