Page 5 of 7
Re: Ebay Auctions Of Interest
Posted: Sun Dec 06, 2020 5:52 pm
4markowen wrote: ↑Sun Dec 06, 2020 5:16 pm
https://www.ebay.co.uk/itm/BMW-2-SERIES ... 3198741222
Series 2 PHEV Rear Differential for £399 on eBay.co.uk. Nice transverse arrangement. Appears to also be found in the Mini Countryman PHEV too, but they're a bit younger and more expensive, but probably more popular and more coming down the line. Couldn't find anymore tech specs other than mentions of power when in electric mode only.
Should deliver about 88hp / 165Nm
I seem to pickup rumor this motor is the same as the one in I8. So performance motor offers should be the same, its the inverter that is derated.
https://www.autoblog.com/2009/08/29/fra ... frankfurt/
Posted: Sun Dec 06, 2020 6:00 pm
by 4markowen
The articles I read about it suggest that it is the same as the i8, but with everything turned down. The ICE primarily.
Perhaps we could turn things back up
Posted: Mon Dec 07, 2020 2:11 pm
by Bigpie
UK Ebay 2018 BMW 5 Series G30 Hybrid With Gearbox Inverter High Voltage Hybrid Battery
https://www.ebay.co.uk/itm/2018-BMW-5-S ... 3866919557
Buy it now £3k
Starting Bid at: £1.5k with 7h left.
Posted: Mon Dec 07, 2020 3:13 pm
Here is a good battery from Volvo V60 WITH 3kw eltek charger!
https://www.befr.ebay.be/itm/303632669738?ul_noapp=true
Posted: Wed Dec 16, 2020 2:12 pm
by MiBa
Hello,
found some affordable Tesla Chargers @ ebay Kleinanzeigen.
150EUR each.
Parts located in the Netherlands
a) Model 3 PCS (the „Penthouse“)
https://www.ebay-kleinanzeigen.de/s-anz ... 2-223-1182
b) Model S/X
https://www.ebay-kleinanzeigen.de/s-anz ... 4-223-1182
Regards
Michael
Posted: Thu Dec 17, 2020 1:50 pm
by FJ3422
I had contact with that guy, he's at a few kilometers from here. Seems to be scrap / RMA goods, most likely all defective.
Posted: Sat Dec 19, 2020 9:51 am
by Alibro
Renault Zoe with a very low starting price. Not charging so may be an easy fix or a good parts car
https://www.ebay.co.uk/itm/RENAULT-ZOE- ... 1438.l2649
Posted: Sat Dec 19, 2020 12:35 pm
Known faults or issues:
Very Low Battery
Charging issue – Wont charge
That means BMS error or one or more cells went to the low end. Battery could still be good for manual charge...
Or one could just take the car and fit their own battery to the box... It seems a waste to just break the car apart...
Edit: Ok the steering wheel is on the "right" side so...
Posted: Wed Dec 30, 2020 6:45 pm
by jnsaff
FJ3422 wrote: ↑Thu Dec 17, 2020 1:50 pm
I got both from the guy and the Gen 3 had all 3 chargers light up with 12v applied to it according to the instructions in Damiens video. It’s an EU version and the Tesla seal had not been broken AFAICT. So it’s not a complete lemon and once I get the board from Damien I’ll report back about my progress.
The M3 PCS looked a bit more beaten up, I have not connected power to it yet but once I know more I’ll report back as well.
Posted: Mon Jan 18, 2021 9:59 am
by jnsaff
There is an ebay vendor in Los Angeles area that has lots of very interesting items available for EV Conversions, including ISA shunts and contactors.
I have bought from him in the past and he has never failed on these purchases.
I would suggest check him out but coordinate here so forum members will not start bidding against each other.
The items listed are here:
https://www.ebay.com/sch/6scooter13/m.h ... pg=&_from=
Posted: Thu Jan 28, 2021 9:04 pm
by clanger9
Posted: Sat Feb 13, 2021 11:37 pm
by Bratitude
Posted: Sun Mar 07, 2021 7:30 pm
by FJ3422
Chevrolet Volt / Opel Ampera on board charger in the UK:
https://www.ebay.com/sch/i.html?_from=R ... 5&_sacat=0
Posted: Thu Mar 11, 2021 6:32 pm
Posted: Thu Mar 11, 2021 9:01 pm
by Alibro
https://www.ebay.co.uk/itm/VW-E-Golf-35 ... fresh=true
Anyone know how easy these are to break up and reuse in an EV project? I wouldn't want to make an offer on it and find the cells are impossible to remove.
Thanks.
Posted: Tue Mar 16, 2021 8:00 pm
by Alibro
Sorry to be a pain guys but I'm seriously considering buying this pack as it is so close to me and seems a reasonable price.
Can anyone advise if I will have issues charging, discharging and balancing the Samsung SDI cells?
Posted: Tue Mar 16, 2021 8:42 pm
by Bigpie
I have the modules from a Golf GTE, I know both the passat and golf modules cannot be balanced as of yet.
I think the passat has Samsung cells, the bms slaves respond to the same wakeup command as the slaves on the Panasonic cells I have.
https://github.com/Tom-evnut/VW-bms, I've not seen any mention if it'll work with a E Golf pack,
If you do for for it, please do document on the wiki, rstevens and myself have been filling in as much as we can find on our respective packs, under the volkswagen section.
Posted: Tue Mar 16, 2021 9:10 pm
by Alibro
Bigpie wrote: ↑Tue Mar 16, 2021 8:42 pm
If using the slave modules that come with the pack is not an option then is it is possible to bypass them and use a different BMS.
I had planned to use a Leaf BMS with the rest of the leaf running gear I have. I know they have different numbers of cells but I was hoping there would be ways to get past this.
Posted: Tue Mar 16, 2021 9:41 pm
by Bigpie
Take a look on the wiki, if the modules are the same it would be possible to use a 3rd party bms, each terminal is very easy to access.
You can reuse the slaves, at least for the GTE packs, for cell voltages and temperature, it's just that the balancing hasn't been figured out and shared.
Posted: Tue Mar 16, 2021 10:27 pm
by Alibro
Bigpie wrote: ↑Tue Mar 16, 2021 9:41 pm
Thanks Bigpie.
I started a new thread in the VW section to continue this conversation.
viewtopic.php?f=24&t=1498
Posted: Fri Mar 19, 2021 9:56 am
by joromy
Lots of Eltek 3kw chargers, have used some of them, they are CAN bus operated.
100-250VAC input 250-420VDC output.
Now they are really cheap!
https://www.ebay.com/itm/164764289269
Posted: Sat Mar 20, 2021 7:50 am
by FJ3422
Cheap Chevy Volt gen2 DC-DC converter in de US
https://www.ebay.com/itm/333869667767
Posted: Sun Mar 28, 2021 9:11 pm
by deanusjack
Not ebay, but noticed some wallbox charge points on bidspotter UK. If you've not used before, unlike ebay there are auction fees and vat ontop so make sure to check the terms and conditions
https://www.bidspotter.co.uk/en-gb/auct ... cm-au10465
Posted: Sat Apr 03, 2021 11:48 am
by Bigpie
4 x Outlander chargers £190 each or best offer + £30 postage
https://www.ebay.co.uk/itm/2014-2019-MI ... 4409561020
Posted: Wed Apr 07, 2021 2:12 pm
by DarkwingDuck
Chevy Volt gen2 MSE718 DC-DC for $100
Only ships within USA, sadly
https://www.ebay.com/itm/2016-2019-CHEV ... b#shpCntId
