The ZombieVerter VCU Project
Locked
Has thanked: 12 times
Been thanked: 350 times
Oh yeah does anyone have any pinouts for the gen 3 prius resolver connector plugs by any chance?
mdrobnak
Post by mdrobnak »
Jack Bauer wrote: Thu Jan 14, 2021 5:44 pm I'm on Ubuntu 20.something:)
Hopefully try and get some prius gen3 action and E46 / Leaf inverter testing over the weekend.
Interesting! I'm on 20.04 as well, and yet `make get-deps` was all busted for me.
If you get those two going you'll be pretty good to go, rather quickly I might add.
-Matt
I think its busted because I didn't do the Johannes magic linking thingy with his repo.
Dilbert
Post by Dilbert »
I tried to build the stm32-vcu code earlier but ran into an issue, I believe it didn't build openlib. I'll be looking at it in the morning as I want to make the Prius changes.
mdrobnak
Post by mdrobnak »
Ok, I'll make a branch with the code re-org'd a bit and with git submodules called submodules_and_split. You should be able to work off that.
I'd also recommend Damien check it out fresh and try it:
git clone <your clone url> stm32-vcu-with-submodules
make get-deps # should do all the heavy lifting.
Note this is not done yet and won't be until about Midnight UTC.
-Matt
jon volk
Post by jon volk »
Just touching back on the hardware, JLC seems to be out of STM32F105RBT6s, they alternatively do show these available.
https://jlcpcb.com/parts/componentSearc ... 32F105RBT6
Has thanked: 380 times
Been thanked: 1570 times
Thats funky, quick skim over data sheet makes it look like a Chinese copy of the STM32.
Also noticed the STM32F103 is now a basic part but it costs 5 times as much as the GigaDevices part.
jon volk
Post by jon volk »
Ive been reading issues of STM32 supply with a global backlog. Prior to today, I’ve never heard of Gigadevice, but they could be a potential alternative. I’m not sure I’d risk my inverter on one just yet.
mackoffgrid
Has thanked: 6 times
Post by mackoffgrid »
jon volk wrote: Thu Jan 14, 2021 8:57 pm Ive been reading issues of STM32 supply with a global backlog. Prior to today, I’ve never heard of Gigadevice, but they could be a potential alternative. I’m not sure I’d risk my inverter on one just yet.
I've been watching the cost of stm32F103s go up with each order :(
STM32 supply has gone haywire. PITA. Gigadevice is probably the best of the STM copycats. I'd rather pay the extra for a inverter controller :)
Atmel supply is fine :?
mdrobnak
Post by mdrobnak »
libopeninv has some local mods by Damien so not touching that folder yet.
However, make get-deps does now work.
I have also enhanced it such that make get-deps is no longer needed. :) It will automatically build things in the right order.
Working on splitting things now.
mdrobnak
Post by mdrobnak »
Please test this branch:
https://github.com/damienmaguire/Stm32- ... _and_split
git clone -b submodules_and_split https://github.com/damienmaguire/Stm32-vcu.git VCU_TEST_DIR
cd VCU_TEST_DIR
make
Flash and test.
If that's happy, then please merge https://github.com/damienmaguire/Stm32-vcu/pull/5
Then merge: https://github.com/damienmaguire/Stm32-vcu/pull/6
(The branch submodules_and_split is the combination of those PRs - to make the changes easier to read, I split it into two so that stuff didn't get lost.)
I moved some stuff out of the global namespace, turned the E65 stuff into an actual class, and made use of enumerations we already had, rather than redefining BMW_E65.
All comments on the PRs are welcome.
-Matt
Thanks Matt. So on bench test all looks good except message 0x332 is being sent constantly very quickly! It should only send 3 times at startup.
Reposting this from Patreon just to keep people up to date on the plans :
So I'm now finalising the V1 release design based on the 100 pin variant of the STM32F105 and a larger ecu housing featuring a 60 pin connector. I'm also dual footprinting for an F405 for future extra horsepower like flexray and ethernet as seen in many modern vehicles.
Currently Lexus GS450H and Leaf Gen1/2 inverters are supported as well as vehicle side can integration for BMW (E39,E46,E65) There is also the start of a VAG vehicle side module . I expect the software to be continuously improved with more modules and features and less Damien generated bugs as more people get involved. Things like AC charger control, CCS , Chademo , etc are all possibilities.
How do you think about adding support for the brake vacuum pump? Like reading an analog vacuum sensor on a generic analog input and switching a beefy mosfet on some also generic digital output? And maybe the fuel gauge sender from stm32-car?
Sorry if you already thought of it and mentioned it a few pages back, I'm in lazy mode ;)
Yep will do.
Dilbert
Post by Dilbert »
I have a suggestion for longer-term consideration with never revision of ECU, is if there would be the ability to add support for chargers, such as the outlander charger + DC:DC, which is fairly readily available. This would require one analogue input + pullup to detect the change handle is connected, everything else is done over CAN.
Can do. Working on the gen3 loom now.
bobby_come_lately
Has thanked: 41 times
Been thanked: 40 times
Post by bobby_come_lately »
+1 for Dilbert's suggestion.
Loving this. Hugely appreciative of your efforts.
I guess a number of amplified PWM outputs and voltage divided analog/digital inputs can be used to cover future requirements.
It is also good to have pseudo-analog outputs, PWM -> RC filter -> NPN transistor. For things like fuel gauges and such.
mdrobnak
Post by mdrobnak »
Jack Bauer wrote: Fri Jan 15, 2021 9:34 am Thanks Matt. So on bench test all looks good except message 0x332 is being sent constantly very quickly! It should only send 3 times at startup.
Hopefully that's some stupid logic error.. should be an easy fix.
If that's it, we're on our way to slaying global variables that don't need to be. ;)
Ah, yes:
https://github.com/damienmaguire/Stm32- ... ef7425R110
I forgot the if check there. Fixing.
mdrobnak
Post by mdrobnak »
Ok, a simple git pull on that submodules_and_split branch should fix you all up.
I updated PR #6 with the fix if that's all it takes.
-Matt
Nope. 0x332 is still spitting out at warp speed
mdrobnak
Post by mdrobnak »
Uhhhh
https://github.com/damienmaguire/Stm32- ... ccb9af8fbe
What am I doing wrong here then?
If not init, init, and set it to init...
Edit - Side note: I have an interview to give in 30 minutes so can't fix until after. But hopefully Johannes or someone else can figure out what I did dumb :D
Dilbert
Post by Dilbert »
One option for generic hardware might be to include a cheap microchip Digi-pot(s), these are SPI based and can contain one or more pots. You could use them to simulate thermistors or fuel senders. The instrument cluster would just see a simple resistor so should be happy.
Ok I don't understand some of the new symbols in use here but it looks like we are calling DashOn() every 100ms but we should only call it if T15==on so that is my fault from the original code.
Locked
