- Been thanked: 1136 times
I have no way to know. Just taking it at face value. I do however feel I'm being backed into the refund corner yet again. If so then I'm out.
- Has thanked: 479 times
- Been thanked: 314 times
Why would someone think that you offer Spanish support on an English website?Jack Bauer wrote: ↑Tue May 05, 2020 5:57 pmI do however feel I'm being backed into the refund corner yet again. If so then I'm out.
Do they expect you to speak every language in the world at a technical level? What if they want you to communicate using only Peruvian Folk Dance?
I'd just straight up refuse a refund.
Have they even attempted to post here and ask their questions?
Tell them to use Google Translate and post in English here and translate back and read in Spanish.
- PacEmaker
- Has thanked: 5 times
1000% agree with MattsAwsomeStuff. It's entirely on the customer. If he can read enough to buy the thing he can read enough to use the forum. Either that or he can sell it on the bay. You couldn't be clearer in your terms of sale Damien, so he has no legal leg to stand on and no ethical leg either. Sin piernas
Geoff
Is this smoke trying to tell me something ...
- jnsaff
- Has thanked: 3 times
- Been thanked: 8 times
How you gonna survive in Lanzarotte without Spanish?Jack Bauer wrote: ↑Tue May 05, 2020 5:57 pm I have no way to know. Just taking it at face value. I do however feel I'm being backed into the refund corner yet again. If so then I'm out.
Ah s^&t! good point! Just when I'm about getting up the courage to test my dodgy German on Johannes
Recieved my VCU today (thanks Damien!), I have one question already, which enclosure should I buy? I tried a search but only came up with the section that´s already there, or maybe the VCU gets too hot inside those small enclosures and that´s why the part number isn't written with the Molex connectors on Github?
Enclosure part number is listed in the BOM :
https://github.com/damienmaguire/Lexus- ... V1_BOM.ods
- jcwright45
Amazing designs for the HV and input converter covers. Are they complete? Can the files be shared to print them out ourselves? Thanksxp677 wrote: ↑Thu Feb 20, 2020 12:50 am It's glued/bonded in - I had to smash mine out. I think I used a screwdriver and then a craft knife to clean up the rest. Be careful not to cut yourself or scratch the aluminium, it's a mating face for my cover!
DC bus cover pictured in my last post is done. I just want to add o-ring grooves around the cable entries, and a million other tiny things that I'll notice.
Now onto the converter input cover!
- jcwright45
Above you state Auto-click has all the necessary connectors. I have ordered everything but the main inverter connecto,Inverter interface connector (A62) 90980–12630. Unfortunately my inverter did not include the wiring loom. Now I understand that's a critical element but not before buying my first one. Does anyone have a source to buy or options for a work around?Dilbert wrote: ↑Mon Mar 16, 2020 3:04 pm The thread on the GS450h gearbox connections has all the info you need. Auto-click in the UK has required connectors. You can also buy the other connector from them too.
viewtopic.php?f=14&t=271&start=10
This is my version of inverter connector, based on Molex parts.
First I tore the original connector apart Then I soldered the wires to the new connector.
After that it was time to try to fit the new connector to the inverter, I used the old connector and cut it flush. Then some cutting with the knife to get it square, and last but not least some sealant between the two.
This is the final inverter connector: If anyone is interested I have all the partnumbers for my build somewhere, I can post them if there is interest.
- jcwright45
Molex part number please.. Thank youFilip wrote: ↑Sat May 09, 2020 11:56 am This is my version of inverter connector, based on Molex parts.
Ok, here's the list!
36638-0002 CMC header connector 48pin 1pc
64320-1311 CMC receptacle 48pin 1pc
64320-1301 CMC wire cap 1pc
64323-1039 CP terminal 4pcs
64323-1029 CP terminal 32pcs
64325-1010 CMC plug 8pcs
64325-1023 CMC plug 4pcs
xp677
- Been thanked: 15 times
These are still not quite ready, I need to work on the seals between the sections and make some adjustments to the fit, especially on the converter piece, which needed notching on the prototypes to clear the water inlet casting.jcwright45 wrote: ↑Sat May 09, 2020 10:50 am Amazing designs for the HV and input converter covers. Are they complete? Can the files be shared to print them out ourselves? Thanks
- jcwright45
Fits perfectly. Thanks Filip. If you don't mind, we should add this to the wiki.
Great to see! You´re welcome
I don´t mind at all, if I can contribute I'm just happy.
Robbertjanzen
I have updated the drawing after some remarks and updates found in the software.
Hope this helps
Hope this helps
GS450H Wiring overview V2.3.pdf- (1.31 MiB) Downloaded 519 times
- jcwright45
Amazing, helps to see the whole picture. Thanks again.Robbertjanzen wrote: ↑Wed May 13, 2020 6:37 pm I have updated the drawing after some remarks and updates found in the software.
Hope this helps
- Kevin Sharpe
- Been thanked: 10 times
Very coolRobbertjanzen wrote: ↑Wed May 13, 2020 6:37 pm I have updated the drawing after some remarks and updates found in the software.
Hope this helps
The HV- contactor would normally use the key switch to ensure it's closed when ever the precharge or HV+contactors are closed.
I would also recommend adding an inertia switch in the 12V supply to the HV- contactor to cut power after a collision.
- arturk
- Has thanked: 7 times
- Been thanked: 4 times
Attached is pinout for Generator Resolver connector (E81)Robbertjanzen wrote: ↑Wed May 13, 2020 6:37 pm I have updated the drawing after some remarks and updates found in the software.
Hope this helps
- Bassmobile
GS450H Oil Pump Controller Part No. ?
Anybody help a guy with the part number for this Oil Pump Controller?
Can somebody add this part No. to the Wiki possibly
- arturk
Here it is
xp677
Pretty sure the oil pump controller needs its own thread by now
I for one welcome our new oil pump controller overlords.
