Page 9 of 32
Posted: Mon Jan 06, 2020 6:09 pm
by Kevin Sharpe
Jack Bauer wrote: Mon Jan 06, 2020 3:53 pm Main differences over previous versions :
Thanks for the correction, I should have listened more carefully :D
Posted: Mon Jan 06, 2020 6:28 pm
Not to sure, the tallest one I believe. Will have a look at Zero-EV tomorrow.
Posted: Mon Jan 06, 2020 6:40 pm
There was a problem of a very tall through hole 680uf main input cap hitting the lid. Swapping to a shorter but wider one cured the problem. Completely absent on the V5 as all are smd.
No master/slave on the V5 as of now but I do have some thoughts in the back of my mind about the wifi...
Posted: Mon Jan 06, 2020 7:07 pm
by Kevin Sharpe
Jack Bauer wrote: Mon Jan 06, 2020 6:40 pm No master/slave on the V5 as of now but I do have some thoughts in the back of my mind about the wifi...
Personally I don't think this is an issue... very few people will install multiple Gen 2 chargers once we have 250kW CCS... look at the Tesla Model 3 with 11kW AC for example :)
Posted: Tue Jan 07, 2020 8:34 am
by prensel
Kevin Sharpe wrote: Mon Jan 06, 2020 7:07 pm ... very few people will install multiple Gen 2 chargers once we have 250kW CCS...
Is there any progress on having CCS on a DIY base ?
Posted: Tue Jan 07, 2020 7:13 pm
by Kevin Sharpe
prensel wrote: Tue Jan 07, 2020 8:34 am Is there any progress on having CCS on a DIY base ?
Yes, we expect both the Super Yacht (here) and ICE Breaker (here) to have CCS based on the Model 3 Charge Port ECU (here) in the next few weeks 8-)
Posted: Wed Jan 08, 2020 2:37 pm
by prensel
I got the Model3 EU CCS socket to build into my Th!sla (Think with Tesla parts..) project.
How do you take care of the PHY stuff and protocol stack ?
Posted: Wed Jan 08, 2020 8:38 pm
by Kevin Sharpe
prensel wrote: Wed Jan 08, 2020 2:37 pm How do you take care of the PHY stuff and protocol stack ?
We're using the Tesla Model 3 EU Charge Port ECU (see here). We'll publish updates as they become available in that thread and on Damien's YouTube channel.
Posted: Sat Jan 11, 2020 7:46 pm
by nesto1972
Hi
I have Trouble to config Damiens Controller for Gen3.
I did all well and read the Manual carefully and install the program PuTTy on my Computer.
I start and connect to Controller,press d for stopping the traffic.
press 1 changes Auto eneble is ok!
but i cannot Change Parameter with value!!! only on/off
for example Pressing 3 then 1 or "31" is only switching 1 enable onoff!
does anyone know this Problem?
THX
Thomas
Posted: Sat Jan 11, 2020 11:43 pm
by Kevin Sharpe
nesto1972 wrote: Sat Jan 11, 2020 7:46 pm does anyone know this Problem?
What version hardware and software are you using?
Can you post a video showing this behaviour and show how you've wired up the charger for test? The more information you provide the more likely you are to get help :)
Posted: Sun Jan 12, 2020 11:20 am
by nesto1972
i use Windows 10,PuTTY 0.73 x64
I have Gen3 North Amerika Version.
So must the Controller connected to charger modules for config????
I tryed both,no difference!
actual Status when i connect to charger:when i put IN1 to 12 V all three modules led turn on.(god sign??)
I will later post a Video !
Posted: Sun Jan 12, 2020 11:29 am
by Kevin Sharpe
nesto1972 wrote: Sun Jan 12, 2020 11:20 am I have Gen3 North Amerika Version.
Assuming you're testing in Austria, how have you wired the mains input? Single Phase or have you modified the charger hardware?
Is this a tested controller board from Damien or one you made yourself?
What firmware version are you using? If you don't know where did you get it from?
Posted: Sun Jan 12, 2020 4:06 pm
by nesto1972
Modified 3 Phase
Yes its a board from Damien!
firmware:no idea
i bought in December so quite new!
Is Damiens Controller without charger configable?
Posted: Sun Jan 12, 2020 6:57 pm
by nesto1972
Now i tryed another computer but same issue.
Is there need to connect to charger full wired? (AC,DC)for programming these little parameters on controller???
Wich firmware?from charger or damiens Controller?
Posted: Sun Jan 12, 2020 8:13 pm
Do you have CR/LF enabled on your terminal program? There is no need to change the software on the controller. They are shipped programmed and tested.
Posted: Mon Jan 13, 2020 12:18 pm
by nesto1972
Can you tell me where i will find "CR/LF enabled",i looked the whole tree but can not find!
Sorry but for me is the first time using PuTTY!
Also i make a mess trying combinations with keys and they effect programming( Voltage =0,Current =0)
Why is programming not needed??? I have 96S Tesla,and the current should be increased after testing!,no?
Posted: Mon Jan 13, 2020 1:24 pm
by Kevin Sharpe
nesto1972 wrote: Mon Jan 13, 2020 12:18 pm Can you tell me where i will find "CR/LF enabled",i looked the whole tree but can not find!
Posted: Mon Jan 13, 2020 5:02 pm
by nesto1972
I enabled CR/LF and typed ESC key [20h ???
no progress!
Posted: Mon Jan 13, 2020 5:52 pm
Try using termite or just Arduino IDE should work right after installation.
Posted: Mon Jan 13, 2020 7:25 pm
by nesto1972
No sucess!
I give up 3 days of nightmare!
Posted: Mon Jan 13, 2020 11:10 pm
by xp677
Just a quick question, apologies if this has been discussed before.
I seem to recall an issue with these charger controllers where they aren't able to trigger an EVSE by pulling the Pilot line to 0v, apparently this caused an issue with the microcontroller?
Was this a real thing, or did I imagine it? If this was a real issue, was it ever resolved?
I'm about to order some bare PCBs for my project (incorporates BMS and charger controller), and would rather make changes now than later!
Cheers.
Posted: Tue Jan 14, 2020 7:47 am
There was a bug on the old v1 pcb with some missing grounds but that was way back. Current designs are fine in that respect to the best of my knowledge.
Posted: Tue Jan 14, 2020 7:57 am
nesto1972 wrote: Mon Jan 13, 2020 7:25 pm No sucess!
To clarify when I said you do not need to reprogram the controller I mean you do not need to change the software that is installed.
Please do the following :
Download and install arduino ide from here :
https://www.arduino.cc/en/Main/Software
Connect the controller to your pc with a usb cable
Open the arduino serial monitor at 115200 bps
You should see information scrolling on the screen
type d and press enter. This brings up the menu.
From here you can set the parameters as required.
When set type q and press enter to quit the menu.
If this does not work for whatever reason and you believe there to be a problem with the unit then please contact me via email and return the unit to me for testing.
Again I have to remind people : I do not provide one to one support for this or any other product. For more detail see this thread :
viewtopic.php?f=10&t=256
Posted: Tue Jan 14, 2020 9:10 am
by nesto1972
With arduino i made it !
THANKS!!!
Posted: Tue Jan 14, 2020 9:41 am
Excellent:)
