Page 2 of 2
Re: [DRIVING] 1978 VW T2 Camper
Posted: Thu Mar 07, 2024 8:33 pm
by DaveH
CCS controller and inlet is in. Kit at eDubs posted a video before I picked her up.
Next I need to improve the brake pump with the vacuum sensor I got from Citini, then it will be time for an interior.
Posted: Sat Mar 23, 2024 7:18 pm
by DaveH
New vacuum sensor from Citini (attached to the blue manifold). Works a treat - I am now getting about 7 seconds pump run time every 24 seconds, which may indicate a slight vacuum leak but it will do for now.
Posted: Sat Mar 23, 2024 7:54 pm
Glad to see them in the wild, switches are quite finicky compared to a digital solution.
Posted: Thu May 23, 2024 7:49 am
by ianlighting
Hi DaveH, just scanned through your build posts. I’m at the start of my VW conversion so it’s good to see someone reach the other end!
Can I ask whether it went ok with the dvla in the end? You’ve obviously got a super clean, as new looking vehicle. I’m debating what level of restoration to go for, but I can see it might make the inspector more inclined to pass it if he thinks the vehicle overall is in good shape. Or do you think they have a narrow focus on just the EV bits of the vehicle?
2nd question is are you happy with the brake vacuum pump? Would love to have a link to what you bought if possible. Any changes you’d do if you did it again?
Are you using it regularly now? What’s your range like?
Cheers
Ian
Posted: Tue Jul 02, 2024 5:37 pm
by DaveH
Apologies for the delay, I haven't been on here for ages.
I think as long as it's MOT worthy you should be ok. The inspector didn't spend very long looking at it, he asked a few questions, looked at the subframe to make sure it was properly mounted. I think he had a quick look at the wiring but didn't ask to open up the battery box or anything.
The brake pump is fine, it does a better job than the engine did but the noise can be annoying. I have the one that Fellten sell but didn't use the relay or vac switch.
https://shop.fellten.com/shop/brakevack ... y=71#attr=
I still haven't used the van that much, just finishing off the interior now and there have been a few software updates and parameter tweaks to get it right. I'm pretty happy with it now. I get about 3.3 miles/kWh but obviously it depends how you drive it.
Posted: Tue Jul 02, 2024 5:53 pm
by Jacobsmess
This looks great, out of curiosity whereabouts are you based? I see your van went to Borough bridge for resto, I'm over in Leeds so not far, it'd be great to see then van in real life. Cheers
Posted: Wed Jul 03, 2024 1:09 pm
by DaveH
My location is in my profile :)
