Page 2 of 2
Re: electric power steering mini cooper (R56)
Posted: Mon May 19, 2025 1:07 pm
by mane2
1. Wire Connections
Yellow = Ignition (12V)
Yellow/Black = CAN High
Yellow/Brown = CAN Low
CAN bus speed = 500 kbps
2. Send Required CAN Messages
Mandatory messages:
0x130 (Terminal status) every 100ms
Example: 0x45 0x41 0x21 0x8F 0x24
0x1A0 (Vehicle speed — affects assist level) every 50ms
Example: 0x00 0x80 0x00 0x00 0x80 0x00 0x78 0x1B
0x1D0 (Engine run) every 50ms
Example: 0x61 0xFF 0x6E 0xD2 0x24 0x78 0xCC 0xA4
3. Vehicle Speed Message 0x1A0
The first byte (data[0]) seems to influence assist (e.g., 0x00 = light steering, 0xFF = heavy).
Second byte (0x80 at rest, 0xB0 when moving) to signal movement state.
Posted: Mon May 26, 2025 1:09 pm
by mengu190
tom91 wrote: Wed May 07, 2025 4:16 pm Static values do not work.
how can i simulate like car cruising 100km ?
Posted: Mon May 26, 2025 1:13 pm
by mengu190
mane2 wrote: Mon May 19, 2025 1:07 pm 1. Wire Connections
Mandatory messages:
i will try and reply thanks
Posted: Mon May 26, 2025 1:48 pm
mengu190 wrote: Mon May 26, 2025 1:09 pm how can i simulate like car cruising 100km ?
Check @mane2post and the other information in this thread
Posted: Thu Jul 24, 2025 12:26 pm
by CPLRacing
mengu190 wrote: Mon May 26, 2025 1:13 pm i will try and reply thanks
Hi Mengu
Did you manage to get the EPS working on your Mini. I also run my Mini on Maxx ecu and have everything working except the EPS
