Page 2 of 2
Re: No charge current with Leaf PDM and Zombiverter VCU
Posted: Fri Jan 24, 2025 1:31 pm
Does the Zombie go into charge mode? This is still possible with key off, what firmware version are you on?
0x?8 drives plug detect nothing else gets changed.
Only when actually capable of charging does it show some other values.
Posted: Fri Jan 24, 2025 2:24 pm
by Rustybkts
Firmware 2.20A
0x088 each time plug is inserted on 7kW EVSE.
PlugDet On
PilotTyp none
CableLim 0
PilotLim 0
Opmode 0
ChgTyp 0
Posted: Fri Jan 24, 2025 2:25 pm
Does it go into charge mode?
Posted: Fri Jan 24, 2025 2:27 pm
by Rustybkts
tom91 wrote: Fri Jan 24, 2025 2:25 pm Does it go into charge mode?
No only PlugDet On
Posted: Fri Jan 24, 2025 2:30 pm
What are all your settings? as it should go to charge mode if the parameters and settings allow.
Once the PlugDet is set and the Zombie is okay to go charge it will. try.
Ofcourse you will need the whole system working as it will want to do precharge and such.
Posted: Fri Jan 24, 2025 2:37 pm
by Rustybkts
All settings are as the attachment sent earlier.
I'm pretty sure they are all correct.
Posted: Fri Jan 24, 2025 2:38 pm
by Rustybkts
All HV control has been working for weeks as the inverter and DC-DC ore fully operational
Posted: Fri Jan 24, 2025 2:39 pm
Is Chgctrl enabled, set to 1?
Posted: Fri Jan 24, 2025 3:00 pm
by Rustybkts
tom91 wrote: Fri Jan 24, 2025 2:39 pm Is Chgctrl enabled, set to 1?
Confused I am.... ChgCtrl set to Enable but parameter log shows a 0 set.
Posted: Fri Jan 24, 2025 3:17 pm
by Rustybkts
If I set Chgctrl to Disable I get a 1 on parameter log.
Still no charge so will take a long look at the parameter log.
Posted: Fri Jan 24, 2025 3:31 pm
by Rustybkts
I now am displaying PilotLim as 28A but still nothing on opmode.
No LastError, Chgtyp or HV contactor operation
Posted: Fri Jan 24, 2025 3:38 pm
Rustybkts wrote: Fri Jan 24, 2025 3:31 pm PilotLim as 28A
Sure is the PDM trying to activate the EVSE?
What opmode is it in? It should be in off when trying to go to Charge
Please log: Opmode, Plugdetect, Pilotlim
Also a CAN log please.
Posted: Fri Jan 24, 2025 3:51 pm
by Rustybkts
Opmode is off
EVSE App displays "ready to charge" and a limit of 32A when plugged in.
Battery management parameters all correct.
Posted: Fri Jan 24, 2025 3:53 pm
Okay then I cannot help you. Your setup is not behaving as everyone else running the 2.20A release. Also please include more info in stead of the bare minimum this gives me nothing to go on.
Posted: Fri Jan 24, 2025 3:57 pm
by Rustybkts
Ok thanks for your time. Looks as if the ChgCtrl is working backwards somehow.
Posted: Fri Jan 24, 2025 3:59 pm
#define CHGCTRL "0=Enable, 1=Disable, 2=Timer"
Zero is fine so that was not it.
So I have zero things left for you. You download the release right,https://github.com/damienmaguire/Stm32- ... /tag/2.20a, and used that for the update? You did not compile your own code?
Please show me all your spot values with the charge plugged in.
Posted: Fri Jan 24, 2025 4:05 pm
One last thing to try, set "interface" to chademo
Damien's truck params do not show this.
Posted: Fri Jan 24, 2025 4:21 pm
by Rustybkts
Tom, I owe you a large drink.
Set ChgCtrl to Enable = 0 and its charging.
Might have been a BMS_VmaxLimit or minLimt as I have adjusted a few since setting ChgCtrl to 1.
Charging at 0.7kW and note that BMS_ChargeLim is only 2A. I guess that comes from the BMS so will check that.
Thanks again.
When its all sorted, will add to Wiki a list of parameters used with Leaf drive units as so many are not used, especially on the Spot Values list.
Posted: Fri Jan 24, 2025 4:27 pm
Key here has been 0x?8 on plug in.
Rest of the params been changed along the way and should not have been. Same goes for your wiring, please clean this up to as per wiki documentation.
Posted: Fri Jan 24, 2025 5:01 pm
by Rustybkts
I did try selecting Interface Chademo and all it did was lock the Zombie to continuous Charging and HV contactors on all the while.
Selecting Interface to Unused dropped the HV contactors off.
Could do with a future update to allow 0x8? to be range from 0x84 to 0x88 as a 16A cable or Granny will not enable the PDM.
Wiring is exactly as wiki docs.
Posted: Fri Jan 24, 2025 5:24 pm
Rustybkts wrote: Fri Jan 24, 2025 5:01 pm0x84 to 0x88
Not sure this is real. Will need other to also conclude this. As its the first time I have seen this.
