Page 2 of 5
Re: Lexus Inverter Hacking
Posted: Sat Apr 27, 2019 3:01 pm
Closed loop control of the GS450h booster in both buck and boost mode using an atmega328. Just set the desired voltage over serial and it will buck or boost as required.
Posted: Sat Apr 27, 2019 10:09 pm
Jack Bauer wrote: ↑Sat Apr 27, 2019 3:01 pm
Now that is what i had in mind for charge pump. So in effect you can have a drive and a charger unit in one case. Superb work.
Now what we need is interface!
Posted: Sun Apr 28, 2019 9:07 am
These Toyota inverters are a huge untapped resource. I just wish I had the skills and finance to make it happen quicker.
In the same vein it is of course impossible to kill the booster. No turning on both high and low , no running the pwm freq too high too low or too much or too little duty.
Posted: Mon Apr 29, 2019 11:35 pm
How much power have you put through it? Any idea of the achievable efficiencies?
Posted: Wed May 08, 2019 6:20 am
by Rouwdy
Patiently waiting on further development. I have been fascinated by these transaxles for the last couple years. Stumbled across your work here just as i was about to give up on the notion. Thanks for keeping the dream alive. I happen to have an old Toyota that i want to restore, along with an upgrade. The original 2.6 liter is a thirsty beast that barely can get out of its own way when it isn't pushing out headgaskets. A lexus drivetrain would be fitting, as this model is essentially the grandparent to the lexus brand. Well that's my introduction, extra points if you can name the car.
Posted: Wed May 08, 2019 6:44 am
by sfk
Toyota Crown.
Posted: Wed May 08, 2019 9:06 pm
by Rouwdy
Same car different name. Mark II at any rate. It went by many names depending on market. I have the mx32 Cressida. My particular one is an oddball as in 78 they adopted injection and mine still has the carburetor. Excited to see where Jack and the team here go, while i get the old girl looking a little nicer. Even if the lexus drivetrain doesn't pan out, i can always put a 2JZ in her and be happy. The ultimate dream is a 2JZ mated up to the hybrid system. All of Toyota's best in one package...
Posted: Mon May 13, 2019 9:55 am
by johnspark
The Toyota Camry Hybrid AVV50R aluminum die-cast frame holding the top PCB is stamped with 035A not 035B as per is300h inverter. But i can't see any differences at all between the two.
Posted: Mon May 13, 2019 6:32 pm
It does look like the 3 phase output connections are a little different but I also can't see any differences.
Posted: Tue May 14, 2019 9:42 am
by johnspark
Here are pics of the AVV50R inverter still in the car:
At some stage in the future, i will try to get the voltages wrt time, of each of the wires connected to the DC/DC converter below the inverter...
Posted: Tue May 14, 2019 9:44 am
by johnspark
photo of DC/DC converter connector...
Posted: Thu May 16, 2019 10:21 pm
by johnspark
A few years ago, i paid ~$30 to access the Toyota Technical site for 2 weeks. During that time, i was able to download some info on the Toyota Camry Hybrid AVV50x. There were two pages that talked about a pressure sensor in the inverter Please see pics below.
(hope this info is useful, apologies if you already know...)
you will find this info on the first 3 slides of the word doc attached.
Can't tell if the sensor is on top pcb or bottom pcb of the inverter.
Posted: Sat May 18, 2019 7:11 am
by johnspark
Attached are the wiring schematic and connections for the DC/DC converter plug for the AVV50x (is300h?).
Posted: Sat Jun 01, 2019 1:34 am
by 519 Kustomz
I am quite interested to know more about the boost converter aswell. I would love to know if it is something that could be divorced from the Lexus inverter and ran by the open source inverter. Would it be a can signal that would essentially tell it what to do?? I want to run the Lexus mg3 for context. I have it all mounted and ready to go in a 74 Volkswagen thing and would love to get it spinning!!
Posted: Sat Jun 01, 2019 1:38 am
by 519 Kustomz
Posted: Sat Jun 01, 2019 4:08 am
by sfk
Is the Lexus MG3 the type found in the rear axle of the RX?
Does it have approx 50kw output? Is there a maximum RPM which would limit top speed prematurely?
I'm interested in the idea of putting 2 of these into a 4wd car, particularly an Audi Quattro A4 or A5. Together they may provide acceptable performance.
Posted: Sat Jun 01, 2019 12:39 pm
by 519 Kustomz
Yes that is exactly it. I believe it was found in the Toyota hylander hybrid aswell. It is 50kw so when compared with the original 46hp vw motor it should in my mind be quite acceptable of a transplant.
To my knowledge I am not sure of a maximum electrical rpm but would assume that it is always
Spinning in its originally designed purpose it should be okay in this little volkswagen! I thought I read somewhere of 18000rpm max rating but could be horribly incorrect as it has been difficult to get much info out of Lexus...
Biggest question for me is can we utilize the boost converter in some ‘aftermarket’ fashion.
Maybe jack bauer can chime in with some ideas. I don’t know how to tag him so he sees the post though..
Posted: Sat Jun 01, 2019 2:35 pm
by Kevin Sharpe
519 Kustomz wrote: ↑Sat Jun 01, 2019 12:39 pmBiggest question for me is can we utilize the boost converter in some ‘aftermarket’ fashion.
We're all really busy getting ready for the Fully Charged Live show but I know 'Jack' has some interesting ideas on how we can use the boost converter on a future project
We're back in Ireland in a little over a week and hopefully 'Jack' will then take a holiday
Posted: Sat Jun 01, 2019 2:42 pm
by Kevin Sharpe
519 Kustomz wrote: ↑Sat Jun 01, 2019 1:34 amI want to run the Lexus mg3 for context. I have it all mounted and ready to go in a 74 Volkswagen thing and would love to get it spinning!!
Fabulous
Can you start a project page (
here) please?
Posted: Sat Jun 01, 2019 4:42 pm
by 519 Kustomz
Very cool. I’ll assemble some pics and attempt a build thread.
I would love to hear how Jack (Damien) is making on with this. I’m going to get one from my local scrappers to start messing with aswell. Curious if he has cloned and is sending it can signals or what??
Posted: Sat Jun 01, 2019 6:46 pm
by sfk
Yes. Must always be spinning since the rear wheels are always turning when the car is moving. But there may be a clutch in there to disconnect at higher road speeds. The motor only intended to provide traction when required.
Posted: Sat Jun 01, 2019 10:08 pm
by Kevin Sharpe
519 Kustomz wrote: ↑Sat Jun 01, 2019 4:42 pmVery cool. I’ll assemble some pics and attempt a build thread.
Great!
519 Kustomz wrote: ↑Sat Jun 01, 2019 4:42 pmI would love to hear how Jack (Damien) is making on with this.
He's been working flat out on the Panzer for the last few weeks. Have you seen his video channel? That has the most up to date information and links to github, etc;
https://www.youtube.com/user/pooey1911/videos
Re: Lexus Inverter Hacking [edit]
Posted: Mon Jun 03, 2019 7:45 pm
by sfk
sfk wrote: ↑Sat Jun 01, 2019 6:46 pm
EDIT: the unit is called the Q211 or referred to as "MGR" Motor Generator Rear. It has no such clutch and is always spinning when the vehicle is moving. Approx 6:1 reduction ratio through a fairly lightweight open differential. It doesn't seem possible to get too much more out of this setup as the internal gearing components would need to be beefed up. So limited in use to light weight vehicles or maybe in dual motor 4wd setup in more medium weight vehicles.
Might be worth pointing out that this unit is
air cooled and relies on fairly modest cooling fins on the casing. And therefore may overheat with constant use. However, there is a lubricant drain plug and separate fill plug so shouldn't be difficult to route the lubricant through a pump and heat exchanger then back into the case again.
Posted: Tue Jun 04, 2019 1:49 am
by 519 Kustomz
Might be worth pointing out that this unit is air cooled and relies on fairly modest cooling fins on the casing. And therefore may overheat with constant use. However, there is a lubricant drain plug and separate fill plug so shouldn't be difficult to route the lubricant through a pump and heat exchanger then back into the case again.
Right, it is the mgr. I did read that and missed it. I have opened this little unit right up and had a look inside. I love it’s complete simplicity. Your correct it it may not be a power house of a drive but I’m going more for a ‘stock’ power replacement. Ecomodder stuff I suppose. I have already planned on the possibility of a recirculating oil cooler if need be. The boost converter is what I’m excited / curious about. How to jamb the full 650v into this thing...
Posted: Thu Jun 20, 2019 6:31 pm
Its worth noting that Toyota only use the boost converter when the motor needs to run above the speed possible with the base battery voltage.
I think the MGR with a little 12v oil pump and cooler would make an excellent low cost drive unit.
