Page 2 of 2
Re: Web interface problems V2.1 mainboard
Posted: Wed Apr 10, 2019 2:36 pm
by PoloLbricolo
I had the same issue, i couldn't upload the arduino sketch to the ESP but i finally achieve the succesfull upload.
Check your RX/TX wires it might help if they are corrrectly connected.
In arduino IDE, under tools, erase flash try seecting all flash contents.
This worked for me.
Hope it helps
Posted: Tue Apr 30, 2019 8:58 am
by purplespark
Quick update ! The firmware was being flashed to the 8266 all the time , but because I couldn't alter the ssid or create a password ,or
load spiffs I didn't think the firmware had flashed properly - if that makes sense. Anyway ,loaded spiffs using curl - seems you have to use the full path to the files - and then I was able to see the web pages !!! Now all i need is some advice on how to flash a ssid and password in the firmware code - Johannes ' instructions don't seem to work .
Posted: Wed Sep 11, 2019 7:13 am
I would like to report a problem with WiFi adapter ESP8266.
I tried to upload Rev 4.53R software over Wifi and failed. I tried multiple times and allways when i innitiated the file Olimex would drop into reset and WiFi adapter would fall out. In the end i pulled Olimex out and manually updated software.
Any solution to WiFi firmware update?
Posted: Wed Sep 11, 2019 10:31 pm
by dima
Posted: Thu Sep 12, 2019 5:06 am
Tnx, seems i missed that one
Arber
Posted: Thu Dec 26, 2019 9:00 pm
Hi
Again i would like to report a problem.
I took a brand new ESP8266.
I uploaded Johannes ESP8266 web interface ino file.
Then i installed the SPIFs.
Then i got inside web interface and set wifi password and SSID.
Next i connected to my off car V2 board, but web interface wouldnt load parameters! I tried changing the tx/rx wires, but both setups show exactly the same view. Waiting circle rolling at parameter line...
Any ideas?
I loaded flash onto Olimex ESP8266 mod as well as on Wemos D1 mini. The latter is much easier to program. But still i cant connect to the board effectively.
tnx
A
Posted: Fri Feb 21, 2020 6:37 pm
by yaroslav
Hi. I uploaded Dima files to wemos d1, I can see the parameters and can change them, but when I go to the tab where I can enable graphs and click on start, the graph is not drawn.
What could be the problem?
Posted: Fri Feb 21, 2020 6:40 pm
by SciroccoEV
Do you need the 'auto' box (next to the refresh button) ticked?
Posted: Fri Feb 21, 2020 6:48 pm
by yaroslav
I want the oscilloscope to work, which works if you establish a connection via uart
Posted: Fri Feb 21, 2020 6:57 pm
by joromy
yaroslav wrote: ↑Fri Feb 21, 2020 6:48 pm
You must tick the L or R box next to the spot value you want to "scoope"
Posted: Fri Feb 21, 2020 7:29 pm
by yaroslav
I use the Dima interface, there is no such choice
Posted: Sun Jun 21, 2020 7:40 pm
by Thatguyoverthere
arber333 wrote: ↑Thu Dec 26, 2019 9:00 pm
Hi
Any ideas?
tnx
A
Did you ever figure this one out? I have the same problem. It seems I can successfully upload *.bin files to the stm32, but no parameters. I'm beginning to think this is another case of missing files in the "data" folder.
Posted: Sun Jun 21, 2020 8:06 pm
Thatguyoverthere wrote: ↑Sun Jun 21, 2020 7:40 pm
Hi
Well try resetting the STM32 board (manually by a reset button) after you are connected to wifi module. Then refresh interface in your browser.
It seems some packets get stuck before bootloader on STM32 can get them sorted. Strangely i dont have this problem in my car. This only happens on desk...
Posted: Mon Jun 22, 2020 12:43 am
by Thatguyoverthere
Yeah I might have another problem (dead stm32 I guess, not getting warm and no ALIVE_LED), so I'll try that after I repair the board.
Posted: Tue Jun 23, 2020 7:49 pm
by damian.lo
Arber, do You remember my situation with stm32 after failed uploading bin file?
Thatguyoverthere - first try to connect with STM-32 Link utility to chip - if is possible to connect - he lives, but maybe something is corrupted.
In my situation faster was to replace stm32 chip (was unable to establish connection to chip). I wish You bigger luck than I had
