Page 11 of 16
Re: [WIP] BMW Z3
Posted: Tue Mar 05, 2024 10:26 am
by Aragorn
andybpowell wrote: Sat Mar 02, 2024 1:57 pm now my diff is on the way I'm really tempted to order a lsd for it in fact I'm on the Matt Lewis racing site with it in the basket right now trying to be sensible and really struggling because I really really want it
:lol:
Are there not factory LSD options that can work instead of buying new?
Re: [WIP] BMW Z3
Posted: Tue Mar 05, 2024 11:01 am
by andybpowell
Aragorn wrote: Tue Mar 05, 2024 10:26 am Are there not factory LSD options that can work instead of buying new?
rare and expensive it's just as cheap to buy new also the ratio's are always high
Re: [WIP] BMW Z3
Posted: Tue Mar 05, 2024 3:21 pm
by andybpowell
since it was a little moist outside I treated the diff to a spin in the media blaster and a few coats of paint
just need to drop the old one and swap them over the slightly better ratio was hardly worth bothering with 3.45 to 3.38 but every little bit helps
Re: [WIP] BMW Z3
Posted: Wed Mar 06, 2024 5:13 pm
by andybpowell
Diff is in and it was an absolute pig the bolts were really hard to access and some idiot (me) put them in really tight with threadlock, but its all in just need to refill with oil and torque up the driveshaft bolts
Re: [WIP] BMW Z3
Posted: Thu Mar 07, 2024 11:34 am
by andybpowell
Re: [WIP] BMW Z3
Posted: Thu Mar 07, 2024 11:43 am
Over 300A :) Can you get a Amp and UDC graph at some point? Things are starting to look good.
Wonder how much more the limit can go up by. ;)
Re: [WIP] BMW Z3
Posted: Thu Mar 07, 2024 12:05 pm
by andybpowell
tom91 wrote: Thu Mar 07, 2024 11:43 am Over 300A :) Can you get a Amp and UDC graph at some point? Things are starting to look good.
yes no problem that plot was with throtmax at 50%
Re: [WIP] BMW Z3
Posted: Sat Mar 09, 2024 3:05 pm
by andybpowell
Is this any good for you
Still juddering at low throttle not sure why yet
Re: [WIP] BMW Z3
Posted: Sat Mar 09, 2024 5:18 pm
by Jacobsmess
Peaking around 350A! Great work, did you tweak thrormax at all?
Re: [WIP] BMW Z3
Posted: Sat Mar 09, 2024 5:27 pm
From those plots it is now hitting the 100kW limit as I set in the code. Will need to look at tweaking things more once your car is more sorted.
Re: [WIP] BMW Z3
Posted: Sat Mar 09, 2024 6:01 pm
by Ev8
Impressive, with my gearbox making noise this could be an option
Re: [WIP] BMW Z3
Posted: Sat Mar 09, 2024 8:11 pm
by andybpowell
tom91 wrote: Sat Mar 09, 2024 5:27 pm From those plots it is now hitting the 100kW limit as I set in the code. Will need to look at tweaking things more once your car is more sorted.
hopefully I can have it usable quite quickly. I have the bms partially working it's reporting high and low cell voltages though it's not reporting the number of cells for some reason but I have done a major hack job on your simpbms code (sorry Tom) So I may start again with that as it's been through many changes, the charging is all working other than tidy the wiring and sort the rev light it'll be ready to go
Re: [WIP] BMW Z3
Posted: Sat Mar 09, 2024 8:12 pm
by andybpowell
Ev8 wrote: Sat Mar 09, 2024 6:01 pm Impressive, with my gearbox making noise this could be an option
only if you can find one, it seems the are all being bought up :lol:
Re: [WIP] BMW Z3
Posted: Sat Mar 09, 2024 8:13 pm
by andybpowell
Jacobsmess wrote: Sat Mar 09, 2024 5:18 pm Peaking around 350A! Great work, did you tweak thrormax at all?
no I think it's currently at 100%
Re: [WIP] BMW Z3
Posted: Sat Mar 09, 2024 9:38 pm
by AMP3R
Do you have a dragy? Could you floor it and show the numbers?
Re: [WIP] BMW Z3
Posted: Sat Mar 09, 2024 9:54 pm
AMP3R wrote: Sat Mar 09, 2024 9:38 pm Do you have a dragy? Could you floor it and show the numbers?
No where near where any of that would be relevant yet.
Re: [WIP] BMW Z3
Posted: Sun Mar 10, 2024 7:08 am
by Ev8
Looks like this won’t be an option for me as the longest ratio rx8 diff is 4.3! Lol will be interesting to see what top end you manage
Re: [WIP] BMW Z3
Posted: Wed Mar 13, 2024 4:16 pm
by andybpowell
I'm slowly chipping away at the outstanding jobs, charging is now working properly and it's currently on charge, the bms is working (90%) well enough so I can have some feedback during testing, and all of the important data is being shown on my nextion display so just the rev light and tidy the wiring
Re: [WIP] BMW Z3
Posted: Wed Mar 13, 2024 7:53 pm
by nkiernan
andybpowell wrote: Wed Mar 13, 2024 4:16 pm bms is working (90%) :)
I have a SimpBMS and just got a 24kWh X5 pack too. Are there many changes to the BMWPhevBMS to get it working with the X5 pack? Is it mainly around identifying the extra modules on the CAN bus?
Re: [WIP] BMW Z3
Posted: Wed Mar 13, 2024 8:36 pm
by andybpowell
nkiernan wrote: Wed Mar 13, 2024 7:53 pm I have a SimpBMS and just got a 24kWh X5 pack too. Are there many changes to the BMWPhevBMS to get it working with the X5 pack? Is it mainly around identifying the extra modules on the CAN bus?
I did have it all working when it was all laid out in my garage thanks to Tom De Bree, this is the information he sent me
In code
https://github.com/Tom-evnut/BMWPhevBMS ... hevBMS.ino
void sendcommand() //Send Can Command to get data from slaves
///////module id cycling/////////
if (nextmes == 6) {
6 is the modules amount, so change it to 12 as the modules are 0 to 11 .
But I'd hacked the code on my simpbms so much I decided to start again but now with it in the car I'm having some problems it seems to work fine when charging but when driving it seems to have some issues I need to investigate it further it may be down to all of the other canbus traffic on the same bus when in drive mode
Re: [WIP] BMW Z3
Posted: Wed Mar 13, 2024 9:52 pm
by nkiernan
Thanks for the reply, smaller change than I was expecting so! :) I hope to get to this on the bench at the weekend
Re: [WIP] BMW Z3
Posted: Wed Mar 13, 2024 9:58 pm
Slight issue with this is that the final XOR for making the command correct for the numbers above 6 wont be correct, but if Andy has gotten the modules reporting the info this is all good.
It is possible that balancing will not work, this has not been proven yet.
Re: [WIP] BMW Z3
Posted: Wed Mar 13, 2024 10:13 pm
by andybpowell
I didn't look in depth at it to be honest it's reporting 96 cells and high and low voltages I'll have a closer look tomorrow if I get a chance
Re: [WIP] BMW Z3
Posted: Thu Mar 14, 2024 11:21 am
by andybpowell
tom91 wrote: Wed Mar 13, 2024 9:58 pm Slight issue with this is that the final XOR for making the command correct for the numbers above 6 wont be correct, but if Andy has gotten the modules reporting the info this is all good.
had a quick look from what i can see it looks fine no idea about balancing though
Re: [WIP] BMW Z3
Posted: Thu Mar 14, 2024 5:38 pm
by andybpowell
logged some more data as I was out driving the first 2 peaks are uphill the 2nd peak is a hill start
This is the matching video (I had to cut out a small bit due to my foul language)
