Page 12 of 25
Re: 1984 Voltswagen Rabbit Prius Gen 3 ZOMBIE
Posted: Wed Mar 27, 2024 12:44 am
by Gregski
so I thought it was the Parking Pawl causing that click clock noise
Posted: Wed Mar 27, 2024 5:25 am
by Gregski
well it was one of them days
I decided to drop the transaxle, so naturally first I had to either grow a third arm, make some friends, or invent the Soloist 7000
Posted: Wed Mar 27, 2024 7:09 am
by MattsAwesomeStuff
Gregski wrote: Wed Mar 27, 2024 5:25 amwell it was one of them days
Let's power up on the power of anger!
Considering they were LA based and the amount of fan camios, there's a non-zero chance you're in that video somewhere :p
Turns 25 this year. There are married people with graduate degrees were born after this song came out. On review, was it this cringe back then? Ugh. *considers turning his cap forward at least 50% of the time*
Posted: Wed Mar 27, 2024 3:38 pm
by Gregski
Carnage 2.0
Posted: Wed Mar 27, 2024 5:41 pm
by Gregski
Def Con 4
Posted: Thu Mar 28, 2024 1:39 am
Gregski wrote: Wed Mar 27, 2024 3:38 pmCarnage 2.0
Nooo!!! He is bleeding to death!
Just tell me to stop vandalizing your thread whenever...
Posted: Thu Mar 28, 2024 4:25 pm
by Gregski
Happy to report the problem has been fixed, I will leave the technical explanation to the masters.
Toyota Prius Open Transaxle Motor Action
Posted: Fri Mar 29, 2024 2:09 pm
by Gregski
with the transaxle out I thought it was as good a time as any to make some things black (after making them red)
I luv this primer
I wanted to hang these up to cure in the garage, but the wife insisted I move them into the formal dining room, while she's on Girls Weekend Out !
Posted: Fri Mar 29, 2024 2:16 pm
by Gregski
I also managed to get the Paint Booth inside the Rabbit
nailed the color match
Posted: Fri Mar 29, 2024 11:28 pm
by Gregski
VW Rabbit DIY EV Charge Port
some day I'll own a car with a fuel filler door
Posted: Sat Mar 30, 2024 5:29 am
Gregski wrote: Fri Mar 29, 2024 11:28 pmVW Rabbit DIY EV Charge Port
"Gentlemen, let me tell you a story. A story about a path of least resistance."
*proceeds to not tell a story at all*
Damnit Greg, that was a parable, not a story, and the parable was the non-telling of the story, by the story itself being so much the path of least resistance that you didn't even bother to tell the story at all! You just gave it a title and left it to drift in the river, like Jochebed to her baby Moses. And what are we your audience supposed to be? The naked Egyptian princess bathing in the river, to take your story right into the Pharaoh's household?
Well I never.
Posted: Sat Mar 30, 2024 1:24 pm
by Gregski
MattsAwesomeStuff wrote: Sat Mar 30, 2024 5:29 am "Gentlemen, let me tell you a story. A story about a path of least resistance."
Well I never.
a simple story
of a simple man
who's focused
on simple solutions
Posted: Sat Mar 30, 2024 2:01 pm
Charge port install in 3:50 single take - in sport climbing we'd call it onsight :)
Posted: Sat Mar 30, 2024 2:34 pm
by Gregski
VW MK1 Outlander Battery Charger Install DIY EV Part I
Posted: Sat Mar 30, 2024 2:57 pm
by Gregski
~ OR ~
Posted: Sat Mar 30, 2024 4:27 pm
by Jacobsmess
johu wrote: Sat Mar 30, 2024 2:01 pm Charge port install in 3:50 single take - in sport climbing we'd call it onsight :)
That puts me firmly in the multi year projecting parallel....
Posted: Sat Mar 30, 2024 4:37 pm
by Gregski
It's a Polack thang...
Posted: Sat Mar 30, 2024 4:42 pm
Gregski wrote: Sat Mar 30, 2024 4:37 pm It's a Polack thang...
I dont think you can trademark like that!
Shall i mention our Janja :)..?
Posted: Sat Mar 30, 2024 7:22 pm
Gregski wrote: Sat Mar 30, 2024 2:34 pm VW MK1 Outlander Battery Charger Install DIY EV Part I
There is enough space to put 2x OBCs there...
I tried to command two chargers by transmitting CP PWM signal... and it worked!
You could get yourself two phase charging... or 6kW single phase if you connect them to your AC fuse.
https://leafdriveblog.wordpress.com/202 ... l-part-ii/
There could be a problem with charger report or DCDC feedback signal. This is why i only used one DCDC.
Posted: Sat Mar 30, 2024 8:08 pm
Here you could observe how i managed to install Outlander OBCs.
https://leafdriveblog.wordpress.com/202 ... r-charger/
download/file.php?id=6896&mode=view
I used OEM mont points on the sd o the charger. I made several mounts and then pressed/adjusted them so i could simply bolt them to the car sheet metal. I used 3 mounting points just because plain level is described by 3 points...
You could even make a bar which would cross the empty space over the top of the charger and use it as 2 point mount. Then you could use another point from the sides...
Posted: Sun Mar 31, 2024 3:10 pm
by Gregski
First motor spin... [again]
always, sometimes, bench test first
the battery module is from a 2018 BMW 530e (same as the 330e)
throttle pedal is from a 2010 Honda Fit (cause I thought maybe the Prius one was whack, but turns out it is fine)
Posted: Sun Mar 31, 2024 9:12 pm
Oh what a happy Easter it will be.
Why, on Friday we thought she was dead. But on Sunday she rose again, and performed miracles for all to see!
Posted: Mon Apr 01, 2024 7:34 am
by Woodfie
Great work here, have just stumbled across your build..
For this spin up, think was a mention somewhere of changes made by forum folks.
Wondering if still using 2.05a code, or a mod to it?
Posted: Mon Apr 01, 2024 7:56 am
by rstevens81
There is a mod in the works (not by me Damian and others) that's going to fix the issues, so rather than potentially adding a bug and have an accident and the bad publicity that might be causes it would be prudent to wait for the fix.
Posted: Mon Apr 01, 2024 1:55 pm
by Gregski
Woodfie wrote: Mon Apr 01, 2024 7:34 am Great work here, have just stumbled across your build..
Yes I am still using 2.05A with a change to a parameter called tmpmmax = 300
I posted this specific issue under the OEM Specific Topics where some of the developers have chimed in
Gen 3 Prius Transaxle P410 Makes Clunky Noise
