Page 19 of 38
Posted: Sat Feb 20, 2021 2:17 pm
by Jack Bauer
Finally some progress. Just did a push to the repo.
-Fix ISA voltage bugs.
-Change to floats on ISA params.
-Add charge mode HV control.
-Add HV on/off via web interface for testing.
-Fix Leaf INVudc reading.
-Added kWh and Ah display from isa shunt.
Not tested in a car as yet due to weather. turned out my ripped off evtv isa functions were waaayy over complex so simplified those down quite a bit.
Thinking about testing Dilbert's regen code today gave me an idea that might get two birds with one inverter. I still have my diesel/electric rig in one piece from a previous experiment. Will link the video below in case anyone missed that classic. Basically its a 5hp Lister LT1 diesel engine and a Toyota Estima MG1 (belt driven MG). Now the LT1 has a massive flywheel sooo IF the prius inverter will accept the Estima MG1 then we can spin up that flywheel with the decompressor open on the engine and regen it back down. Then if that works kick the fuel on and "regen" the engine back in to the battery:) This way I stay warm and dry and get to breath engine exhaust.
Previous installment with openinverter sine control (pre foc) :
https://youtu.be/hYxxCOxyWM0
Posted: Sat Feb 20, 2021 3:08 pm
by Dilbert
The sounds good. I'd imagine even the flywheel would do the job. It would give us a good idea of what rpm the system can regen down to.
I was considering if even a flywheel could be added to the input shaft on the gearbox, to do something similar.
I'm still in the process of sourcibg a gen 3 inverter so I can try with the gen 2 transaxle.
Posted: Sun Feb 21, 2021 3:45 pm
by Jack Bauer
Charge mode now up and running and tested in the E46. Also ISA shunt data in float format is making sense. Think I'll add a delta voltage parameter.
Posted: Sun Feb 21, 2021 8:42 pm
by Alibro
Jack Bauer wrote: Sun Feb 21, 2021 3:45 pm Charge mode now up and running and tested in the E46. Also ISA shunt data in float format is making sense. Think I'll add a delta voltage parameter.
Are you trying to build a time machine JB? :D
Posted: Wed Feb 24, 2021 4:38 pm
by Jack Bauer
Well, we have a regen tester :
Some interesting lessons :
1) Seems we can run non gen3 motors with a gen 3 inverter (estima starter generator in this case) which seems to be a gen1 motor.
2)It made monster torque in fwd but almost none in rev so I broke out the grinder and welder instead of the c compiler.
3)Running at 150v in the video it cranked the living s%^t out of the LT1 with only a smidge of throttle
Next up : Lexus mgr in the blue E39:)
Posted: Wed Feb 24, 2021 4:49 pm
by mdrobnak
Nice!
Thanks for testing my start engine code for my M3 hybrid :D
Posted: Wed Feb 24, 2021 7:57 pm
by Dilbert
It will definitely spin a gen 2 transaxle then 😁
Posted: Sat Mar 13, 2021 2:14 pm
by Jack Bauer
Well following my test drive in the E46 last week I pushed a bug fix for the Leaf inverter RPM:) Now time for a dumb Damien software question (ddsq for short).
So I've been working on the model 3 pcs full bore the past week or so and finally have it charging. Now while waiting to see how we go about implementing a controller for the pcs I've been tidying up charge mode in the VCU. Now have HV on/off via web interface , digital input and CAN. In terms of the CAN I want to have the firmware look for a counter in the incoming message from the charger controller to give it a basic sanity check. Question is how do I do this? The send side is easy (even I can manage that) but how about receive ....
Posted: Sat Mar 13, 2021 3:07 pm
by Jack Bauer
Here are some connectors and Toyota part number for connecting to the Prius/Yaris gen 3 inverter. Still need to find the tails for the small signal wires and the resolver plug.
Posted: Sat Mar 13, 2021 4:02 pm
by Dilbert
Perfect, thanks for posting! So the repair wire is one of the main 12V/Ground connections to the inverter.
I'll see if i can identify a crimps for the smaller signal wires, i would guess the same crimp would be used for the resolver connector. I have measured the pitch of the connectors and they seem to be 3mm pitch. I guess from a manufacturing point of view they don't want to use too many different crimps, so they must be used in other connectors.
Posted: Sat Mar 13, 2021 4:49 pm
by Dilbert
The larger repair wire (82998-12440), is listed here:- https://www.ih8mud.com/tech/pdf/WireHar ... pairwi.pdf
Looks like this is the larger crimp terminal https://www.bmotorsports.com/shop/produ ... ts_id/1762
Sumitomo TS 2.3II Female Terminal
It says that its a 6mm pitch on the larger terminals.
Posted: Sat Mar 13, 2021 5:17 pm
by Dilbert
If the whole connector is Sumitono, the only crimp that seems close to the right pitch for the signal wires is the type 1.0II or 1.0III, which are 1.8mm wide...
Posted: Sun Mar 14, 2021 10:23 am
by EV_Builder
Jack Bauer wrote: Sat Mar 13, 2021 2:14 pm So I've been working on the model 3 pcs full bore the past week or so and finally have it charging. Now while waiting to see how we go about implementing a controller for the pcs I've been tidying up charge mode in the VCU. Now have HV on/off via web interface , digital input and CAN. In terms of the CAN I want to have the firmware look for a counter in the incoming message from the charger controller to give it a basic sanity check. Question is how do I do this? The send side is easy (even I can manage that) but how about receive ....
I would add an array to the software. (atleast its the simplest method i think if you have the memory available).
I use always some code convention for example
Pseude code so it wont build i guess...
darr_lastseq[ CANID ] = Last recieved seq number. //init the array with 255 to disable the check // or add an extra VAR with the setting on / off..
darr_seqbytenr[ CANID ] = simlpe storage of the byte number containing the seq number. //init the array with 255 to disable the check..
darr_seqbytemask[ CANID ] = simlpe storage of the bytemask containing the seq number. //this value will be && with the databyte..
Now in the code you have everything available.
If you send me the code or a link i can implement it for you.
Regards,
Posted: Sun Mar 14, 2021 12:12 pm
by Dilbert
Here's the Pinouts for the GEN3 Toyota Inverters, we will probably move these over onto the wiki when there is some time.
Posted: Sun Mar 14, 2021 1:31 pm
by Jack Bauer
@EV_builder Thanks for the offer. Code is here : https://github.com/damienmaguire/Stm32-vcu
charger.cpp has the receive subroutine.
@Dilbert yeah lets start putting this on the wiki. I have a sneaky suspicion the gen 3 inverter will drive any Toyota motor...... Don't want to say that too loud or I'll get mobbed by even more emails:)
Just did a commit with the charge hv request over can implementation. Tested in the Grey Goose.
Posted: Sun Mar 14, 2021 4:12 pm
by EV_Builder
@Jack_Bauer:
Ok i did a simple version first for now...
We could always make a better full blown gui choice thing etc.
Also we could let the method return the error (void becomes a bit) but since HV was not done that way i thought i join the class var way of doing it.
charger.cpp:
#include <charger.h>
bool chargerClass::HVreq=false;
bool chargerClass::CAN_108SeqError = false; //we boot with no errors
static uint8_t counter_109 = 0;
//Simple counter check
//Configure here the 108 message properties
static uint8_t lastseqcntr_108 = 255; //empty on startup
static uint8_t bytenrseq_108 = 7;
static uint8_t bytemask_108 = 0xFF;
void chargerClass::handle108(uint32_t data[2])  //HV request
	CAN_108SeqError = true; //we program write false == save
	uint8_t* bytes = (uint8_t*)data;// arrgghhh this converts the two 32bit array into bytes. See comments are useful:)
	uint8_t seqnr = (bytes[bytenrseq_108] & bytemask_108); //here we AND the data with the mask to write the result in the local seqnr var.
	if (bytes[0] == 0xAA) HVreq = true;
	if (bytes[0] == 0xCC) HVreq = false;
	if (lastseqcntr_108 == 255) {
		lastseqcntr_108 = seqnr; //if we are 255 we are just booted (this shoudn't be a normall counter value normally its 0-15 (16 messages);
	else {
		if ( (lastseqcntr_108 == 15)  && (seqnr ==0) ) { //special case we expect now 0 in byte 7 (clock overrun??)
		else if ((lastseqcntr_108 + 1 ) == seqnr) { //if we increase the previous value by one we should match the bytes7 value...
We should check in the main program who calls this function if the bit is set after each call and then set the according error bit in the general error layer.
Let me know if this is too lean :)
EDIT: If you are not sure if we recieve all CANBUS messages we could implement easily a count down counter instead of the bool.
Then it would be a bit more forgiven.
Posted: Sun Mar 14, 2021 6:14 pm
by mdrobnak
Jack Bauer wrote: Sun Mar 14, 2021 1:31 pm @Dilbert yeah lets start putting this on the wiki. I have a sneaky suspicion the gen 3 inverter will drive any Toyota motor...... Don't want to say that too loud or I'll get mobbed by even more emails:)
Ya know, I wondered that. Can we drive the GS450h with a Prius inverter over serial? The Gen 3 is a bit more compact than the Lexus / Camry inverters, no? (Thinking for my hybrid conversion, trying to stuff things in as little space as possible....)
-Matt
Posted: Mon Mar 15, 2021 9:06 am
by Dilbert
Have the Yaris converter hooked up ready to test later in the week. I didn't have the correct connectors so made do with lots of 2 way JST connectors.
Posted: Mon Mar 15, 2021 6:27 pm
by Jack Bauer
Excellent. My next move in the gen3 scene is to see if it will spin the MGR:)
Posted: Tue Mar 16, 2021 3:26 am
by arturk
I just couldn't wait any longer and had to test Dilbert's regen implementation from one of the earlier posts.
Success! I was able to get over 50 amps of regen in during braking with small amount of negative torque.
I had to adopt code slightly for my VCU v.2 Arduino code because I do not have VCU v.3 board.
Anyways looks like approach is solid however some tuning may be necessary.
I am going to keep working on it.
Posted: Tue Mar 16, 2021 9:26 am
by Dilbert
arturk wrote: Tue Mar 16, 2021 3:26 am I just couldn't wait any longer and had to test Dilbert's regen implementation from one of the earlier posts.
Perfect ;-)
Yea i was trying to develop something that could work for a simple on/off condition with the brake or a more complex brake position sensor. I was also trying to model engine braking. So if no throttle is applied, you get engine braking, when brake pressed it moves to the higher level of braking.
Most importantly i want the brake to have priority over the throttle, something which my Auris doesn't do at one particular point in the cycle.
Posted: Wed Mar 17, 2021 12:15 am
by Dilbert
Quick question, does the normal bootloader work on the zombie ecu? Or does it need some changes for this cpu?
Posted: Wed Mar 17, 2021 8:00 am
by Jack Bauer
Bootloader is different due to 2k page size on the 105. Will upload later. Meanwhile here is a hex.
Posted: Wed Mar 17, 2021 10:05 am
by Dilbert
Perfect thanks for that, I'll give that a go. I was able to use the STM32 programmer anyway.
I got the Yaris converter connected up and it seems to be outputting a larger MTH frame, which is 2.8mS long rather than the 2.4mS. I haven't had a chance to connect up the FTDI Cables yet, but this to me would mean that the MTH frame has increased from 120 bytes to 140 bytes on the Yaris.
The part number of the yaris inverter i have is G9200-52031, i knew i should have got the Auris one, but this one was too cheap to pass up!
Posted: Wed Mar 17, 2021 10:14 am
by Dilbert
OK so i bumped up the MTH frame from 120 to 140 bytes and i now have valid frames coming in from the yaris inverter!
The only question is, if the have added extra bytes to MTH have they done the same with HTM also, or is that still 100 bytes.
Lexus GS450 is 80 / 100
GEN3 Prius is 100 / 120
Yaris is ? / 140
