Page 3 of 5
Re: Nissan Leaf Powered E46 Touring
Posted: Sat Aug 24, 2019 4:45 pm
Yeeha :D what gear is that?
Posted: Sat Aug 24, 2019 5:12 pm
second and third
Posted: Sat Aug 24, 2019 10:31 pm
by johnspark
Very nice.
Posted: Sun Sep 08, 2019 3:26 pm
Posted: Sat Nov 09, 2019 10:54 am
Damien On DIY forum i noticed someone is working on Leaf car power augmentation :).
From Ampera (2013 Volt) i know when you apply sport mode you actually dont increase power. What this does is shift throttle curve to provide more torque at lower end of the RPM. The car seems more powerfull that way and in the end you dont need much torque at the 10KRPM to step over 80kW limit.
So there it is your solution for low end power.
1. Put a CAN filter uC on CAN lines between brain and inverter.
2. Filter out the torque demand IDs. Those are published.
3. After filter connect one uC that will read throttle position and calculate what data MSG to output.
4. Test drive!
Maybe you could get away with not cutting the wires. You would just have to time nonsuspecting CAN ID of torque and transmitt the CAN ID with your data just before so inverter decides to listen to yours instead of original. I think there is some requirement how fast throttle signal is transmitted. If you send duplicate ID original will get filtered out as an echo...
Since your BMW now drives i wanted to ask you if you could verify/confirm something. Could you add another controller behind your original and transmitt torque ID that would be higher than original? This signal would have to be timed some ms before original. I would like to know if inverter will remove or blanket original CAN ID as an echo?
tnx
Posted: Sat Nov 09, 2019 12:02 pm
by JaniK
arber333,
I have been actually wondering if it would be possible to add low end torque to an actual Leaf by putting a middle man module just before the inverter. That would only have task to add torque in lower speeds.
I actually have a 2014 leaf for daily driver and there is much more acceleration to be gained by adding some torque in speeds of 5-50kmh. Without going over 80kW (there are actually original japanese market only Nissan VCM out there that has different torque curves)
Regarding speed 5-50kmh, there is no sense in putting all torque
available at once when standing still. Unless you just want to spin the wheels..
Posted: Tue Jan 28, 2020 6:12 pm
Small update on the E46 touring. Front battery box fitted and currently working out mounting for the Model 3 PCS (charger and dcdc in one).
Posted: Tue Jan 28, 2020 6:33 pm
by JaniK
Looks great!
Thumbs up for this project :)
Posted: Fri Jan 31, 2020 5:44 pm
by Kevin Sharpe
The Grey Goose was inspected and passed by an automotive engineer today... next steps include changing the taxation class to electric drive, NCT, and testing on track and road 8-)
Posted: Fri Jan 31, 2020 5:48 pm
Seems today is a good day :) Congratulations!
Posted: Fri Jan 31, 2020 6:03 pm
by Kevin Sharpe
Posted: Fri Jan 31, 2020 6:54 pm
by xp677
Let me know if you need code and/or schematics for control of the Eberspaecher heater, I have some provisional code for my project which uses the same heater.
Posted: Sat Feb 01, 2020 1:24 am
by Igor
Good work. There was some discussion about these heaters in this thread: viewtopic.php?f=9&t=335&start=20
Posted: Sat Feb 01, 2020 6:29 pm
by Kevin Sharpe
Igor wrote: Sat Feb 01, 2020 1:24 am Good work. There was some discussion about these heaters in this thread: viewtopic.php?f=9&t=335&start=20
I've moved the generic posts re heaters here;
viewtopic.php?f=9&t=335&start=30#p5957
Posted: Sun Feb 16, 2020 11:39 am
by Kevin Sharpe
The car is now taxed as an electric vehicle (cost €120 p/a) with the automotive inspection/report process working like a dream :)
Posted: Sun Feb 16, 2020 3:44 pm
by JaniK
So it is on the road now :) thumbs up!
Posted: Thu Mar 12, 2020 6:03 pm
Some good work today. Pcs is mounted and secure as is the high voltage junction box.
Need some help locating two components. The 12v high current plug and a european AC connector plug. As my pcs was US I only have the single phase connector plug. The ones pictured do not belong to me so I cant butcher them:)
Posted: Sat Mar 21, 2020 1:14 pm
by Kevin Sharpe
Lots work on Grey Goose this week... the front and rear batteries are now strapped down and the Tesla PCS testing will commence once the last of the cooling system components arrive 8-)
Posted: Fri Mar 27, 2020 6:01 pm
The Goose now has cooling thanks to a BMW E90 electric pump. HV junction box is done and car now precharging and starting and driving. Also does a mean donut:) Next up is PCS controller programming to get the dcdc and charger functions working.
Posted: Fri Mar 27, 2020 6:50 pm
by zippy500
HV box looks good'
What is white unit wire in series with the pre-charge resister
Posted: Fri Mar 27, 2020 7:55 pm
by Kevin Sharpe
Jack Bauer wrote: Fri Mar 27, 2020 6:01 pm Also does a mean donut:)
It sure does :D
https://twitter.com/EvBmw/status/124355 ... 28066?s=20
Posted: Sun Aug 09, 2020 6:38 pm
by Kevin Sharpe
Lots driving in circles today as the New Electric course participants attempted to break Damiens motor-gearbox coupler and fry the inverter :)
https://twitter.com/NewElectricIRL/stat ... 13793?s=20
Posted: Tue Aug 25, 2020 3:31 pm
by Kevin Sharpe
Posted: Tue Aug 25, 2020 5:45 pm
by clanger9
I take it the "reverse burnout" was un-intentional... 8-)
Posted: Tue Aug 25, 2020 6:08 pm
by Kevin Sharpe
clanger9 wrote: Tue Aug 25, 2020 5:45 pm I take it the "reverse burnout" was un-intentional... 8-)
No, we wanted to see who on the course would bottle out first :D
