Page 3 of 5
Re: Mercedes-Benz B Electric - motor support
Posted: Mon Oct 19, 2020 6:52 am
by mohalkh
leman2112 wrote: ↑Sun Oct 18, 2020 3:08 am
This is awesome! So I do not need a special board like the tesla and mercedes inverter both have? I can just add the few cables I am missing to the jst connector and make sure they are all the same length as the mercedes harness and solder them all straight to my female ampseal female connector? No special connector board needed? I really kinda thought that the connector board might of had some type of purpose but obviously I am definitely a super noob right now. I got a feeling it's gonna work soon enough! Thanks again friends!
can't wait to see the final result which you will get, could you share the CAN connection that you will have when you finish?
Posted: Mon Oct 19, 2020 1:38 pm
by leman2112
Sure bud! Today I finally figured out a way to get my 23pin ampseal 90 degree female connector mate to the male connector. The plastic prongs on the edge on the inside did not line up so I took a really tiny file and sawed it all the way down and now they fully connect together.
Posted: Mon Oct 19, 2020 1:41 pm
by leman2112
This 90 may give me the clearance I need to close the case according to Tomdb. Might not hit the phase terminals. Excited to finish my harness, solder the cables to the 23 pin connector 90 degree and see if it will fit.
Posted: Mon Oct 19, 2020 1:43 pm
by leman2112
Should probably watch some YouTube videos on how to solder small cables. Only ever soldered big cables on my electric car. Got an old weller soldering iron my dad had.
Posted: Sat Oct 24, 2020 1:22 pm
by mohalkh
leman2112 wrote: ↑Mon Oct 19, 2020 1:43 pm
have this worked on Mercedes b250e, if so, could you just share the connection that you got, please?
Posted: Sun Oct 25, 2020 10:32 pm
by leman2112
tom91 wrote: ↑Wed Jun 12, 2019 8:56 pm
It has its full power, Zero-EV has had multiple motors and we can confirm the RAV-4 or B-class motors are electrically identical to Tesla Model S units.
This guy did it from zero ev outta Bristol England I think.
Posted: Sun Oct 25, 2020 10:34 pm
by leman2112
leman2112 wrote: ↑Sun Aug 23, 2020 1:26 pm
Ok think I ordered the right female connector with the 90 degree header just like Isaac and Tom have recommended. The picture on the website looks like it makes the 90 degree bend! I am so stoked! Thank you electric friends!
https://www.mouser.com/ProductDetail/TE ... WvWw%3D%3D
This is the one I bought
Posted: Fri Oct 30, 2020 2:07 am
by leman2112
Also need to modify the JST connector on the end of the harness so that it will except the extra wires that are required for a tesla style 23 pin ampseal connector.
Connector for the logic boards is: JST 24CPT-B-2A
Pins are: scpt-a021gf-0.5
Posted: Mon Nov 09, 2020 9:48 pm
by leman2112
So I made some more progress. My belden 22 AWG cables came. Must say the quality of the original Mercedes Harness seem like better cabling. I can count like 8 strands on the belden and the mercedes had like 20 strands. Hmmmm anyone know a more similar cable brand to go with? Kinda want the same stuff.
Posted: Mon Nov 09, 2020 10:14 pm
by leman2112
Also trying to figure out the order of the pinouts. The diagrams that are given dont exactly describe the order in my brain yet? Derp... do I just read 1-20 left to right top to bottom just like a book?
Also realized that the harness makes a total twist on my zero ev harness that I bought to help use as a referance.
Posted: Mon Nov 09, 2020 10:18 pm
by leman2112
Top to bottom left to right?
Posted: Mon Nov 09, 2020 10:59 pm
by leman2112
Top to bottom, left to right?
Posted: Tue Nov 10, 2020 10:39 am
by muehlpower
By the way, if you had bought the black plug, the coding would also match!
Posted: Fri Nov 13, 2020 6:18 pm
by leman2112
Alright awesome Thanks for the ordering of the pinouts! Yeah the black one plugs right in just doesnt have the 90° angle that will help the connector stay clear of the inverter terminals.
Posted: Fri Nov 13, 2020 6:32 pm
by muehlpower
TE Connectivity AMPSEAL part 776087-1
Posted: Mon Nov 16, 2020 10:47 pm
by leman2112
How is the pinout for this JST connector ordered? Like this?
Want to start soldering but dont want to connect them to the wrong pins.
Posted: Tue Nov 17, 2020 1:04 am
by leman2112
muehlpower wrote: ↑Tue Nov 10, 2020 10:39 am
What is the coding?
Posted: Thu Nov 26, 2020 9:34 pm
by leman2112
https://www.lifewire.com/atx-24-pin-12v ... ut-2624578
Ok think I found the proper order of the pinouts possibly for the jst connector.
Posted: Thu Nov 26, 2020 10:04 pm
by leman2112
actually I don't think this has anything to do with the jst connector. Darn. Still on the hunt.
Posted: Tue Dec 08, 2020 7:52 pm
by leman2112
Think I got it figured out. Just gonna need to look at the logic board and I bet I will understand the pinout finally.
Posted: Thu Dec 10, 2020 2:21 pm
by leman2112
Ok I think I got the pinout ordering now that I have a visual on the back of the JST connector and the chart provided to me from you guys. Thanks.
Posted: Thu Dec 10, 2020 2:40 pm
by leman2112
It looks like I got this figured out.
Posted: Sun Dec 13, 2020 5:48 pm
by PatrcioEV-ATX
tom91 wrote: ↑Tue Dec 24, 2019 11:59 am
Jack Bauer wrote: ↑Tue Dec 24, 2019 10:04 am
I believe ZeroEV sell a new connector and cable.
Yes and No.
Both do not fit from factory;
Connector: you need to modify the case a bit, not hard just tedious.
Cable: Current one in stock is too short, as the motor is clocked different it needs to be almost twice as long.
Tom-
1. Assuming one modifies the case to make the ZeroEV replacement connector work
AND they used the ZeroEV loom (let’s assume it’s long enough for a moment), this would work with the EVBMW board?
2. Could one use two ZeroEV looms joined by a male/male connector? (just for ease and speed over creating new loom)
3. Does anyone know if the extra pins on the MB connector are to operate the parking pawl?
Posted: Sun Dec 13, 2020 7:22 pm
PatrcioEV-ATX wrote: ↑Sun Dec 13, 2020 5:48 pm
Yes and No.
Tom-
1. Nope, replacement connector board DOES NOT fit physically even after modifying the connector hole on the case. The connections are rotated compared to a Tesla motor.
Posted: Wed Dec 16, 2020 5:16 am
by Jrod
I have a Mercedes Ldu motor and swapped the wiring to match damien's Ldu board. I added a shielded 8 wire lead into inverter housing using waterproof gland nut. I have a crossover chart for making the correct connections to the jst plug.
