prius gen2 mg1 + honda ima
Has thanked: 413 times
Been thanked: 118 times
Re: prius gen2 mg1 + leaf invertor gen2 + honda ima
Post by Jacobsmess »
Romale wrote: Sun Nov 05, 2023 10:23 am hi. this motor = generator from prius gen 2. there is no welding, only a grinder and a little patience. according to the inverter, I sawed off part of the board in vain, it does not work well with external DC / dc to power the drivers. look at my other topic, where the ima inverter is affected, there are pictures of how to use it. this is a wonderful inverter and it works even from 520 volts!!!
Interesting, do you have any before and after pics? Was it quite straight forward to cut it down? What would you recommend as a setup to have a 3rd motor controlling the input shaft on a lexus gearbox CVT?
