Page 3 of 4
Re: Der Panzer Tesla Powered BMW E31
Posted: Thu Jun 27, 2019 6:26 pm
by sonachan1
Looks good Mr Bauer!
I was also thinking maybe we could get BT functionality into Johannes' BMS at some point. The TorquePro app looks quite good.
Posted: Sat Jun 29, 2019 11:00 am
by Jack Bauer
Making nice progress on the bms :
BMS Status : 5 Error | AC Present | 96
Out:0000 Cont:0000 In:0010
Modules: 13 Cells: 96 Strings: 1 Voltage: 366.714V Avg Cell Voltage: 3.816V Low Cell Voltage: 3.547V High Cell Voltage: 3.845V Delta Voltage: 298mV Avg Temp: 0.131C
Module #1 23.01V Cell0: 3.84V Cell1: 3.83V Cell2: 3.84V Cell3: 0.00V Cell4: 3.84V Cell5: 3.83V Cell6: 3.84V
Temp 1: 15.64
Module #2 30.70V Cell7: 3.84V Cell8: 3.84V Cell9: 3.84V Cell10: 3.84V Cell11: 3.84V Cell12: 3.84V Cell13: 3.84V Cell14: 3.84V
Temp 1: 15.57
Module #3 30.71V Cell15: 3.84V Cell16: 3.84V Cell17: 3.84V Cell18: 3.84V Cell19: 3.84V Cell20: 3.84V Cell21: 3.84V Cell22: 3.84V
Temp 1: 16.09
Module #4 30.70V Cell23: 3.84V Cell24: 3.84V Cell25: 3.84V Cell26: 3.84V Cell27: 3.84V Cell28: 3.84V Cell29: 3.83V Cell30: 3.84V
Temp 1: 17.19
Module #5 30.72V Cell31: 3.84V Cell32: 3.84V Cell33: 3.84V Cell34: 3.84V Cell35: 3.84V Cell36: 3.84V Cell37: 3.84V Cell38: 3.84V
Temp 1: 15.54
Module #6 30.70V Cell39: 3.84V Cell40: 3.84V Cell41: 3.84V Cell42: 3.84V Cell43: 3.84V Cell44: 3.84V Cell45: 3.83V Cell46: 3.84V
Temp 1: 15.64
Module #7 30.69V Cell47: 3.84V Cell48: 3.84V Cell49: 3.84V Cell50: 3.84V Cell51: 3.81V Cell52: 3.84V Cell53: 3.84V Cell54: 3.84V
Temp 1: 17.10
Module #9 30.71V Cell55: 3.84V Cell56: 3.84V Cell57: 3.84V Cell58: 3.84V Cell59: 3.84V Cell60: 3.84V Cell61: 3.82V Cell62: 3.84V
Temp 1: 14.11
Module #10 30.68V Cell63: 3.84V Cell64: 3.84V Cell65: 3.84V Cell66: 3.84V Cell67: 3.84V Cell68: 3.80V Cell69: 3.84V Cell70: 3.84V
Temp 1: 14.96
Module #11 30.67V Cell71: 3.82V Cell72: 3.81V Cell73: 3.84V Cell74: 3.85V Cell75: 3.84V Cell76: 3.84V Cell77: 3.83V Cell78: 3.83V
Temp 1: 16.97
Module #13 22.73V Cell79: 3.83V Cell80: 3.84V Cell81: 3.84V Cell82: 0.00V Cell83: 3.74V Cell84: 3.74V Cell85: 3.74V
Temp 1: 13.66
Module #14 22.24V Cell86: 3.74V Cell87: 3.74V Cell88: 3.55V Cell89: 0.00V Cell90: 3.74V Cell91: 3.74V Cell92: 3.74V
Temp 1: 14.37
Module #15 22.44V Cell93: 3.74V Cell94: 3.74V Cell95: 3.74V Cell96: 0.00V Cell97: 3.74V Cell98: 3.74V Cell99: 3.74V
Temp 1: 16.84
Low Range 16339.73mA 93% SOC 42227.88mAh
Posted: Sat Jun 29, 2019 4:47 pm
by tom91
Oh its counting your SOC :D
Coding is still a bit basic, there is no drift for miss counting except at the very top end.
Wonder how close the SimpBMS is to your other system.
Posted: Mon Jul 01, 2019 8:11 pm
by arber333
Jack Bauer wrote: Wed Jun 26, 2019 5:35 pm Thanks Arber. I have done just that.
I just found out i still have some code from Dimitri that is using BT with Torque pro. If you like you can program your chip with it and try to use torque :).
I use USBASP programmer with AVRDUDE software. There is 6 pin header on the board, I use pogo pins, but you can solder pin header or whatever you want. I use these command lines as example, first one unlocks security bit and sets fuses, second flashes code and locks it
avrdude.exe -F -Cavrdude.conf -v -patmega328p -P usb -c usbasp -e -Ulock:w:0x3F:m -Uefuse:w:0x05:m -Uhfuse:w:0xDA:m -Ulfuse:w:0xFF:m
avrdude.exe -F -Cavrdude.conf -v -patmega328p -P usb -c usbasp -Uflash:w:SOC_Gauge_V4_TQ_450V.hex:i -Ulock:w:0x0F:m
There are two codes in rar file. one is normal AT serial code, the other is TQ code.
Also my board is set to max 350Vdc so i use external 500K trim pot set at 325K and i get correct voltage.
Posted: Thu Nov 07, 2019 10:18 am
by Kevin Sharpe
some nice views of Der Panzer at Fully Charged Live (start at 4:46) 8-)
Opensource also gets a shout out at 6:40 :D
Posted: Fri Nov 29, 2019 11:20 pm
by Kevin Sharpe
very shiny Panzer getting ready for a magazine photo shoot :D
Posted: Sun Dec 01, 2019 11:11 pm
by Kevin Sharpe
"Today’s shoot for Performance BMW was unusual..."
https://twitter.com/pmcgphotos/status/1 ... 96323?s=20
Posted: Thu Dec 05, 2019 7:34 pm
by Igor
Nice! Looking forward to more shots.
Posted: Sat Aug 15, 2020 12:12 pm
by Kevin Sharpe
Fabulous article in SpeedHunters magazine 8-)
Converted: The Tesla-Powered BMW 8 Series (here)
When I asked Damien if there was any advice he would give to others who are also interested in going electric, he said this: “This is all stuff that you can do in your shed or at home as safely as wiring a plug or working on a high pressure fuel system. You still get your hands dirty. They’re still cars.”
Posted: Sat Aug 15, 2020 2:32 pm
by RetroZero
Awesome report. Pat on the back Damien. Looking very smart 👌
Posted: Sat Aug 15, 2020 6:47 pm
by P.S.Mangelsdorf
Kevin Sharpe wrote: Sat Aug 15, 2020 12:12 pm When I asked Damien if there was any advice he would give to others who are also interested in going electric, he said this: “This is all stuff that you can do in your shed or at home as safely as wiring a plug or working on a high pressure fuel system. You still get your hands dirty. They’re still cars.”
That's a great quote.
Posted: Sat Aug 15, 2020 7:51 pm
by JaniK
Wow cool writeup on speedhunters! Congratulations Damien!
Posted: Sun Aug 16, 2020 7:54 am
by Jack Bauer
Thanks folks. I'm still in quite a bit of shock about it. The article was originally supposed to appear in Performance BMW magazine but I guess the grinder cut, mig welded mild steel didn't exactly spin their turbine. Having it on Speedhunters feels like winning the lottery:)
The comments offer an interesting insight into the pervasive myths that still surround conversions. "Informed ignorance" I call it. Goes like this :
" I know xxx about ev conversion, therefore I have no reason to test to see if xxx is actually true".
Sort of like an anti scientific method:)
Posted: Sun Aug 16, 2020 10:38 am
by Lwerewolf
Major grats for the speedhunters article! Getting it out there :)
Posted: Sun Aug 16, 2020 12:23 pm
by TheSilverBuick
Saw the article on Twitter, good stuff!!
Posted: Sun Aug 16, 2020 12:48 pm
by TFirenza
so good, congrats !
Posted: Sun Aug 16, 2020 2:24 pm
by Maker_of_Things
I found and read the article last night.
Really well done! :D
Posted: Wed Mar 31, 2021 7:46 am
by Jack Bauer
Checkout this months Perfromance BMW magazine:)
Posted: Wed Mar 31, 2021 6:11 pm
by nkiernan
Class, love that car and the whole Panzer project :D
Posted: Thu Nov 10, 2022 8:58 am
by Jack Bauer
Almost lost the Panzer last weekend :
Posted: Thu Nov 10, 2022 9:15 am
by nkiernan
Jack Bauer wrote: Thu Nov 10, 2022 8:58 am Almost lost the Panzer last weekend :
Bit of an eye opener this video!!! Thanks for sharing. Glad to hear we're going to see more of the Panzer soon though, this is the car that started me on my conversion journey, all 113 panzer youtube videos over two weeks (nearly got evicted for it) :D and great to see it in the flesh at the conversion course
Posted: Thu Nov 10, 2022 2:31 pm
by janosch
Jesus! Glad you are OK!
Posted: Thu Nov 10, 2022 5:27 pm
by mark
Scary stuff! Glad to see it resulted in minimal damage. As you said, very lucky indeed. Looking forward to v2, and how it's put together with the current options available.
Posted: Thu Nov 10, 2022 5:38 pm
by tom91
Wait you just had them under the car and not enclosed? Must have been corrosion or something into the plug wiring.
Posted: Thu Nov 10, 2022 6:59 pm
by Ev8
Wow, sorry to hear what happened but yes so lucky you were there to catch it, have you considered reconfiguring the ampera pack for additional solar storage?
