Re: 11KW StreetScooter charger group hack
Posted: Tue Oct 29, 2024 8:04 pm
openinverter Community
https://openinverter.org:443/forum/
# Convert the BLF File Format to SavvyCAN CSV format
# This script requires the python-can module to work:
# python -m pip install python-can
# Author: crasbe, 2024
import can
import csv
# Object Format of a CAN message
# can.Message(timestamp=1677163869.3135324, arbitration_id=0x258, is_extended_id=False, channel=1, dlc=8, data=[0x0, 0x5e, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0])
blfFile = can.BLFReader("2023-02-23_15-51-05_Run062_Performance_B-ON_S17-06_MaxBox_Prod.blf")
with open("output.csv", "w", newline="") as csvfile:
csvOutput = csv.writer(csvfile)
csvOutput.writerow(["Time Stamp","ID","Extended","Dir","Bus","LEN","D1","D2","D3","D4","D5","D6","D7","D8"])
for msg in blfFile:
line = ["{:016d}".format(int(msg.timestamp * 10**6)), "{:03X}".format(msg.arbitration_id), \
str(msg.is_extended_id).lower(), "Rx", msg.channel, msg.dlc]
for i in range(0, 8): # not all messages are 8 bytes long
if (i < msg.dlc):
line.append("{:02X}".format(msg.data[i]))
else:
line.append('')
line.append('') # SavvyCAN puts an empty row in each data line, so we have to do it too
csvOutput.writerow(line)Code: Select all
ID: 007, Magic Bytes: 0xE8,
ID: 00A, Magic Bytes: 0x2C,0x7F,0x8A,0xD9,0x35,0x66,0x93,0xC0,0x1E,0x4D,0xB8,0xEB,0x07,0x54,0xA1,0xF2,
ID: 185, Magic Bytes: 0x06,
ID: 205, Magic Bytes: 0x51,0x3D,0x40,0x5C,0xC2,0xC9,0x52,0xAB,0x16,0x00,0x5E,0xAE,0x83,0xA2,0x1D,0x18,0xED,0x54,0x3B,0x23,0xAB,0x17,0xB0,0x72,0x0A,0xF2,0x8D,0x72,0x43,0x80,0x04,0x17,0x26,0x21,0xE2,0x7B,0x03,0xD2,0xE3,0x9B,0x27,0x3F,0x45,0x31,0x44,0x1C,0xB2,0x81,0x6F,0x93,0x97,0xAB,0xFD,0xB1,0x27,0xDC,0x9E,0xFD,0xED,0xB7,0x3A,0x0C,0xD7,0xA7,0x0D,0x62,0xBA,0xC5,0xAC,0x6D,0xDC,0xC5,0x49,0x3D,0x2B,0xF0,0x3A,0x93,0xD4,0x22,0xA4,0x55,0x01,0x7D,0x48,0x99,0xCC,0x75,0x6A,0x98,0x8C,0x65,0x93,0xDD,0x21,0x2A,0x08,0x4B,0x25,0x80,0x31,0xC1,0x2D,0x65,0x8C,0x1A,0x73,0xF0,0xCE,0x09,0xBA,0xD8,0x18,0x46,0x79,0x1E,0x42,0x7A,0x6F,0x33,0xB9,0x6F,0x0A,0x80,0x4B,0x99,0xF8,
ID: 208, Magic Bytes: 0xE8,0x29,0x4A,0x3F,0xC6,0x2A,0x98,0x37,0x1C,0xD8,0xB3,0xB6,0x24,0x98,0xA6,0x44,0x10,0x98,0x3D,0x32,0x41,0x9F,0x0F,0xFB,0xEB,0x4E,0x64,0x9A,0xAF,0x25,0x76,0x90,0xE2,0xF7,0x12,0xFB,0xEB,0x72,0x52,0xE2,0x9B,0xDE,0xF5,0xBA,0x28,0xCA,0xF2,0x66,0x6D,0x99,0xCA,0xFF,0x39,0xE6,0x5A,0x61,0x79,0x04,0x82,0x11,0x0A,0x27,0xE1,0x7D,0xBF,0x42,0x89,0x8A,0x98,0x3E,0xF7,0x49,0x97,0xC3,0x2A,0xF4,0x15,0x07,0x0A,0xFB,0xA1,0x9E,0xE4,0xF2,0xA0,0x05,0x12,0x4F,0xDD,0xC7,0x52,0x3F,0x08,0x38,0x95,0x3D,0x6A,0xD3,0x82,0x7A,0x5E,0x06,0x3E,0xE4,0x3B,0xF1,0x27,0xC8,0xF0,0xD8,0xB1,0xC3,0xF3,0x84,0x2B,0x50,0x52,0xC2,0x21,0x5A,0xFE,0xC5,0x26,0x36,0xBF,0xEC,0x79,0xD0,0x32,0xAE,0x83,0x58,0x17,0x28,0x8C,0x2B,0x67,0x69,0x9A,0x48,0x39,0x21,0x4B,0x9C,0xF6,0x0C,0x3C,0x48,0xEF,0x3C,0x2A,0x1E,0x5E,0xF9,0xAF,0x25,0xBC,0x5F,0xF9,0x11,0xE0,0x2E,0xA6,0x8A,0x33,0xA5,0xA2,0x03,0xFC,0x44,0xD1,0x86,0x2C,0xB4,0xB2,0xC7,0xEC,0xB3,0x06,0x24,0x10,0xF6,0x07,0xE9,0x7D,0x30,0xB1,0xE5,0x6E,0x3F,0xE2,0xE3,0xD8,0x19,0xDF,0x56,0x4A,0x21,0x5C,0x16,0x64,0xC4,0xC1,0x53,0xE3,0xFD,0xFC,0x03,0x0E,0x63,0xDE,0x80,0x8C,0x66,0x8B,0x1D,0x70,0x47,0x2B,0x4F,0xEA,0x7F,0x0F,0x01,0x3F,0xB2,0xC3,0x71,0xC3,0xAD,0x9C,0x58,0xF0,0x8C,0x10,0x4C,0x41,0x71,0xAC,0x41,0x5E,0x5E,0xFF,0x76,0x12,0x8C,0x2C,0x04,0x58,0xB8,0x2A,0xAB,0x65,0xF5,0x96,0xED,
ID: 218, Magic Bytes: 0xD0,
ID: 255, Magic Bytes: 0xE8,
ID: 258, Magic Bytes: 0xE8,0xB9,0x8A,0x7E,0x6A,0x9E,0xAD,0xDF,0x39,0xD4,0xE7,0x13,0xA2,0xF3,0xC0,0x8E,0xE7,0x20,0xD4,0x46,0x44,0xD2,0x7C,0x9F,0xBB,0xEA,0x1D,0x1A,0x4B,0x50,0xA4,0x97,0x63,0xF1,0x05,0x36,0x23,0x11,0xEA,0x5E,0x0E,0x9C,0xFB,0x5B,0xCA,0x01,0x7E,0x4D,0xDC,0xAF,0x7A,0x89,0xBD,0xE7,0x36,0xE1,0xCB,0x59,0x17,0x79,0x75,0xD2,0x26,0x8A,0xD5,0x50,0x87,0x32,0x59,0xBF,0x01,0x78,0x8C,0xBF,0x54,0xD9,0x88,0x08,0xDF,0xCF,0x3B,0x8A,0xF8,0x4D,0xB9,0x65,0xCC,0xFA,0x56,0x32,0x5C,0x03,0xF7,0xD1,0x9E,0x5C,0x7A,0xE8,0xC0,0x36,0x07,0x24,0xFA,0x54,0x17,0x85,0x44,0x61,0x77,0x93,0xE1,0xF1,0xA0,0x32,0xC6,0xB3,0x01,0xFE,0x0A,0x39,0xCD,0x5F,0xAB,0x98,0x6C,0xF9,0x2E,0x3E,0x6F,0x58,0x09,0x9F,0x6B,0x94,0x60,0x76,0xA7,0x35,0xC1,0xF2,0x06,0x00,0xF4,0x12,0x10,0x82,0x53,0x45,0x14,0x4E,0xBA,0x89,0x7D,0xEF,0xBE,0x28,0xDC,0x62,0x24,0xA5,0x51,0xC3,0x92,0x04,0x53,0x0F,0x0D,0x6D,0x25,0xAE,0x5A,0x19,0xA1,0xB8,0x6F,0xDA,0x8B,0x3A,0xED,0xE2,0xDC,0xD5,0xD7,0xB7,0xE6,0x74,0x80,0x45,0xF5,0x16,0x14,0x04,0x76,0x31,0xB5,0x70,0xD7,0x8D,0xDA,0x69,0xBE,0xDA,0xCF,0x1D,0x3C,0x38,0x58,0xAC,0xB8,0x22,0xAA,0xA8,0xE5,0x55,0x90,0x73,0x00,0xA1,0x12,0x60,0x47,0x2A,0x19,0xFA,0xDA,0x2E,0x0A,0xE9,0xB3,0xF5,0xC8,0x80,0x05,0x43,0xD5,0x36,0xA1,0x42,0x45,0x92,0xF6,0xF4,0x62,0x33,0x3A,0x48,0x28,0xDC,0x6D,0x99,0x0F,0x62,
ID: 265, Magic Bytes: 0x94,
ID: 280, Magic Bytes: 0xE8,
ID: 285, Magic Bytes: 0x7F,
ID: 321, Magic Bytes: 0x7A,0x3D,0x1A,0x8C,0x7C,0x6B,0x7F,0x7F,0x20,0xF1,0x34,0x51,0xF4,0x52,0x0B,0x75,0xA8,0x9E,0x91,0x29,0xCD,0xF1,0xA2,0xEF,0xE5,0xAB,0x6E,0x67,0x4C,0x89,0x25,0xF1,0x62,0xF2,0x98,0xDC,0x61,0x85,0x92,0x7A,0x70,0x38,0xC1,0x68,0x4A,0xD6,0x80,0xC1,0x02,0x51,0x9D,0x83,0xF8,0xB9,0x9D,0x3D,0x51,0x10,0x23,0x02,0x04,0xFB,0xAD,0x37,0x32,0x51,0x5B,0x43,0x43,0x89,0x89,0x0D,0x51,0x0B,0xEA,0xB6,0xC7,0x1C,0x6B,0x85,0xEA,0xB9,0x08,0x4C,0x51,0xA4,0x8A,0x1C,0x01,0x97,0x97,0x70,0x9E,0x15,0x0E,0x2F,0xF1,0xB5,0x1A,0xAE,0x51,0x2A,0xEC,0x19,0x6B,0x86,0x43,0x92,0x1C,0x86,0xFE,0xD3,0xE3,0x98,0xAE,0x29,0x67,0x98,0x20,0xAE,0xA1,0xC4,0x1A,0xE0,0x64,0xD5,0xAE,0xA1,0x46,0x2C,0x7C,0xBC,0x7C,0x5B,0x54,0x19,0xA2,0x89,0x9D,0xBA,0xF1,0x76,0x61,0xFB,0xDA,0x89,0x94,0x45,0xDC,0x9D,0x5E,0x91,0x3D,0x1A,0xD9,0xC2,0xDA,0xA1,0x5E,0xF2,0xEF,0x62,0xE0,0x91,0x61,0x52,0xE3,0x0B,0xD6,0x3D,0x6B,0x23,0x4A,0xB3,0x46,0x7C,0x1F,0xA4,0x3B,0xAD,0x43,0x62,0x75,0x8F,0x15,0x64,0xDA,0x52,0x8F,0x52,0x10,0xD9,0x0B,0xE6,0x2A,0x97,0x8F,0xA8,0x31,0x8F,0xC4,0xA1,0x10,0x3D,0x10,0x0D,0x68,0xDA,0x57,0xFE,0x70,0x25,0x5D,0x04,0x52,0xC2,0x6B,0xB9,0x04,0xFB,0x5E,0xCE,0x75,0x6E,0x4C,0x57,0x02,0xAD,0x6B,0x2A,0x61,0xA8,0xBF,0x19,0xA1,0x89,0x6E,0x2A,0xD3,0x9E,0x4A,0x8A,0x7A,0x2C,0x79,0xC4,0x1A,0xBA,0xEA,0x75,0x15,0xA1,0x40,0x6E,0x40,0xA7,
ID: 375, Magic Bytes: 0x4C,0x1F,0xEA,0xB9,0x55,0x06,0xF3,0xA0,0x7E,0x2D,0xD8,0x8B,0x67,0x34,0xC1,0x92,
ID: 382, Magic Bytes: 0x65,0x58,0x8D,0xF2,0x64,0xC5,0x0D,0x14,0xF2,0x5C,0x66,0x0D,0x36,0x53,0x60,0x94,0x37,0x82,0xCA,0x82,0xA4,0x50,0xB4,0x40,0xBF,0x4B,0x71,0xD5,0x22,0xD6,0xE5,0xB1,
ID: 385, Magic Bytes: 0xC6,
ID: 390, Magic Bytes: 0xE8,0x1C,0x2F,0xDB,0x49,0xBD,0x8E,0x7A,0x85,0x71,0x42,0xB6,0x24,0xD0,0xE3,0x17,0x32,0xC6,0xF5,0x01,0x93,0x67,0x54,0xA0,0x5F,0xAB,0x98,0x6C,0xFE,0x0A,0x39,0xCD,0x73,0x87,0xB4,0x40,0xD2,0x26,0x15,0xE1,0x1E,0xEA,0xD9,0x2D,0xBF,0x4B,0x78,0x8C,0xA9,0x5D,0x6E,0x9A,0x08,0xFC,0xCF,0x3B,0xC4,0x30,0x03,0xF7,0x65,0x91,0xA2,0x56,0xF1,0x05,0x36,0xC2,0x50,0xA4,0x97,0x63,0x5B,0x0E,0x2B,
ID: 420, Magic Bytes: 0xEA,
ID: 430, Magic Bytes: 0x19,
ID: 485, Magic Bytes: 0x0A,0x42,0xE2,0x00,0x48,0xDE,0x7B,0x74,0xC6,0xDE,0x0F,0x47,0x11,0xD8,0x17,0x35,
ID: 550, Magic Bytes: 0x4D,
ID: 600, Magic Bytes: 0x5B,0xCE,0xA4,0x7F,0x96,0x82,0x36,0x42,0xA5,0x70,0x17,0x9E,0x5D,0x9C,0xE8,0x1C,0x97,0xBF,0x17,0x93,0x19,0x6B,0xCF,0xCD,0xFE,0x1D,0xDE,0x44,0xC2,0x9D,0x88,0x2A,0xB7,0xC9,0xBE,
ID: 601, Magic Bytes: 0xA2,
ID: 611, Magic Bytes: 0x99,
ID: 612, Magic Bytes: 0x88,
ID: 613, Magic Bytes: 0x35,
ID: 614, Magic Bytes: 0x22,
ID: 617, Magic Bytes: 0x2E,
ID: 618, Magic Bytes: 0xFF,
ID: 632, Magic Bytes: 0x80,
ID: 652, Magic Bytes: 0x37,
ID: 675, Magic Bytes: 0xDF,0x8C,0x79,0x2A,0xC6,0x95,0x60,0x33,0x40,0x13,0xE6,0xB5,0x59,0xA7,0x52,0x01,
ID: 711, Magic Bytes: 0x34,
This contains the only log I've gotJacobsmess wrote: ↑Wed Nov 06, 2024 7:22 am So I finally got a canlog from a running vehicle.
Playing back the attached* I get the following IDs...
0x619
0x618 - BMS_ACDC_CONTROL
0x652
0x321 - SAS_HECU_SteerInf
0x06E - BMS_VCU_ICU_Status
0x430 - BMS_BCM_FcBck
0x485 - BMS_VCU_BatLim
0x00A - BMS_VCU_CrashState
0x185 - BMS_VCU_BatPackSum
0x285 - BMS_VCU_Status
0x375 - BMS_VCU_CDIS_currLimit
0x385 - BMS_Service
0x280 - VCU_EHPS_Enable
0x205 - VCU_HECU_TqInfo
0x255 - VCU_HECU_SpdPedal
0x265 - VCU_HECU_SysSt
0x258 - HECU_VCU_FailLmp
0x208 - HECU_VCU_WhlSpd
0x218 - HECU_VCU_VehSpd
0x100 - AVAS_BCM_Status
0x411 - DC_VCU_BCM_Failue
0x500 - VCU_BCM_DisplatCtrl
0x510 - VCU_BCM_CoolReq
0x620 - ICU_VCU_BCM_Temperature
0x499
0x509
0x617
0x538
0x335
0x275
0x400
0x336
0x390
0x382
0x600
0x007
0x536
0x550
0x560
Edit Will add more DBC defs later, I've run out of time!
