This probably has been touched on before but for reason can't find the answer. If I set my Gen 2 charger voltage at 387 volts what should my turn off voltage be? The same or a little above or below?
Posted: Wed Sep 16, 2020 6:17 am
by Boxster EV
Roadstercycle wrote: ↑Wed Sep 16, 2020 1:00 am
My V5 cuts AC about 3-4v above termination voltage.
Posted: Thu Sep 17, 2020 5:11 pm
by Roadstercycle
On a good note my Gen 2, Rev. L is working with the V5 board that I just received. I could not run it long because of not having the cooling setup yet. Single phase, 220 volt USA. As I increased amp output from 5A to 10A and then 15A the charger increased in output as it should have. WIFI is working too but has the same address as motor inverter, is that normal?
Posted: Thu Sep 17, 2020 6:18 pm
by jon volk
Roadstercycle wrote: ↑Thu Sep 17, 2020 5:11 pm
Yes the ip address is the same. Your device can only connect to one wifi connection at a time so it does not cause a problem.
Posted: Mon Sep 21, 2020 5:54 am
by annyung
Hi, hoping I can get some help with setting up my V5 board. Somehow I must have fat fingered and hit 8 and now to can settings are not matching what I'm seeing others post. Typing 8500 doesn't seem to restore them. Also trying to change the current by typing 75 doesn't work.
Settings Menu
1 - Auto Enable : ON
2 - Modules Enabled : 123
3 - Can Mode : Master
4 - Port Type : 1
5 - Phase Wiring : 1
6 - DC Charge Voltage : 400.000000 0V
7 - AC Current Limit : 13A
8 - CAN0 Speed : 500.000031 0
a - Can Debug : OFF
b - EVSE Debug : ON
t - termination voltage : 0.000000 0V
q - To Quit Menu
Posted: Mon Sep 21, 2020 7:26 pm
by Boxster EV
Always a good idea to photo them before changing. Check your termination V too.
Posted: Tue Sep 22, 2020 2:13 am
by annyung
4 - Port Type : 1
a - Can Debug : OFF
b - EVSE Debug : ON
t - termination voltage : 400.000000 0V
q - To Quit Menu
So termination voltage and CAN0 match. When I type 41 it changes 1 Auto Enable to off. I'm sure I'm dense and there is some kind of semantics I'm missing when typing this in even though I've gone through the manual several times.
Posted: Tue Sep 22, 2020 2:57 am
by annyung
Typing 75 into notepad copying and right clicking in the putty terminal is working. I type q to exit and save. Unplugging the usb cable to power off and plugging it back in and reconnecting over serial, 13A for AC current greets me again! Step by step...
4 - Port Type : 1
7 - AC Current Limit : 5A
a - Can Debug : OFF
b - EVSE Debug : ON
q - To Quit Menu
Posted: Tue Sep 22, 2020 5:53 am
by Boxster EV
annyung wrote: ↑Tue Sep 22, 2020 2:57 am
4 - Port Type : 1
a - Can Debug : OFF
b - EVSE Debug : ON
q - To Quit Menu
Sounds like you need to update your firmware as per here:
Thank you for the links. Makes total sense now. I ordered a programmer and should be updating shortly.
Other hurdle is the ebay super charger looks to be bad. 400vdc setpoint but only getting an output of 170vdc and measuring 125vdc at the pins.
Guess that's what I get for buying the cheapest charger on ebay.
Proximity Status : Unconnected /ADC Raw: 1012 AC limit : 0 /Cable Limit: 0 /Module Cur Request: 4444 /DC total Cur:0.29 /DC Setpoint:400 /DC tVolt:400 /DC driven AC Cur Lim: 9709
213834 State: 1 Phases : 0 Modules Avtive : 3 ON D1 H
Phase 1 Feebback // AC present: 1 AC volt: 122 AC cur: 10.67 DC volt: 170 DC cur: 0.16 Inlet Targ: 60 Temp Lim Cur: 15 25 40 EN:1 Flt:0 Stat:77
Phase 2 Feebback // AC present: 1 AC volt: 123 AC cur: 10.67 DC volt: 164 DC cur: 0.00 Inlet Targ: 60 Temp Lim Cur: 15 25 42 EN:1 Flt:0 Stat:77
Phase 3 Feebback // AC present: 1 AC volt: 122 AC cur: 10.67 DC volt: 166 DC cur: 0.14 Inlet Targ: 60 Temp Lim Cur: 15 25 38 EN:1 Flt:0 Stat:77
Posted: Thu Oct 08, 2020 8:13 pm
by Cookie6000
Hi all
Spent the day today tweaking and testing the Gen 2 charger with V4 board in the Audi to charge the 24kW Leaf pack via the Type 1 Zappi EVSE I installed the other week. I have it kind of manually set up via a switch in the boot. When I flick the 12v, the charger and aux coolant pump power on and then charge away. I started off at 5A and steadily moved up to a current limit of 20A. With the EVSE in 'Eco' mode, it charges at ~1.2kW and when you set it to fast, ~3.4kW.
I have limited to this due to the fact the Type 1 plug is from the 3.3kW charge output of the Gen 1 Leaf and the cabling associated. I'll change those out at a later date to cope with faster charge capability. Today though, my questions were all about temperature. I spent a few hours during the charge sequences, between Eco and Fast, the temp increases on and around the charger.
There is a flow and return from the front (rad, motor, inverter, DCDC - primary circulation pump only on during operation of vehicle) to the rear where I have a 2nd aux pump, only in use during charging. The coolant system has been pressure tested and fully filled. Two directions of flow have been trialled. I used an infrared thermometer to take measurements of the 3 x phase circuit boards (through the clear plastic cover), the coolant input and output, the charger casing and the 2 x AC leads. What I found is, especially when on 3.4kW EVSE 'fast' charging, I found the following...
Highest temp was on the middle board - temp ranged from 24 up to 58 deg c before I stopped the charge session for fear of it getting too hot.
Coolant output - max 25 deg
AC input cables - max 19 deg
Casing - max 28 deg
To me, those phase module temps seem high. I am still unsure if I have nailed the cooling setup I have but I just wanted to ask you all your feedback on what temperature ranges (especially on the modules) you have seen before I go and maybe, upgrade the aux pump (from a BMW E49).
One other note, I was charging at 1.3kW for about 40 mins when the middle module began to flash red and the EVSE clicked intermittently, stating 'waiting for EV...'. I ceased the session, started again and it was all ok.
Thanks.
Posted: Fri Oct 09, 2020 10:14 am
Personally I've never measured the temp on a gen2 or a gen3 charger and I have ran them up at full 11kw on 3 phase. I would not be at all worried about a 3kw power supply running at 60c. Even 80c. If we take your values of 58c on the board and 28c on the heatsink this is only a 30c rise. How are these temps being measured? IR, contact probe etc?
Posted: Fri Oct 09, 2020 10:50 am
Temperatures do no matter really as the charger modules will just shut down when they get too hot.
Posted: Fri Oct 09, 2020 11:16 am
by Cookie6000
Jack Bauer wrote: ↑Fri Oct 09, 2020 10:14 am
Thanks. Yes, using an IR temp gun. Guess I am just being overly cautious at this stage in the build I am not over heating anything. The battery modules don't even shift in temp yet. When the middle phase board started blinking and the EVSE began to signal it was waiting for the EV to communicate, I thought it may have been something to do with the temp but if the charger will shut itself down if it gets too hot, that's all I needed to know. Thanks.
Posted: Sun Oct 11, 2020 12:09 am
by deadsled
I've got a Gen 3 charger from an Australian Model X, 3ph 18kW, like the EU versions I believe. Before I buy the controller from Damien, I just want to be sure it will work with my proposed setup. I'm planning to use it with 14 Tesla modules and a small rear SDU. I've already bought an Orion BMS2 - will the Gen 3 charger integrate with the Orion?
Posted: Sun Oct 11, 2020 7:21 am
by joromy
deadsled wrote: ↑Sun Oct 11, 2020 12:09 am
Why du you want to use a Orion BMS, when you have the BMS slaves from tesla already?
You have several options for tesla modules, Simp BMS and EVTV, have used both of them.
If you really want to use Orion please PM me. I want to buy the tesla slaves!!!
Posted: Sun Oct 11, 2020 7:34 am
So this is quite a common question I get asked so I'll answer here and in the first post on this thread for better visibility.
There is no support in the current firmware for any particular bms. However the following options are available :
- The IN1 pin can be used as a charge enable/disable input. Pull it to 12v to enable and ground to disable.
- The external CAN interface is available and could be used to receive commands from a CAN capable bms but no such features are implemented in the current firmware and I have no plans to add.
Just sticking to what we know and have used before, plus I need DCFC capability and until recently the Orion was the only option for out-of-the-box CHAdeMO charging. I've spent a lot already on the Orion so am committed to it, maybe next project I'll consider the alternatives you mention plus the CHadeMO controller I've now seen on this forum.
Let me know if you are serious about the slave module boards, I am in Australia though.
Jack Bauer wrote: ↑Sun Oct 11, 2020 7:34 am
Thank you Damien, I will look into it a bit more with this info.
Posted: Fri Oct 23, 2020 4:41 pm
by fransoa
I use an EVBMW's board for Tesla GEN3 charger with a Tesla GEN3 charger.
There is not much documentation on this configuration. What software is installed on the board ? What version ? what software can be put without unpleasant surprises ? I made the connections as it seems good to do. Then I plugged in the USB cable, powered the board with 12V and connected my PC CAN interface to do tests. The USB interface works perfectly : I can to visualize the logs and the good reception of the TC CAN frame send by my PC on the external CAN bus. But I recieve absolutely nothing on the external CAN bus. What software can I put to do tests?
Bryson wrote: ↑Tue Sep 08, 2020 5:54 am
Ah yes it is supposed to get 12v hot at all times. It does consume some power though, so if you leave the car for long periods, you may have to accommodate.
So now we are at full loop again. Is it Ok to turn the 12 volt power on at the same time as the 220 volt EVSE is plugged in so you don't get battery drain. There may not be an answer without testing?
The workaround I used for this was to use a switch that closes when the charge door (petrol flap) is open, that supplies 12V to the charger.
Someone posted a clever circuit way back in this thread that detects the PP line and fires the charger up first, if you prefer something a bit fancier.
Posted: Fri Oct 30, 2020 8:06 am
If someone wants to design a circuit for powering up via the proximity signal and post here I'll be happy to include it in the next rev build.
Posted: Fri Oct 30, 2020 8:17 am
by clanger9
OT question: what's your preferred circuit design software?
Just getting back into this, happy to help, so I might as well use the same package as you...
Posted: Fri Oct 30, 2020 9:28 am
This is the way I done it for the SimpCharge, use some pull up and pull down resistors to create the Proximity window.
then a simple comparator to set the point at which to activate. and a Pmos of your choice to switch 12V.
You know you could just buy a SimpCharge and just hook up the Proximity line to create your 12V when a plug is inserted.
Posted: Fri Oct 30, 2020 10:25 am
Designspark pcb is my weapon of choice as I'm too lazy to learn anything else. Am making slow progress on kicad though.
Thanks Tom. I'll update the first post on this thread with a link to simpcharge.
