Kia Niro BMS
bigmotherwhale
Has thanked: 17 times
Been thanked: 22 times
Re: Kia Niro BMS
Post by bigmotherwhale »
Does anyone have an idea if this code will work with the Hyundai / Kia hybrid packs?
Edit: looking deeper it seems that it will
could anyone tell me whether you can use the BMS master and the CAN messages alone instead of directly connecting to the slaves?
maciek16c
Been thanked: 10 times
Re: Kia Niro BMS
Post by maciek16c »
I think it should be possible to use stock BMS. Looks like a lot of CAN messages are the same or similar between different Hyundai / Kia models and i have Hyundai Santa-Fe PHEV battery working using Savvycan script or zombieverter (there are still some obd-2 errors, but probably not critical)
bigmotherwhale
Re: Kia Niro BMS
I already went ahead and bought the pack its a Hyundai IONIQ PHEV, its nice to know that it can be done, would you mind sharing your code? Thanks
maciek16c
Re: Kia Niro BMS
Post by maciek16c »
I added short description of my battery in my thread: viewtopic.php?p=62256
bigmotherwhale
Re: Kia Niro BMS
Hello, im trying to use your code and an Arduino to patch into a HEV BMS from a niro as i have been unable to find the CAN commands for the contactors, I have connected to the spi and i think im getting them to talk but the board design is different to that of the CMUs, It has 8X max17845 chips onboard.
I tried playing with the code but i dont know what im doing, and I keep getting "error byte cleared" in serial.
Is it possible to get this to work? could i get some help.
Thank you
bexander
Has thanked: 71 times
Been thanked: 97 times
Re: Kia Niro BMS
Post by bexander »
Yes, this seem to be a integrated BMS, interesting.
So you have connected via SPI to the onborad MAX17841, correct?
My SW is hard coded to 12 slaves with 4+4 cells connected at pos 1-4 and 6-9. This will have to be changed to 8 slaves with 9 cells connected.
The number of slaves also determines the value of check byte so this have to match.
Please provide a serial print out of your results so far, helps a lot for me to determine your progress.
bexander
Re: Kia Niro BMS
Post by bexander »
bexander wrote: Thu Oct 26, 2023 4:17 am The number of slaves also determines the value of check byte so this have to match.
I ment the alive-counter. 0x0C with 12 slaves, 0x08 with 8 slaves. Will need to be changed in 3 places in the SW, daisyChainInit(), writeAllSlaves() and readAllSlaves().
That should get you through the setup.
bigmotherwhale
Re: Kia Niro BMS
Thankyou this is exactly what i needed to know.
Yes I have connected to the SPI of the MAX17841 and pulled up the respective pins.
So i have edited 0x0c to 0x08 in the code.
does this need to be edited too?
"* Reads data from slaves and stores in arrays *
void readData()
for(int i=0; i<4; i++)
readAllSlaves((0x20 + i), true); // Read CELL 1-4 of all slaves
readAllSlaves((0x25 + i), true); // Read CELL 5-8 of all slaves"
and this
* Stores measured cell voltage data in cellVoltage array *
void storeCellVoltage(uint8_t dataRegister, uint8_t readRegisterData[29])
if((dataRegister >= 0x20) && (dataRegister <= 0x23)) // Cell voltage registers 1-4
uint8_t cellNumberOffset = dataRegister - 0x20;
for(int i=0; i<12; i++)
uint16_t measVoltage = ((readRegisterData[25-i*2] << 8) + readRegisterData[24-i*2]);
measVoltage = (measVoltage >> 2) * (uint32_t)5000 / 0x3FFF;
cellVoltage[i*8 + cellNumberOffset] = measVoltage;
if((dataRegister >= 0x25) && (dataRegister <= 0x28)) // Cell voltage registers 5-8
uint8_t cellNumberOffset = dataRegister - 0x20 - 1;
Im not exactly sure how to edit this i just want the voltages from 1-8 on each chip, there are 72 channels even though my bms only uses 64 of them there are no thermistors connected to any of the slaves,
Im not very good at coding i can understand some of it but this is way to much for me, if i start editing this its going to be more of a guess than anything else.
bexander
Re: Kia Niro BMS
Post by bexander »
bigmotherwhale wrote: Thu Oct 26, 2023 1:46 pm void readData()
Try this:
void readData()
    for(int i=0; i<8; i++)
    readAllSlaves((0x20 + i), true); // Read CELL 1-8 of all slaves
  //readAllSlaves(0x2D, true); // Read AIN1 of all slaves (Cell temperature)
  readAllSlaves(0x50, true); // Read DIAG (Die temperature) of all slaves
bexander
Re: Kia Niro BMS
Post by bexander »
bigmotherwhale wrote: Thu Oct 26, 2023 1:46 pm void storeCellVoltage(uint8_t dataRegister, uint8_t readRegisterData[29])
Try this:
	if((dataRegister >= 0x20) && (dataRegister <= 0x27)) // Cell voltage registers 1-8
bexander
Re: Kia Niro BMS
Post by bexander »
I would also comment out this part:
if(dataRegister == 0x2D) // Aux voltage measurements (external temperature sensors)
			storeCellTemperature(readRegisterData);
Like this:
/*if(dataRegister == 0x2D) // Aux voltage measurements (external temperature sensors)
bexander
Re: Kia Niro BMS
Post by bexander »
Change:
const uint8_t numberOfCells = 96;
to
const uint8_t numberOfCells = 64;
bexander
Re: Kia Niro BMS
Post by bexander »
Also this function needs to be changed
boolean balanceCells(uint16_t lowestCellVoltage)
	static uint8_t counter = 1;
	static uint16_t cellToBalanceFilter = 0x0FFF & 0x5555; // Every odd cell
	boolean measureVoltages = false;
  //if(1 == counter) Serial.println("Balance cells");
	writeAllSlaves(0x18, 0x1500, true); // Set WATCHDOG timer to 5s
	if(0 == counter)
		cellToBalanceFilter = 0x0FFF & ~cellToBalanceFilter; // Every other cell
		writeAllSlaves(0x1A, 0x0000, true); // Turn off all cell balancing for one cycle to avoid any switch overlap
	if(1 == counter)
		measureVoltages = true; // OK to measure cell voltages
	for (int i=0; i < 12; i++) // Go through modules to set cells for balancing
		if(2 == counter) // Only set cells once every counter cycle
			uint16_t cellToBalance = 0x0000;
			for (int j=0; j < 8; j++) // Go through cells to set cells for balancing
				uint8_t cellNumber = j+i*8;
				if ((cellVoltage[cellNumber] > startShuntVoltage) && ((int16_t)(cellVoltage[cellNumber] - lowestCellVoltage) > voltageAllowance)) // Ok to balance
					if (j < 4)
						cellToBalance |= (0x01 << j);
					else if (j >= 4 && j <8)
						cellToBalance |= (0x01 << (j+1));
					else //Error
			cellToBalance &= cellToBalanceFilter; // To avoid enabling adjacent balance switches
			writeAddressedSlave(0x1A, cellToBalance, i, true); // Send request to set cell balance switches
			Serial.print(i+1);
			Serial.print(": ");
			//Serial.println(cellToBalance, BIN);
			for(int i=0; i < 8; i++)
				if(4 == i) Serial.print(" ");
				if(i < 4)
					Serial.print((uint8_t)((cellToBalance >> i) & 0x01));
				else
					Serial.print((uint8_t)((cellToBalance >> (i + 1)) & 0x01));
			Serial.println();
		if(dieTemperature[i] > 100) // Check die overtemp
			writeAddressedSlave(0x1A, 0x0000, i, true); // Turn off cell balancing for the module with die overtemp
			Serial.print("Die overtemp, module ");
      Serial.println(i+1);
	counter++;
	if(counter > balanceCellCounterTurnAround)
		counter = 0;
	return measureVoltages;
To:
	static uint16_t cellToBalanceFilter = 0x00FF & 0x5555; // Every odd cell
	if(0 == counter)
	if(1 == counter)
	for (int i=0; i < 8; i++) // Go through modules to set cells for balancing
					if (j < 8)
					else //Error
			Serial.print(i+1);
			Serial.print(": ");
			Serial.println();
	counter++;
		counter = 0;
bigmotherwhale
Re: Kia Niro BMS
Thankyou for helping, I tried the above i think i may have got something wrong as an extra bracket stopped me from compiling, I removed what I thought was the right one and uploaded it and this is what i got. I have included the log and the modified .ino
could you have a look at see i haven't missed something? thanks
BMS2_7_3_modified.ino
(47.06 KiB) Downloaded 832 times
error.txt
(1.2 KiB) Downloaded 756 times
bexander
Re: Kia Niro BMS
Post by bexander »
Replace the entire readAllSlaves() with this:
void readAllSlaves(uint8_t dataRegister, boolean setupDone) // Read all slaves
	uint8_t command = 0x03; // READALL
	uint8_t byteList[3] = {command, dataRegister, 0x00};
	uint8_t PEC = calculatePEC(byteList, 3);
	uint8_t readRegisterData[21];
	uint8_t errorByte = 0x00;
	static uint8_t resendCounter = 0;
	//static uint8_t failCounter = 0;
	/*if(failCounter >= 4)
		//clearBuffers();
		failCounter = 0; // Reset counter
		Serial.println("Buffers cleared");
	SPI.beginTransaction(MAX17841);
	// Load the READALL command sequence into the load queue
	digitalWrite(SPI_MAX_CS_PIN, LOW);
  SPI.transfer(0xC0); // WR_LD_Q SPI command byte (write the load queue)
  SPI.transfer(0x15); // Message length (5 + 2 x n = 21)
  SPI.transfer(command); // READALL command byte
  SPI.transfer(dataRegister); // Register address
  SPI.transfer(0x00); // Data-check byte (seed value = 0x00)
  SPI.transfer(PEC); // PEC byte
  SPI.transfer(0x00); // Alive-counter byte (seed value = 0x00)
  digitalWrite(SPI_MAX_CS_PIN, HIGH);
  transmitQueue();
	// Read the receive buffer
	SPI.transfer(0x93); // RD_NXT_MSG SPI command byte
	for(int i=0; i<21; i++)
		readRegisterData[i] = SPI.transfer(0x93);
	errorByte |= receiveBufferError();
	SPI.endTransaction();
	// Verify that the device register data is received correctly during the READALL sequence
	if(!((readRegisterData[0] == command) && (readRegisterData[1] == dataRegister)))
		errorByte |= mismatchBefore;
	if(setupDone)
		uint8_t checkPEC = calculatePEC(readRegisterData, 19);
		// Check check-byte, PEC and alive-counter
		if(!((readRegisterData[18] == 0x00) && (readRegisterData[19] == checkPEC) && (readRegisterData[20] == 0x08)))
			errorByte |= mismatchAfter;
			if(readRegisterData[18] != 0x00)
				readAllSlaves(0x02, false); // Read STATUS of all slaves with checks ignored
				writeAllSlaves(0x02, 0x0000, true); // Clear STATUS register
				Serial.println("STATUS cleared");
	/*// Print data received
		Serial.print(readRegisterData[i], HEX);
		Serial.print(" ");
	Serial.println();*/
	if(errorByte) // Error
    resendCounter++;
    Serial.println(errorByte, HEX);
    errorByte &= 0x00; // Clear errors
    Serial.println("errorByte cleared");
    if(resendCounter > 2)
			Serial.println("READALL fail");
			resendCounter = 0;
			//failCounter++;
			return;
    delay(1);
    readAllSlaves(dataRegister, setupDone); // Resend READALL
  else // No errors, clear counters and store data received
		resendCounter = 0; // Reset counter
		//failCounter = 0; // Reset counter
		if((dataRegister >= 0x20) && (dataRegister <= 0x2B)) // Cell voltage measurements
			storeCellVoltage(dataRegister, readRegisterData);
		if(dataRegister == 0x50) // Die temperature measurements
			storeDieTemperature(readRegisterData);
		if(dataRegister == 0x13) // Read SCANCTRL to check if data is ready to be read
			checkDataReady(readRegisterData);
		if(dataRegister == 0x02) // Read STATUS and print content
				Serial.print(" ");
			Serial.println();
Adjusted for 8 slave modules.
bigmotherwhale
Re: Kia Niro BMS
Okay thanks again, I will give that a go and report back.
bigmotherwhale
Re: Kia Niro BMS
Seems to be getting closer, still seems to have 12 groups in the readout though?
Here is what im getting.
error.txt
(3.78 KiB) Downloaded 844 times
bexander
Re: Kia Niro BMS
Post by bexander »
In writeAllSlaves() there is an error in your code:
// Check alive-counter
		if(!(readRegisterData[5] == 0x0))
Should be:
		if(!(readRegisterData[5] == 0x08))
bexander
Re: Kia Niro BMS
Post by bexander »
There is also a lot of other places that need to be changed, I realize.
Post your latest code and I will make some changes to it and post it back.
bigmotherwhale
Re: Kia Niro BMS
Here is the code its been modified just by your suggestions.
Cheers
BMS2_7_3_EDITED.ino
(46.68 KiB) Downloaded 820 times
bexander
Re: Kia Niro BMS
Post by bexander »
Try with this:
BMS2_7_3_EDITED_2.ino
(46.67 KiB) Downloaded 910 times
bigmotherwhale
Re: Kia Niro BMS
i get errorbyte cleared 1
Would it be a good ide to enable the HEX output in the code to see what the slaves are spitting out?
error.txt
(1.31 KiB) Downloaded 1000 times
bexander
Re: Kia Niro BMS
Post by bexander »
Check now
(46.67 KiB) Downloaded 946 times
bigmotherwhale
Re: Kia Niro BMS
It has the correct number of cells but im getting measurecelldata wd timeout
error.txt
(861 Bytes) Downloaded 805 times
bexander
Re: Kia Niro BMS
Post by bexander »
Found a typo...
