Page 4 of 4
Re: E Golf Battery pack
Posted: Wed Nov 16, 2022 7:27 am
by jeltop
arber333 wrote: ↑Tue Nov 15, 2022 8:57 pm In my opinion you should reconfigure modules from 12S into 16S configuration. That way inverter will work at higher battery potential.
As i have Volt battery 12S with my solar setup i am seeing some adverse behaviour as inverter has 48V minimum for change from utillity.
If i would be able to use higher cell count i could setup for it to move in higher voltage range.
hi
What do you mean? I am a beginner, 12S and 16S what is it exactly?
how can i test if the batteries are still good or dead? because I bought it second hand
I take a 12v car charger and I plug into a module for example, to see if it charges? thank you
thank you
Posted: Tue Dec 27, 2022 12:06 am
by Alibro
jeltop wrote: ↑Wed Nov 16, 2022 7:27 am hi
thank you
12S is the number of cells in series. 2 or 3P is the number of cells in parallel.
These are lithium ion batteries. Do not use a battery charger designed for lead acid batteries to charge them as it will destroy them.
If you have never used lithium ion batteries before then I'd recommend you do a LOT of studying before going any further or you risk damaging the batteries at best and burning down your house at worst.
Posted: Tue Sep 19, 2023 8:03 am
by JaniK
I have a small issue:
Module #8 was bench tested and working as a 10S group CAN module before. I have a screenshot from SimpBMS to verify that.
Yesterday I plugged in CAN modules 5/6/7 and 8
(With the cell interconnect wiring for their respective cell Groups.)
The module #8 is not Sensing/sending voltages from cells 9 and 10. I tested another cell interconnect cable and issue seems to not be between cell taps but in the CAN bus module #8.
All other CAN modules work fine.
I hope the module is not changing its behavior related to other modules sending some ids, since I am re-using the original VW CAN-bus harness. With the enable and can lines running through the other modules.
Posted: Tue Oct 10, 2023 5:03 pm
by boekel
JaniK wrote: ↑Tue Sep 19, 2023 8:03 am I have a small issue:
that is correct, the old version (Panasonic) was able to sense 12s on all CMU's, the Samsung version cannot sense more cells than originally in the pack.
iirc 3 CMU's are not capable of 12s.
Posted: Sat Jun 22, 2024 6:55 pm
by MrFlibble
I hope this is a good thread to post this request rather than start a new one.
I am planning to remove a pack from an e-Golf (which I don't have yet) like in this video:
I'm trying to figure out what size table top on a scissor table I would need to do this on a budget
I have attached a picture of a diagram from the workshop guide.
The minimum table size I'd need will be determined by the distance along the blue and green lines, as I will be building the appropriate support struts to fit exactly as required by the red circled areas (rather than copying the VAG multipurpose 'pegboard' table)
Does anyone have the base of this pack leftover from disassembly, and could they advise the dimensions marked with the blue and green lines, please?
Posted: Sun Jun 23, 2024 7:37 am
by Alibro
Have you seen the two videos I made of disassembling eGolf packs? I don't have any measurments and the cases are long gone but you should be able to figure it out close enough.
Posted: Fri Jun 28, 2024 4:42 pm
by MrFlibble
Thanks - your videos are actually some of the first I came across on YouTube when I started looking into my project!
So, I'm estimating about 550 to 600 mm for the short (green) length, and 1420 to 1470 mm for the long (blue) length.
The latter dimension is going to make it too long for all but the largest scissor tables I can find, so quite costly.
I think I'm going to custom build a low, fixed & wheeled platform instead, and lift/lower the car onto it with a 2-post, unbolt the battery and lift the car off the battery, rather than lower it out.
Once I have some accurate dimensions of these mount points, and pictures of such a process, I'll share to add to the data we have here.
Posted: Fri Jun 28, 2024 6:34 pm
by Alibro
If the Golf is totalled anyway then could you tip it on it's side?
Posted: Thu Jul 25, 2024 8:28 pm
by Bratitude
Picks up a 2019 e golf pack and tore it down. Ugly packing/bus bar design.
Word of caution!
The contractor assembly must have a capacitor bank, as it will hold a HV charge!
I was very lucky I only got a minor shock from handling it after the pack was torn down.
Posted: Fri Jul 26, 2024 11:03 pm
by Alibro
I think I mentioned the shock risk in one of my videos above.
Posted: Tue Jul 30, 2024 7:15 pm
by haand
Hello,
I also purchased a e-golf pack a month ago and have now teared it down into bits and pieces. I think I now have got a good clue now how its built up and how I can interact with the CMCs.
I'm writing here with no questions at the moment, just want to spread some insights I learned along the way so that the next one that tries this has a smoother journey. A lot of what I'm wiring is already in this thread, so this will aim to sum that up a bit. Basically, this post is what I would like to have had from the start.
The pack I got is from a 2020 e-Golf with 50000 km on it. Got it of a junkyard in Norway for about $2500. My plan is to mount at least 72 of the 88 cells into a 1969 Austin Mini, pair it up with a Mitsubishi Outlander rear motor, rear inverter and dcdc/obc. I was planning to buy a separate BMS, but after I learned how to interact with the VW CMC:s, I have decided to program it myself and save a lot of bucks.
OVERVIEW
The pack consists of:
8 master modules (4s3p)
9 full slave modules (4s3p)
10 half slave modules (2s3p)
Total pack is 88s3p. Each cell is 37 Ah, each cell cluster 37*3=111 Ah. The pack interconnections is of 35 mm^2 copper busbars, both stiff and flexible mixed.
Every master module communicates over CAN (500 kbs) and the most important bits has been backwards engineered by the champs in this thread (kudos to them!). Every master module consumes about 30 mA when awake and powered from 12V.
This is what can be read and controlled over CAN:
- Read every cell voltage, accuracy 1 mV
- Read temperature of every module, 1 sensor per module. Accuracy 0.5 degC
- Read balancing status for every cell
- Control balancing on/off for every cell
The master modules seems to be very resistant against malconnections. I have not broken any masters, even though I messed up the connections many times. At some times, I have felt heat purge through the cover of the PCB when I messed up some blue connectors, but they seem to not take damage. So don't worry too much ;).
WIRING
The modules are connected with busbars. These are probably of least interest as these might be hard to reuse later given their unique shapes.
In the pack you'll find two main cables harnesses, one orange and one black.
Black = 12V cabling, U30, Ignition, CAN H, CAN L etc. Connects all master modules
Orange = Balancing leads between slaves and masters + temperature leads of the slaves
The orange cabling is actually 8 separate harnesses. First thing is to unwrap most of the orange tape to find the 8 separate smaller harnesses.
Each harness has:
- One black connector = Temperature leads to the master
- One red connector = Balancing leads to master
- Two, three or four blue connectors = Balancing leads and temperature leads from slaves. More on this later...
CONFIGURATION
Every master modules is uniquely configured for a set of either full of half slave connections.
CMC1 = 2 + 2 + 2 + 2
CMC2 = 4 + 2 + 2
CMC3 = 2 + 2
CMC4 = 4 + 2
CMC5 = 4 + 4
CMC6 = 4 + 4
CMC7 = 4 + 4
CMC8 = 4 + 2
Note: CMC 5/6/7 and CMC 4/8 share the same configuration, therefore, the orange cable harness is interchangeable between those.
The master is always the most negative. From the positive pole of the master, the first slave's negative connects, and so on.
(-) Master (+)(-) Slave #1 (+)(-) Slave #2 (+)(-) Slave #3 (+)(-) Slave #4 (+)
The orange cable harness with 4 blue connectors goes to CMC1.
- The only CMC with 4 slaves
- Slave #1 blue connector with one of the cables yellow
- Slave #2 blue connector with one of the cables red
- Slave #3 blue connector with one of the cables purple
- Slave #4 blue connector with one of the cables green
The orange cable harness with 3 blue connectors goes to CMC2.
- The only CMC with 3 slaves
- Slave #2 blue connector with one of the cables purple
- Slave #3 blue connector with one of the cables green
For the rest of the cable harnesses with only 2 blue connectors, it's a bit more tricky. As it happens, slave #1 will always have the blue connector with the yellow cable (among others, but let's focus on the yellow). If the blue connector with the yellow cable has:
- 4 cables in total, the first slave is a half module. This means the cable harness is for CMC3.
- 6 cables in total, the first slave is a full module This means CMC 4/5/6/7/8
If the other connector than the one with a yellow cable has:
- 4 cables, then its for CMC 4 and 8
- 6 cables, then its for CMC 5, 6 and 7
CONNECTION
In order to make the master modules behave "nicely" and send and respond on CAN as expected, they need all prerequisites fulfilled:
- The right orange cable to the right amount of slaves and the right type of slave (as per above).
- All brown wires from the black connector to GND
- All green and red, green and yellow wires from the black connector to +12V (TO BE CONFIRMED)
- Master (+) terminal connected to Slave 1 (-)
- Slave 1 (+) connected to Slave 2 (-) and so on...
The cell temperature and balancing status is reported continuously.
The cell voltages are only transmitted as response to a message:
- Identified CAN standard: 0xBA
- Byte 0: 0x45
- Byte 1: 0x1
- Byte 2: 0x28
- Byte 3: 0x0
- Byte 4: 0x0
- Byte 5: 0x0
- Byte 6: 0x0
- Byte 7: 0x30
For testing, I've been using CANKing. Works well enough and has the functionality needed for this.
All CAN communications are documented in this DBC file. This file is based on the works of Tom-evnut, but complemented and cleaned up by me.
https://github.com/haand22/VW-e-Golf.git
CELL CHARACTERISTICS
I've done a full cycle test, documenting voltages and mAh:s with the equipment I had (IMAX B6). I got a total capacity of 121,2 Ah, which is too much of course... However, I will be using the data and just scale down the Ah:s a bit. The overall SOC vs. Voltage curve showcase the characteristics of the cell quite a lot:
https://github.com/haand22/VW-e-Golf/bl ... C_vs_U.png
Posted: Tue Jul 30, 2024 10:56 pm
by Bratitude
Alibro wrote: ↑Fri Jul 26, 2024 11:03 pm I think I mentioned the shock risk in one of my videos above.
Not everyone has the luxury of skimming through video content πŸ€·πŸΌβ€β™‚οΈ
Good to get everything in writing to build wiki pages
Posted: Wed Jul 31, 2024 9:50 am
haand wrote: ↑Tue Jul 30, 2024 7:15 pm All CAN communications are documented in this DBC file. This file is based on the works of Tom-evnut, but complemented and cleaned up by me.
What have you actually changed?
Thank you for the very detailed wiring explanation. Can you please put this on the wiki, I have created a page dedicated to the battery.
https://openinverter.org/wiki/VW_EGolf_Battery
Posted: Wed Jul 31, 2024 9:01 pm
by Alibro
Bratitude wrote: ↑Tue Jul 30, 2024 10:56 pm Not everyone has the luxury of skimming through video content πŸ€·πŸΌβ€β™‚οΈ
I'm shocked and disappointed you don't hang on my every word. :o
:lol:
Posted: Thu Aug 01, 2024 1:05 pm
by Alibro
haand wrote: ↑Tue Jul 30, 2024 7:15 pm Hello,
OVERVIEW
WIRING
Each harness has:
CONFIGURATION
CMC2 = 4 + 2 + 2
CMC3 = 2 + 2
CMC4 = 4 + 2
CMC5 = 4 + 4
CMC6 = 4 + 4
CMC7 = 4 + 4
CMC8 = 4 + 2
CONNECTION
- Byte 0: 0x45
- Byte 1: 0x1
- Byte 2: 0x28
- Byte 3: 0x0
- Byte 4: 0x0
- Byte 5: 0x0
- Byte 6: 0x0
- Byte 7: 0x30
This is a really great post and much more detailed than I could have managed so thanks for sharing.
I am in the process of building a power wall with the remnants of the 2nd battery pack I opened and plan to hook it up to a hybrid inverter but had not yet confirmed my plans for a BMS. You mentioned you only plan to use part of this pack for your Mini so I was wondering how the BMS will cope with cells 73 to 88 missing?
Posted: Sun Aug 11, 2024 8:30 am
by Wlm2596
Hi all, I've found this and another conversation very useful, however I still have two unanswered questions,
1) does anyone have a diagram of how each of the 'slave' modules connect to the 'master' as in, which port of each 'master' connector go to what corresponding port on the 'slave'?
And 2) we seem to be missing a 'master' module and one large and one small 'slave' module how will i know the ID of each 'master' to determine what slaves can connect to it?
Posted: Wed Aug 28, 2024 6:14 am
by haand
Alibro wrote: ↑Thu Aug 01, 2024 1:05 pm This is a really great post and much more detailed than I could have managed so thanks for sharing.
Yes, I’ll update the Wiki page when I have time. Life comes in the way ;)
I will talk to each BMS master individually using an Arduino Due. As long as each master is β€œhappy”, meaning it has the correct amount of slaves connected, it should be good. So for my eMini, I’ll be using 6 or 7 masters with corresponding slaves. Note that I will not mount them in the same order as in the eGolf, but that won’t be a problem.
Posted: Wed Aug 28, 2024 6:17 am
by haand
Wlm2596 wrote: ↑Sun Aug 11, 2024 8:30 am Hi all, I've found this and another conversation very useful, however I still have two unanswered questions,
1) Yes, I noted all pinning. I can share it soon. Just need to clean it up a bit. In short, orange connector is high voltage balancing leads, blue/black connector next to the orange is for temperature sensors of the slaves, black connector is for U30, U15, KL31, CANH, CANL, etc.
When you connect the master on CAN and feed it with power, it will talk. Just look at the message IDs to determine what master it is. Look in the DBC file to cross reference. Good luck! πŸ€
Posted: Fri Aug 30, 2024 6:18 am
by haand
tom91 wrote: ↑Wed Jul 31, 2024 9:50 am What have you actually changed?
The temperature measurement signals are now correct for each master. The number of cells to balance and read voltage from is different for each master. This is now reflected in the dbc (master 3 only has 8 cells, not 12, for example). Also added the Rx message for requesting voltages from all masters.
Posted: Tue Sep 17, 2024 10:33 am
by egolfer
hello,
i've just discovered this forum and this "hot" thread about the "internals" of the eGolf battery pack. it's amazing
let me say i own an eGolf since 2020 and the only "remark" is the battery capacity (gross 36kWh as you know..)
as i am pretty technical (on low-power electronic/embedded software, in the automotive sector) and open to experiment (done with the proper safety measure, of course), i'm trying to wet my feet also in this HV battery, and so i'm following eagerly this discussion
in the short term, i'd like to connect to the CAN bus of the EV and start to "dump" all the traffic (for the "transactions" in the use cases, like driving and charging..) to see if a future upgrade of the EV battery can be done..
i see that some china companies are starting to offer replacement batteries with "enhanced" capacity, but i'm wondering if they are able to offer a safe(r) solution as the current one: https://mtgbattery.com/volkswagen-e-glof/
i'm wondering, for example, if they had to "reverse-engineer" the comunication protocol, between car and battery with the proper knowledge or if there are eventually missing use-cases (maybe "border-line", of course) that could lead to reduced performance and/or dangerous states
this is general introduction, just to say hi and eventually looking later for more advices.
again thanks for the shared information and this great thread
Posted: Fri Oct 04, 2024 6:24 am
by haand
Just want to shout out to anyone interested that I've started a Youtube channel where you can follow my EV-conversion, using the e-Golf battery and BMS setup. Here is a link:
https://youtube.com/@haand001?si=rCqsvxr0MDG3Sndo
Posted: Wed Oct 30, 2024 10:04 am
by Alibro
For anyone with Samsung VW eGolf (or similar) battery modules who want to connect them to an aftermarket BMS but don't have the correct harness and have zero PCB design experience this might help.
I recently watched a video by Jehu Garcia on Jeep battery modules where he designed a PCB to replace the standard module PCB for Jeep batteries.
The Jeep modules are 12S I think but the boards fit the eGolf 4S modules just fine. I ordered 5 PCB's from JLC PCB for half the cost of PCBWay using Jehu's Gerber files.
Jehu's links don't work so I got the connectors and plugs with pre crimped cables from Aliexpress. The cables are too short but I figured it was easier to solder cables than crimp them but might give crimping a go. The links in the video don't work so here are the links from Aliexpress
Gerber files https://www.pcbway.com/project/sharepro ... f9f43.html
Connectors plugs and pins https://s.click.aliexpress.com/e/_DlOQARB
Plugs with leads https://s.click.aliexpress.com/e/_DBfYea9
Thermistor pins https://s.click.aliexpress.com/e/_Dl2TCmd
