Page 4 of 4
Re: Johannes in a Blue Pill
Posted: Wed Jun 17, 2020 6:56 pm
by bexander
Ok, thanks, that explains alot!
I've just tested the hardware and it works.
Please, can you tell me how I upload first the bootloader and then the firmware, without erasing the bootloader, using stm32flash.
I guess -s option is needed but at what adress?
Posted: Wed Jun 17, 2020 7:38 pm
It's 11 years ago that I used stm32flash
Boot loader is on 0x08000000 and firmware at 0x08001000
Posted: Wed Jun 17, 2020 7:40 pm
by bexander
Hm, I've made some progress, I think.
Did:
stm32flash -w stm32_loader.hex -b 115200 /dev/ttyUSB0
stm32flash -w stm32_sine.hex -e 0 -b 115200 /dev/ttyUSB0
Now the onboard green led blinks!
Update:
It works!
Thank you for all your help!!
Posted: Thu Oct 29, 2020 6:52 am
by aravinth
I have flashed my Bluepill with a USB Bootloader and when I flash it with stm32_sine.bin the green led stays on.
Where do I find the bootloader which supports stm32_sine firmware ??
Posted: Thu Oct 29, 2020 7:11 am
by bexander
Posted: Sat Oct 31, 2020 1:28 pm
by aravinth
Hello, I've got response from the bluepill.
My Current setup is Bluepill connected with USB to TTL Convertor, I used Putty on linux ubuntu for serial terminal.
I cant seem to start inverter in manual mode, typing start 2 on the terminal gives response as Inverter started, set fslipspnt 10 , set ampnom 10 and response is Set ok, and when I try to select the direction as set dir 1 it says value out of range, so I couldn't see any pwm pulses on any pwm pins.
Someone please tell me how to select the direction.
Thank you.
Posted: Sat Oct 31, 2020 4:32 pm
by Isaac96
Pull the FWD pin to positive (3.3v).
Not sure which pin that is, check the schematics.
Posted: Sat Oct 31, 2020 4:38 pm
by Bigpie
Usart seems funky on my bluepills. Not sure why, if I use USB TTL the communication works, using Olimex mod wifi or demos d1 the communication doesn't work.
Anyone any idea why? These cheap bluepills seem very hit and miss.
Posted: Sat Oct 31, 2020 5:05 pm
by bexander
Bigpie wrote: ↑Sat Oct 31, 2020 4:38 pm
What do you mean with seial communication doesn't work with WiFi-module. Please be more specific, is there no transmissions, signals are there but can't receive anything etc.
Have you tried to reverse postion of Tx and Rx when using the WiFi-modules?
Posted: Sat Oct 31, 2020 6:01 pm
by Bigpie
Oops, I get an error on index.html, cannot parse json.
If I look at request or hit '
http://x.x.x.x/cmd?cmd=json' I get
I've tried with the Olimex Mod-WiFi that I know works as I pulled it from my inverter.
Posted: Mon Nov 02, 2020 7:43 am
by aravinth
Hello Isaac96, thanks for your reply.
FWD pin is pb7 on bluepill, I tied pb7 to 3.3v still got no pwm output when I enter start 2 on terminal, I get response as Inverter started but no PWM output.. And also when i type get dir it says 0.
Posted: Mon Nov 02, 2020 8:35 am
by bexander
You need to pull PB1 high as well. Also pull PB6 high for a short period to start the inverter.
Now if you have no errors you should get PWM.
You proably will have to use a potentiometer for current feedback and DC-bus feedback, otherwise overcurrent and udclow error is likely, and no PWM.
Posted: Tue Nov 03, 2020 11:39 am
by aravinth
I finally got PWM in manual mode.
Here's what I did To Start the Inverter in manual mode on bluepill, might help newbie like me.
Bluepill on breadboard with 5v, 3.3v and GND pulled out.
Pull B1 to 3.3v , B7 to 3.3v , and B6 to 3.3v momentarily. (B1_ MPROT/UAUX), (B6-Start),(B7-FWD).
Pull B8 to GND . (B8-REV)
Then issue "start 2" on terminal
Then type set "fslipspnt 1"
Then "ampnom 1"
This outputs a clean 50/50 duty cycle on all 6 PWM outputs.
Next I'm gonna try connecting the bluepill to the ESP8266, Wish me luck.
