Page 4 of 4
Re: Nissan Leaf and Zombieverter minimum components need?
Posted: Wed Jan 28, 2026 12:21 pm
by Taichi
Hello. Need some information about maximum RPM EM57 Engine. I added 2 reductors from rear audi axis, wonna make AWD. But it multiply reduction ratio. Need RPM near 16000 RMP. Anyone run EM57 with 16K RPM? Thx for answer.
Posted: Thu Jan 29, 2026 1:59 pm
by Bratitude
common info thats easily found.
10500rpm, e+ leaf goes to 11330rpm.
Any faster are bearing speeds start to exceed and rotor may start to expand.
Posted: Tue Mar 10, 2026 8:36 am
by blasaab
Hi i have a board with this missing components. can someone tell me what component to skip on leaf setup.
Posted: Tue Mar 10, 2026 1:51 pm
What else are you going to control? what pins will you use?
Just fit all and not restrict yourself.
Posted: Wed Mar 11, 2026 5:41 am
by blasaab
I dont have those component and dont know what they are for. i can order later and fit but now i want to test my leaf motor/inverter without some off this components.
Posted: Wed Mar 11, 2026 7:21 am
by J0hannes
You have on your list parts from modules: power supply, Can3, RS232, LIN bus, Digital outputs and some others.
At least if you don't have any of those power supply related components you listed, you can't use the board at all.
https://github.com/damienmaguire/Stm32- ... ematic.pdf
If it helps, you can look from the scematic yourself, what goes where.
Posted: Wed Mar 11, 2026 5:41 pm
by blasaab
J0hannes wrote: Wed Mar 11, 2026 7:21 am You have on your list parts from modules: power supply, Can3, RS232, LIN bus, Digital outputs and some others.
Thanks Johannes that helped
