Posted: Mon Nov 14, 2022 4:58 pm
oh, I understand. Is the mosfet IC5 shorted? Measure from the right pin (GND) to tab (positive).
openinverter Community
https://openinverter.org:443/forum/
In short, pin 3 and pin 6 are being activated since I started without activating the 12V of pin 23johu wrote: ↑Mon Nov 14, 2022 8:54 am I don't quite understand your issue yet, so will just give you general info
- Pin 3 becomes active as soon as you power up the drive unit - if less than udcsw/2 V are measured after 5s it will drop
- Pin 6 becomes active as soon as you give the start signal (12V, pin 23) AND udc>udcsw
